Silly bin/sh question
- Mike_Eitel
- Thank you received: 185
19 Jun 2011 11:15 - 19 Jun 2011 11:15 #10619
by Mike_Eitel
Replied by Mike_Eitel on topic Re:Silly bin/sh question
Hi
I tried in a file called M105
#!/bin/sh
# M101 in your G code program will run the Linux commands in this
# shell script "batch" file, passing the P and Q variables as command
# line arguments.
# give the command line arguments descriptive names
#P=$1
#Q=$2
axis-remote -c
exit 0
NO REACTION
I tired in terminal and get the error message:
x server insecure (must use xauth-style authorisation); command ignored
What do I do wrong?
EMC 2.4.6 UBU 8.4
THX Mike
#!/bin/sh
# line arguments.
#P=$1
#Q=$2
axis-remote -c
exit 0
NO REACTION
What do I do wrong?
EMC 2.4.6 UBU 8.4
THX Mike
Last edit: 19 Jun 2011 11:15 by Mike_Eitel. Reason: typo
19 Jun 2011 13:50 #10622
by ArcEye
Replied by ArcEye on topic Re:Silly bin/sh question
Hi
I created a test file which just called axis-remote -c , same as yours, and it works both as a child process of Axis and from a separate terminal window.
So I suspect that either your path is not set up, or your file permissions are wrong, or your user permissions are wrong.
All M1xx must be located in the directory set out in your .ini file
eg.
[DISPLAY]
PROGRAM_PREFIX = /home/me/emc2/ngc
If they are not they will not work, but you should get an error to stderr saying the file could not be found.
Next all M1xx files must be executable by all users, ie permissions set at least to 755 and maybe 777 to be ultra sure.
If you try to create file permissions as a user with limited access, that often is the source of the problem.
Log in a root to be sure before using chmod or at least use 'sudo chmod'
I personally never use /bin/sh, but rather /bin/bash, but that is because it is more powerful and flexible and I am more familiar with it.
It should not make any difference to the command succeeding.
Attached is a zip file containing the file which works on my system, with permissions set wide open at 777.
If that works, backtrack from there as above.
eg.
[DISPLAY]
- Mike_Eitel
19 Jun 2011 16:05 #10624
by Mike_Eitel
THX Arceye
I'll try that tommorow.
Principally I have the M1xx running, My problem is that I can not see them in the axis window...... Thats why I want to try remore axis.
When I do test f.x with halpins it works fine
I always can test that in a terminal before I "code it into a file"
So I wonder why I can not run axis-remote ... I get as described a error message that I do interpret as an acess-rights problem.
Can you run these fubctions via terminal .. Can you request the -c and get no error message?
Mike
Mike
- Mike_Eitel
20 Jun 2011 13:08 #10653
by Mike_Eitel
HI I tested again
I can set a halpin...... So think I handle correc basic treatment of M1xx via pyvcp..
Still axis-remote is not showing any reaction.
Thats why I remain on my question why do I get in terminal windows this error message:
Any ideas ?
THX
Mike
Any ideas ?
THX
Mike
20 Jun 2011 14:14 - 20 Jun 2011 15:07 #10662
by ArcEye
Hi
See the below, basically your xserver is insecure, you probably have set it for automatic login or allowed remote login or similar.
wiki.tcl.tk/1829
Make sure you have to log in as a user with a password and get an xauth style auth via a window manager.
Just using gdm set up properly should do it.
I use ldm, which is more secure and way, way faster than gdm, but that's just my preference.
It is worth persevering with the M1xx files.
The file can be a simple bash script or even a compiled C program, receiving the P and Q arguments via the main(argc, argv) function, so you can do some pretty powerful stuff.
wiki.tcl.tk/1829
Last edit: 20 Jun 2011 15:07 by ArcEye.
- Mike_Eitel
20 Jun 2011 21:53 #10686
by Mike_Eitel
Salu ArcEye
I do not fully understand:
I call the terminal from the same logged in session, so why should I give additional user etc.
Is your --- xauth style auth via a window manager --- something oter then the build-in terminal window I aways use?
I kow I'm not an linux guru, so please excuse If my questions are too basic....
Mike
Mike
21 Jun 2011 08:41 #10692
by ArcEye
Sorry
You need to follow the link I sent you and work through it, google any bits you don't understand.
I am not saying you need to log in as another user, rather that there is something wrong with the log in you are using
As a quick check to confirm this is the problem, run 'xhost' from the commandline
If you don't get 'access control enabled, only authorized clients can connect' this is the problem you have.
wiki.tcl.tk/1831 covers that problem in detail
22 Jun 2011 11:07 #10758
by ArcEye
See also this thread
www.linuxcnc.org/component/option,com_ku.../lang,english/#10757
You might want to try what I suggested to plasdom and run as root to sort out whether it is down to your user permissions.
You still need to secure your xserver, but that is a separate issue.
