xml files 5i24
- vre
- Thank you received: 19
05 Jan 2015 17:25 #54566
by vre
xml files 5i24 was created by vre
is there any pcnconf xml file for 5i24 ?
- Thank you received: 5210
05 Jan 2015 23:36 #54585
Replied by PCW on topic xml files 5i24
one option is to make a config for a 5i23 and then globally replace "5i23" with "5i24" in the hal file
another option is to do the same with a 5i23 xml file
you still need to manually remove the firmware=blahblahblah stanza from the
loadrt hm2_pci line and the 50 pin connector numbering will not match
Rumor has it that the next version of mesaflash will have an option to make XML files
- vre
02 May 2015 00:55 #58303
by vre
Replied by vre on topic xml files 5i24
Any update?
02 May 2015 06:58 #58310
Not yet but if you have the bitfile name, I can make a .xml file for the with READHMID
- vre
02 May 2015 17:22 - 02 May 2015 17:33 #58315
by vre
i have a bit file how i can make an xml with READHMID?
What is READHMID ?
What is READHMID ?
Last edit: 02 May 2015 17:33 by vre.
02 May 2015 23:03 #58328
Actually the latest version of mesaflash _does_ make xml files
The command line would be something like:
sudo mesaflash --device 5i24 --readhmid --xml > somefilename.xml
The following user(s) said Thank You: vre
- vre
03 May 2015 05:25 - 03 May 2015 05:56 #58341
by vre
I have mesaflash 3.1 but does not have option --xml outputs only PIN files .
What version has --xml option ?
Is there any newer version that supports xml output ?
Can i make xml for PIN file ?
Last edit: 03 May 2015 05:56 by vre.
- Thank you received: 2159
03 May 2015 06:40 #58342
Replied by cmorley on topic xml files 5i24
pncconf knows nothing about the 5i24 so you will still need to fake things.
I would be happy but surprised if the mesaflash XMLs work perfectly with pncconf.
There have been two sources of XMLs to date and each are a little different.
I have done work on pncconf that reads a live system and in principle it works.
How to make it easy to use in the interface is proving a bit harder.
That and I guess my interest has waned a bit
Chris M
Chris M
- vre
03 May 2015 08:07 - 04 May 2015 06:13 #58344
by vre
I need an xml file for 5i24 svst2_8 for example..
I think the only solution is manual creating configs.
Last edit: 04 May 2015 06:13 by vre.
- vre
12 May 2015 02:06 - 12 May 2015 02:17 #58571
by vre
In bitfiles for 5i23 and 5i24 the pins are the same for example if i get the svst4_8 xml from 5i23 and replace the 5i23 with 5i24 will work ?
Can anyone modify for me the svst4_8 xml for 5i23 to work with svst_4_8 5i24 bitfile ?
Last edit: 12 May 2015 02:17 by vre.
Time to create page: 0.187 seconds
