mesa 5i25 7i76
- jd896
20 Jul 2013 22:12 #36829
by jd896
Replied by jd896 on topic mesa 5i25 7i76
right ive reinstalled ubuntu with the latest iso from this site and loaded via usb stick install
updated via update manager and it now runs lcnc version 2.5.2 all seams okay
pnc will still not work with that same error
updated with the script and had the same folders created for me and the files are there and have root permissions
the files are in lib/firmware/hm2/5i25
and usr/share/docs/hostmot2-firmware-5i25
not sure if its related ran pnc from terminal and got this
root@jnfabs-cnc-beam-punch:~# pncconf
/usr/bin/pncconf:4080: Warning: g_path_get_dirname: assertion `file_name != NULL' failed
self.xml = gtk.glade.xml_new_from_buffer(doc, len(doc), domain="linuxcnc")
/usr/bin/pncconf:4080: GtkWarning: gdk_pixbuf_new_from_file: assertion `filename != NULL' failed
/usr/bin/pncconf:4080: Warning: g_object_unref: assertion `G_IS_OBJECT (object)' failed
debug None
many thanks john
debug None
many thanks john
- Thank you received: 2164
21 Jul 2013 02:21 #36841
Replied by cmorley on topic mesa 5i25 7i76
Thanks normal warnings, though thanks for thinking of posting it.
You really have me stumped.
one more thing to try:
open a terminal enter 'sudo nautilus'
It'll ask for your password.
now using that sudo file browser find and open /usr/bin/pncconf
find the line:
_DEBUGSTRING = ["NONE"]
should be 21
change it to:
_DEBUGSTRING = ["all"]
close the file browser and gedit
now run pncconf from the terminal
you should get more text on the terminal when you switch to the page that you get an error from.
post that text somewhere like pastebin and add a link here.
or give up on pncconf and modify a sample config to get your machine running.
I hope you don't cause I want to know whats going on...
Chris M
find the line:
should be 21
change it to:
Chris M
- jd896
23 Jul 2013 01:02 #36898
by jd896
ive partialy made a pnc generted config on another machine but ill try and help you get to the bottom of this
- jd896
23 Jul 2013 01:03 #36900
by jd896
i have just gotten the following
jnfabs@jnfabs-cnc-beam-punch:~$ sudo -i
[sudo] password for jnfabs:
debug None
Board and firmwarename: 5i25 prob_rfx2
secondary modulename: ???, None.
- jd896
23 Jul 2013 01:36 #36905
by jd896
i also get this message on a window popup
tho i have seen this before as a python error possibly just something that springs to mind might be nothing
File "/usr/bin/pncconf", line 5279, in on_mesa_boardname_changed
if "7i43" in d[_BOARDNAME] :
UnboundLocalError: local variable 'd' referenced before assignment
it the 'd' referenced before assignment i think ive seen somewhere
23 Jul 2013 13:37 #36929
Thanks you.
This seems to indicate that it found the hm2/5i25 folder, but it should have opened the prob_rfx2 last.
And it should have a lot more text after that as it parses the prob_rfx2 firmware.
- jd896
24 Jul 2013 03:13 #36955
by jd896
ive changed the debug line and it still shows debug = none at the end of loading pncconf
i also tried ALL instead of all and also PRINT
but all with the same output to terminal would you rather have ssh access ? or teamviewer ?
and have a look your self whats going on if that would help
24 Jul 2013 09:12 #36961
The output was consistent with 'all' setting.
It still seems to point to a problem with the XML file -but I don't know what.
While that would probably speed things up - I have never done either...
Chris M
Chris M
Time to create page: 0.247 seconds
