- Thank you received: 167
Is this because it is spinning too fast? If the motor isn't under load (ie isn't connected to the machine) it is possible that things will work better then. (If it's a spindle, then this won't help)
You could try running the servo thread faster, if the machine can handle it,
PCW wrote: Yes, as a torque mode drive you need to have some kind of speed control implemented
PCW wrote: In any case you will need speed feedback, sure how that will work with just hall effect
sensors
sensors
It would probably work quite well if the bldc component had a velocity output. But that is something I forgot to add.
A ddt on the angle data ought to work, except that it wraps every rev.
So probably a little hal component would be needed
