Configuring 5i23 7i52 7i73
- gorjanc
24 Jan 2013 06:43 - 24 Jan 2013 06:55 #29046
by gorjanc
Replied by gorjanc on topic Configuring 5i23 7i52 7i73
Here is the changed XML,
I don't know what was exactly wrong (I made quite a few changes based on other xml files)
I didn't test the file yet, but in PncConf looks OK
The only problem I got into now is that SVSS6_6 doesn't have any PWM/ stepper signals
or I made something wrong.
Last edit: 24 Jan 2013 06:55 by gorjanc.
- Thank you received: 5280
24 Jan 2013 07:35 #29048
Replied by PCW on topic Configuring 5i23 7i52 7i73
That's correct the 7I52 has 6 serial channels and 6 encoder inputs
(no room for step/dir outputs unless you steal some serial xmit pins)
A 7I52S has 6 Step/dir (or PWM/DIR) outputs and 6 encoder inputs (and no serial)
Some people have modified 7I52S 's to get a mix of serial and step/dir outputs
- gorjanc
24 Jan 2013 07:57 #29049
by gorjanc
Will it be possible, to use P3 or P4 on 5i23 for PWM or stepper signals ?
I believe that step/dir will be just fine for Granite devices VSD-XE drivers
So is it possible to use the GPIO pin like on parallel port (I don't know where exactly the signals for motors are generated on PCI card or by linuxCNC)
24 Jan 2013 08:16 #29050
Yes this can be done
Normally the signals are generated by hardware on the PCI card
because if they are generated in software
you will have much lower PWM resolution
or much lower possible step rates
- gorjanc
24 Jan 2013 17:46 #29072
by gorjanc
Will it work if I modify PIN_SVSS6_6_72.VHD file by adding PWM/steppers to the Moduleid and define pins in PinDesc
and then compile.
Darko
and then compile.
Darko
24 Jan 2013 23:43 #29095
Basically yes (using source from mesanet.com)
If you are going to do this It would
probably be easier if I made a project file with the right options set
- gorjanc
25 Jan 2013 05:27 - 25 Jan 2013 05:28 #29106
by gorjanc
That will be weary nice from you
What I need is 5 stepper outputs step/dir (enable is not needed) 6 encoders and 1 serial port if possible, you can put all together on P2 or put stepper signals on some other port.
Last edit: 25 Jan 2013 05:28 by gorjanc.
- gorjanc
25 Jan 2013 05:37 #29107
by gorjanc
I looked in manuals for 7i52 card and I think it cant be used for steper outputs, so put them on P3 or P4.
29 Jan 2013 06:09 #29244
freeby.mesanet.com/SVSSST6_6_12.ZIP has bit,pin, and .xml files
This configuration adds 12 stepgenerators on P3
- Thank you received: 2162
29 Jan 2013 06:13 #29245
Replied by cmorley on topic Configuring 5i23 7i52 7i73
Peter your XML files will absolutely not work as is.
They won't even display in a browser because of the leading blank line.
I could work with you for the changes if you are interested. I'm not sure how much work it will be.
What are you using to create the files?
Chris M
Chris M
