xml files 5i24
12 May 2015 04:13 #58576 by PCW
Replied by PCW on topic xml files 5i24
a global replacement of 5i23 with 5i24 should work though the connector names may not match
Since pncconf doesn't know about the 5I24, at the minimum, you will need to edit the hal file to
remove the firmware token from the driver command line
12 May 2015 06:35 - 12 May 2015 06:42 #58580 by vre
Replied by vre on topic xml files 5i24
does not work. I have linuxcnc 2.7.
I need a working SVST4_8 xml without daughter cards.
Why hostmot2-firmware-5i24 package does not exist ?
it shows a pop up and i can not continue
You forgot to designate a stepper or pwm signal for axis x
You forgot to designate a stepper or pwm signal for axis y
You forgot to designate a stepper or pwm signal for axis z
Last edit: 12 May 2015 06:42 by vre.
12 May 2015 07:37 #58582 by PCW
start pncconf
configure what you want for a 5I20 SVST4_8
exit pncconf
edit hal file and replace all "5i20" with "5I24"
delete firmware token from loadrt hm2_pci line
done
The following user(s) said Thank You: vre
Time to create page: 0.172 seconds
