smi_module compilation problem
04 May 2011 19:57 #9604 by tony
Hello,
I am trying to disable the smi on my computer and I got an error when I follow the wiki SMIfix page.
In fact, I have chosen to use the little makefile to compile smi_module.ko but it cannot find the rtai_wrapper.h file which is situated in the include diretory. I am not friendly with "make modules" but even if i add the exact path on INCLUDE variable, it doesn't work.
This is the exact message error :
antoine@pc-desktop:/usr/src/modules/rtai-3.8.1/base/arch/i386/calibration$ sudo make all
[sudo] password for antoine:
make -C /lib/modules/2.6.32-122-rtai/build -I/usr/include/asm/mach-default/ SUBDIRS=/usr/src/modules/rtai-3.8.1/base/arch/i386/calibration modules
make[1]: entrant dans le répertoire « /usr/src/linux-headers-2.6.32-122-rtai »
CC [M] /usr/src/modules/rtai-3.8.1/base/arch/i386/calibration/smi-module.o
/usr/src/modules/rtai-3.8.1/base/arch/i386/calibration/smi-module.c:32:27: error: rtai_wrappers.h: Aucun fichier ou dossier de ce type
/usr/src/modules/rtai-3.8.1/base/arch/i386/calibration/smi-module.c:142: error: expected ‘)’ before ‘ulong’
make[2]: *** [/usr/src/modules/rtai-3.8.1/base/arch/i386/calibration/smi-module.o] Erreur 1
make[1]: *** [_module_/usr/src/modules/rtai-3.8.1/base/arch/i386/calibration] Erreur 2
make[1]: quittant le répertoire « /usr/src/linux-headers-2.6.32-122-rtai »
make: *** [all] Erreur 2
Could you help me on this point ?
Thank you !
05 May 2011 20:06 - 05 May 2011 20:37 #9612 by tony
Anyone ?
Ok, so if I want to compile entirely rtai with SMI disabled. Which version of it I need to download ? I am using EMC from the liveCD install ( v10.04 )
I am very surprised because when I get the last version of rtai (3.8 ), I don't find the HAL patch for my kernel ( 2.6.32 ). Do you know which combination ( linux - rtai version ) I need to use ?
Thank you !
Last edit: 05 May 2011 20:37 by tony.
05 May 2011 20:58 #9615 by BigJohnT
You might search the wiki site for non-standard installs and post on the mailing list for greater coverage. I think EMC is compiled for a specific version of RTAI and changing that might be a problem.
08 May 2011 16:08 #9659 by tony
If I have this message in my dmesg, does it mean that SMI is already disabled ?
[ 1312.575077] SMI configuration has been reset, saved mask used = 1.
[ 1319.369192] RTAI: Intel chipset found, enabling SMI workaround.
[ 1319.369209] SMI configuration has been cleared, mask used = 1 (saved mask setting 1).
Some time later, I have :
[ 1321.354697] RTAPI: ERROR: Unexpected realtime delay on task 1
[ 1321.354703] This Message will only display once per session.
[ 1321.354705] Run the Latency Test and resolve before continuing.
[ 1321.355357] 1580: ERROR: Unexpected realtime delay: check dmesg for details.
[ 1321.355368]
[ 1321.355370] In recent history there were
[ 1321.355373] 2997675, 3023565, 2974980, 3021435, and 3000683
[ 1321.355376] elapsed clocks between calls to the motion controller.
[ 1321.355398] This time, there were 3603007 which is so anomalously
[ 1321.355403] large that it probably signifies a problem with your
[ 1321.355407] realtime configuration. For the rest of this run of
[ 1321.355411] EMC, this message will be suppressed.
Does it mean that i have a big latency problem ?
08 May 2011 17:02 #9660 by BigJohnT
Yes, that does mean you have a latency problem.
I'm not familiar with SMI so I don't know what that means.
08 May 2011 18:25 #9661 by tony
Okay,
Does anyone could explain how to disable SMI on the last EMC liveCD version ( Lynx ).
With the Makefile given on the wiki, I got the error described below.
When I try to compile all the rtai sources, I got a compatibility problem when I apply the HAL patch on the kernel.
I have also tried a little software called smictrl ( www.rts.uni-hannover.de/rtaddon/ ) which I succeeded to compile. But I don't know which value I need to apply to the SMI register and even if it is enough to reduce the periodic latency.
Plz, help me.
11 May 2011 16:35 #9725 by andypugh
Which page are you reading?
There is no need to compile anything to use the rtai_smi module.
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?FixingSMIIssues
All you need to do is edit two lines of rtapi.conf and restart EMC2.
However, it is entirely possible that your latency problem is not SMI related.
04 Aug 2011 18:43 #12189 by tony
So finally, if someone is interested in this topic. I have found the solution to my problem :
In fact rtai_smi.ko is already compiled in Ubuntu RTAI 10.04 and is situated in :
/usr/realtime-2.6.32-122-rtai/modules/rtai_smi.ko
So, you just have to execute : sudo insmod /usr/realtime-2.6.32-122-rtai/modules/rtai_smi.ko
In my case, it solved latency problem when no graphical task is running
Before : Max Jitter 1ms & 25us : about 100000us
After : Max Jitter 1ms : 5661 | 25us : 9813
When I run glxgear I come back to my old shitty results....Help me...
05 Aug 2011 09:59 #12209 by Rick G
Have you looked here...
wiki.linuxcnc.org/emcinfo.pl?TroubleShooting
If you have not already you may want to experiment with a different video driver.
Rick G
06 Aug 2011 18:56 #12257 by andypugh
There is an easier way, by editing the rtapi.conf file, as described in section 4 here:
wiki.linuxcnc.org/emcinfo.pl?FixingSMIIssues
It sounds like you have two problems, one related to SMI, one related to video.
It is probably worth trying software-only OpenGL, as described in the link posted by Rick.
Time to create page: 0.138 seconds
