cannot unhome while moving
- Mike_Eitel
- Topic Author
- Thank you received: 184
19 Apr 2011 17:12 #9090
by Mike_Eitel
cannot unhome while moving was created by Mike_Eitel
Hi good evening
Sorry to ask but what could be the reason for :
"cannot unhome while moving, joint 0" error message
As soon as I press the swith, this message apears ??
Any idea what I do wrong??
THX Mike
HAL
net both-home-x <= debounce.0.1.in parport.0.pin-13-in-not #****
#net both-home-x-not <= debounce.0.1.in parport.0.pin-13-in
net both-x debounce.0.1.out =>
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 21000
setp stepgen.0.dirsetup 18000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
net both-x => axis.0.neg-lim-sw-in
net both-x => axis.0.pos-lim-sw-in
net both-home-x => axis.0.home-sw-in
INI
[AXIS_0]
TYPE = LINEAR
MAX_VELOCITY = 3.2
MAX_ACCELERATION = 24.0
STEPGEN_MAXACCEL = 48
SCALE = 640
BACKLASH = 0.2
FERROR = 1
MIN_FERROR = 0.25
MIN_LIMIT = 0 # -225.0
MAX_LIMIT = 250 # 225.0
HOME = 3.0 # 350
HOME_OFFSET = 20.0 # 450
HOME_SEARCH_VEL = 2.0
HOME_LATCH_VEL = 0.5
HOME_FINAL_VEL= 1.0
HOME_IGNORE_LIMITS= YES
HOME_IS_SHARED= YES
HOME_SEQUENCE= 0
#VOLATILE_HOME= 1
USEINDEX= FALSE
THX Mike
HAL
INI
[AXIS_0]
TYPE = LINEAR
MAX_VELOCITY = 3.2
SCALE = 640
BACKLASH = 0.2
FERROR = 1
MIN_FERROR = 0.25
HOME = 3.0 # 350
HOME_FINAL_VEL= 1.0
HOME_IS_SHARED= YES
HOME_SEQUENCE= 0
#VOLATILE_HOME= 1
USEINDEX= FALSE
19 Apr 2011 17:19 #9092
by BigJohnT
Replied by BigJohnT on topic Re:cannot unhome while moving
Which switch are you pressing?
- Mike_Eitel
- Topic Author
19 Apr 2011 17:23 #9093
by Mike_Eitel
Replied by Mike_Eitel on topic Re:cannot unhome while moving
Hi John
the correct one for x
Y does no harm, but with the debounce delay a limit error, as it shoud be.
19 Apr 2011 17:28 #9095
by BigJohnT
The correct one for what? Please the name of the button...
- Mike_Eitel
- Topic Author
19 Apr 2011 17:34 - 19 Apr 2011 17:39 #9098
by Mike_Eitel
Maybe I missunderfstood you.
To start I use the normal axis home button, that in my case seams to start all axes, corretly X as first
I press on a switch comig in via net both-home-x <= debounce.0.1.in parport.0.pin-13-in-not
This signal works fine.
After a debounce it is used some time later ( for testing 3000ms ) it generates for that axis also a limit sitch emergency halt.
I forgot:
8.04 with 2.4.6
I forgot:
8.04 with 2.4.6
Last edit: 19 Apr 2011 17:39 by Mike_Eitel. Reason: versions
19 Apr 2011 18:10 #9100
by BigJohnT
Is the first line the actual line? Comments are not allowed on the same line as commands in HAL.
I thought your were pressing a button in Axis not one connected to parallel port pin 13... so you have a limit switch connected to parallel port pin 13. And your using debounce on the switch. I don't see where the can't unhome would come from...
- Mike_Eitel
- Topic Author
19 Apr 2011 18:25 #9104
by Mike_Eitel
Taking away the comments... doesn't change anithing, but as fare as I remarked, commenting works mostly.
And I see no reason for that message neither.
Do you know what that message means in detail, and where I could find it. ( Als a google search didn't help... before I tied it via this forum )
SHIT its connected to my EMERGENCY BUTTON
Stupid me chnaged config only patually
Sorry for the asking
Mike
Mike
19 Apr 2011 18:44 #9109
by BigJohnT
I'm just glad you sorted it out.
