Can't configure Mesa 7i92
05 Mar 2018 22:27 #106992
Replied by andypugh on topic Add board and firmware
I think that you might have to set up a config with something "a bit like" the 7i92 and then hand-edit the HAL file to suit.
It's not all that hard. I think you can typically just change the card name in the [HOSTMOT2] section of the generated INI file.
- smplc
06 Mar 2018 11:48 #107025
by smplc
Replied by smplc on topic Add board and firmware
I suppose I'd try your first statement to start and similar following.
Configuring LinuxCNC> PncConf Wizard>Mesa 7i92 support (page 2)
Page 1 and #88723
PnCConf Wizard, Mesa Card 0, borrow 5i25, complete navigation, if develop 5i25 HAL file and make necessary edits.
Not sure which firmware to use. I could compare populated menu firmware, reference hostmot2 and .pin files and whichever resemble C11G.
Yet, I don't know if this would populate in menu of Mesa Card 0 and PnCConfg afterward.
Adequate if software corresponds to my hardware meantime.
Add'l
/usr/lib/python2.7/dist-packages/pncconf
/usr/share/linuxcnc/pncconf/pnconf-help
Page 1 and #88723
Add'l
- aleksamc
- Thank you received: 67
08 Mar 2018 08:19 #107101
by aleksamc
Replied by aleksamc on topic Add board and firmware
You may look my tread about 7i92m configuration.
forum.linuxcnc.org/39-pncconf/33991-configuration-7i92m-7i76x1d
They are similar.
They are similar.
Time to create page: 0.103 seconds
