4i69 XML file
17 Jan 2014 06:35 #42894 by heathmanc
4i69 XML file was created by heathmanc
What are the chances of getting an XML file for a 4i69 using a 7i48 on P1? I am using 2.5.3.
Charles
17 Jan 2014 08:30 #42898 by PCW
Replied by PCW on topic 4i69 XML file
xml and pin files fo 4i69-25 svst6_6 7I48 config
17 Jan 2014 14:45 #42905 by heathmanc
Replied by heathmanc on topic 4i69 XML file
I receive this error in pncconf with that xml file
File "/usr/bin/pncconf", line 5506, in on_mesa_component_value_changed
self.set_mesa_options(boardnum,title,firmware,numofpwmgens,numoftppwmgens,numofstepgens,numofencoders,numofsserialports,numofsserialchannels)
File "/usr/bin/pncconf", line 5605, in set_mesa_options
self.widgets[ptype].handler_block(self.data[ptypeblocksignal])
File "/usr/bin/pncconf", line 667, in __getitem__
if r is None: raise IndexError, "No widget %r" % attr
IndexError: No widget 'mesa0c1pin0type'
17 Jan 2014 17:29 #42909 by heathmanc
Also curious, in the pncconf file, the 4i65 has been blacklisted? Is this card not an option to use with pncconf?
17 Jan 2014 23:04 #42924 by PCW
Not sure if its the cause of the pncconf error but
I did see an error in the XML file on GPIO only pins.
I will fix this and post a new one later today
18 Jan 2014 07:05 #42949 by PCW
This matches the 5i25 and other working xml files as close as I can
If this does not work you probably need cmorely's help
18 Jan 2014 12:11 #42956 by cmorley
Replied by cmorley on topic 4i69 XML file
the 4i69 is not supported in pncconf.
You are the first to ask about it.
Sorry
Chris M
18 Jan 2014 13:47 #42957 by PCW
I guess if any 7i48 config is supported (say a 5I20 one) , you could make a hal file with pncconf
and then just globally replace 5I20 with 4I69 in the hal/ini files and it should be fine
19 Jan 2014 05:47 #43000 by cmorley
oh well if it's that easy - I should just add it to pncconf...cool.
Chris M
19 Jan 2014 06:19 #43002 by heathmanc
That's exactly what I did, took my hal from my 5i20 and changed it all to 4i69 and went to town, had to make no changes and the machine worked. Thanks for all of your help guys.
Charles
Time to create page: 0.081 seconds
