4i69 XML file
- heathmanc
17 Jan 2014 06:35 #42894
by heathmanc
4i69 XML file was created by heathmanc
What are the chances of getting an XML file for a 4i69 using a 7i48 on P1? I am using 2.5.3.
Charles
Charles
- Online
- Thank you received: 5283
17 Jan 2014 08:30 #42898
Replied by PCW on topic 4i69 XML file
xml and pin files fo 4i69-25 svst6_6 7I48 config
- heathmanc
17 Jan 2014 14:45 #42905
by heathmanc
Replied by heathmanc on topic 4i69 XML file
I receive this error in pncconf with that xml file
File "/usr/bin/pncconf", line 5506, in on_mesa_component_value_changed
self.set_mesa_options(boardnum,title,firmware,numofpwmgens,numoftppwmgens,numofstepgens,numofencoders,numofsserialports,numofsserialchannels)
File "/usr/bin/pncconf", line 5605, in set_mesa_options
self.widgets[ptype].handler_block(self.data[ptypeblocksignal])
File "/usr/bin/pncconf", line 667, in __getitem__
if r is None: raise IndexError, "No widget %r" % attr
IndexError: No widget 'mesa0c1pin0type'
- heathmanc
17 Jan 2014 17:29 #42909
by heathmanc
Also curious, in the pncconf file, the 4i65 has been blacklisted? Is this card not an option to use with pncconf?
- Online
17 Jan 2014 23:04 #42924
Not sure if its the cause of the pncconf error but
I did see an error in the XML file on GPIO only pins.
I will fix this and post a new one later today
- Online
18 Jan 2014 07:05 #42949
This matches the 5i25 and other working xml files as close as I can
If this does not work you probably need cmorely's help
- Thank you received: 2164
18 Jan 2014 12:11 #42956
Replied by cmorley on topic 4i69 XML file
the 4i69 is not supported in pncconf.
You are the first to ask about it.
Sorry
Chris M
Sorry
Chris M
- Online
18 Jan 2014 13:47 #42957
I guess if any 7i48 config is supported (say a 5I20 one) , you could make a hal file with pncconf
and then just globally replace 5I20 with 4I69 in the hal/ini files and it should be fine
19 Jan 2014 05:47 #43000
oh well if it's that easy - I should just add it to pncconf...cool.
Chris M
Chris M
- heathmanc
19 Jan 2014 06:19 #43002
by heathmanc
That's exactly what I did, took my hal from my 5i20 and changed it all to 4i69 and went to town, had to make no changes and the machine worked. Thanks for all of your help guys.
Charles
Charles
Time to create page: 0.181 seconds
