5i25 - 7i76 support testers wanted
- gmouer
- Thank you received: 9
05 May 2012 21:11 #19864
by gmouer
Replied by gmouer on topic Re:5i25 - 7i76 support testers wanted
Wow, I now have a TB4 TB5 and TB6 showing !!!!!!!
Still no idea why the build downloaded but failed to install the newest vesion. It installed the one a few months old. Nothing I did, it is supposed to be a automated process.
Oh well, we got there anyway. It was just a bumpy road.
- Thank you received: 2164
05 May 2012 21:19 #19865
Replied by cmorley on topic Re:5i25 - 7i76 support testers wanted
Well great finally got it!
I pushed the fixes for spindle override just now so thanks for that!
05 May 2012 21:22 #19866
oh i bet it didn't work properly because it says:
sudo apt-get install emc2
it's not called ems2 anymore !
- gmouer
05 May 2012 21:26 - 05 May 2012 22:02 #19867
by gmouer
cmorley wrote:
AhHa Somebody did not update the buildbot instruction text on the webpage !!!
Now we know why my installed update was from january, that was the last one before the name change!!
People love to fun me! I am bruised but surviving LOL
Last edit: 05 May 2012 22:02 by gmouer.
- jblain
03 Jul 2012 02:17 #21507
by jblain
Replied by jblain on topic Re:5i25 - 7i76 support testers wanted
Hello there,
I have just installed my brand new mesa 5I25 - 7I76 combo in my 10.04 RT Ubuntu system. I have pointed synaptic at the build bot repository
deb buildbot.linuxcnc.org/ lucid master-rt
and made sure to get, as of today, the latest version (2.6-pre0-3092).
I have followed this procedure to get the 5i25 and 7i76 firwmare
www.linuxcnc.org/index.php/english/compo...mit=6&start=42#16133
And, for a reason that escapes me right now, PNCConf still refuses to give me 5I25 as a choice for the card. Anyone know what I am doing wrong ?
Regards
J Blain
Regards
J Blain
03 Jul 2012 02:52 #21509
use these files/procedures instead:
www.linuxcnc.org/index.php/english/compo...ew&catid=39&id=20043
- jblain
03 Jul 2012 12:25 #21521
by jblain
Thank you for the info,
I have made some progress, I followed the procedures you gave me. I still did not have a choice for 5I25 in PNCConf, I then realised that the folders I had copied into usr/share/doc and lib/firmware with sudo nautilus did not have the same user permissions as the ones already present. So i corrected that and now:
PNPConf gives a choice for 5I25. Please note that I have not yet connected my 7I76 board, I need to buy a cable for that today. So right now, when I select 5I25 in PNCConf I get to Mesa I/O setup screen but :
The 7I76 checkbox does not show up in the sanity check, checkbox window. The 7I33 checkbox is selected instead ?
Is that normal ? Should I configure only with the 7I76 physically connected ?
Regards
JBlain
Regards
JBlain
- BigJohnT
- Thank you received: 1176
03 Jul 2012 12:47 #21522
by BigJohnT
Replied by BigJohnT on topic Re:5i25 - 7i76 support testers wanted
Make sure the cable is marked IEEE1284 or it might not work.
- jblain
03 Jul 2012 22:36 #21533
by jblain
I have gotten my hand on an IEEE1284 certified cable. When I plug the 7I76 and start PnCConf as before, I am able to select the 5I25 card as the PCI card. PnCConf indicates that it is loaded with the 7I76 firmware (the two cards were ordered as a set from Mesa). But the sanity checkboxes on the right do not include the 7I76 ??
What sould I do from there ?
Regards
JBlain
Regards
JBlain
- jblain
04 Jul 2012 00:24 #21541
by jblain
A little more investigating and I found that the 5I25 was not configured to supply 5 volts to the 7I76 ??!!
So I fixed that and just went ahead and unchecked all the sanity checkboxes in PNCConf. Proceeded to the end and I now seem to have a configured mesa driven stepper machine.
At least I hope i do. Now for some more testing
Time to create page: 0.098 seconds
