4i69 XML file
- Thank you received: 2164
20 Jan 2014 05:22 #43018
Replied by cmorley on topic 4i69 XML file
excellent - I will look at adding it then.
Chris M
Chris M
- heathmanc
23 Jan 2014 05:32 - 23 Jan 2014 05:33 #43093
by heathmanc
Replied by heathmanc on topic 4i69 XML file
Now, what about support for the 4i65? I could use a xml and bit file for a 7i48 for it also. To many machines in the works.
Last edit: 23 Jan 2014 05:33 by heathmanc.
26 Jan 2014 09:52 #43176
I'll assume the 4i65 is also just a name change...
It's a little more work then that for pncconf because pncconf has no connector 1 data so I need to add that - which is a pain on the current version.
I'm in the middle of a new version - so it's gonna be a while...
Chris M
Chris M
- heathmanc
26 Jan 2014 21:39 #43197
by heathmanc
Already got it figured out, just took the 5i20 xml, made a bit for the 7i48 and 4i65. One issue though is, can't put it in the 4i65 folder as it's been blacklisted by pncconf. But in the pncconf file, I just replaced all instances of 5i20 with 4i65 and it worked beautifully.
Time to create page: 0.052 seconds
