LinuxCNC not starting
29 Mar 2014 04:54 #45352 by Jerre122
Replied by Jerre122 on topic LinuxCNC not starting
Voltage seemed ok. I got 3.36V when measuring. This was disconnected from the USB port ( this goes to a hub wich powers the touch pad and keyboard) the screen was not connected either.
The power supply was only 240W.
I am now using another PC (pentium 4). Everything is working fine for now. Latency is a bit higher then I would like (around 50000, with onboard video card) but no realtime errors for now.
The only problem with the new PC is that it freezes when trying to shutdown.
29 Mar 2014 05:29 #45355 by andypugh
Replied by andypugh on topic LinuxCNC not starting
That's a "feature" :-)
The RTAI kernel that you are probably using disables power management to get better latency, so you need to shut down manually.
04 Apr 2014 01:24 - 04 Apr 2014 01:26 #45547 by emcPT
Replied by emcPT on topic LinuxCNC not starting
EDIT : Forget my post, I only read the first page ....
Jerre122,
Can you please give some feedback about your error?
It is good to know what was the solution/problem.
Thank you
Last edit: 04 Apr 2014 01:26 by emcPT.
