Can't configure Mesa 7i92
- dannym
11 years 3 weeks ago #63532
by dannym
Replied by dannym on topic Can't configure Mesa 7i92
Well if it's anything like the Mach3 Smoothstepper, machine performance usually isn't even relevant. And they do tend to run smoother and more torque due to dead-on accurate step timing.
I like the 7i92 because I'm only running an Ethernet connection to the computer, not a thick, length-limited parallel cable. And a laptop is just as good (5i25 requires a PCI slot). You could probably run it off a Raspberry Pi if you thought you had a reason.
Yep, 7i92 is a bit "bleeding edge" but I got the hang of it. Basic movement is all there. I'm still stuck on how to link 2x gantry axes and the Modbus and wireless MPG link- but those have nothing to do with the 7i92 setup.
- skunkworks
- Thank you received: 153
11 years 3 weeks ago #63539
by skunkworks
Replied by skunkworks on topic Can't configure Mesa 7i92
Smoothstepper is a buffered motion controller. The computer doesn't have to be realtime to run it.
Linuxcnc needs a realtime connection between the computer and hardware. The external interface hardware like mesa moves the stuff computers don't do well - high speed stepgen, pwmgen, encoder counting and such. You then don't need a base thread - only a servo thread. So 1 to 5khz or so. Latencies can be higher - approaching 100us or more. (mesa has some cool DPLL magic to make jitter have less effect)
sam
sam
- LS
11 years 3 weeks ago #63560
by LS
Replied by LS on topic Can't configure Mesa 7i92
Thank you for the clarification. I might go for the 7i92, connected to my existing (parallel port) Controller.
- LS
11 years 3 weeks ago #63594
by LS
Any thoughts on which .bit should I use for a generic (chinese Yoocnc 3040) controller?
Thanks.
Thanks.
- Thank you received: 5334
11 years 3 weeks ago #63596
Replied by PCW on topic Can't configure Mesa 7i92
Best thing is to compare your existing pinout (step and dir mainly) with available bit file pinouts
BTW here is a reversed (IO connectors swapped) G540 config for the 7I92
freeby.mesanet.com/7i92_g540x2RD.bit
- smplc
8 years 7 months ago - 8 years 7 months ago #106884
by smplc
Replied by smplc on topic Add board and firmware
Debian 9 (Stretch)
Mesa 7i92M FPGA
Download 7i92 firmware from Mesa Elect.
Write /hostmot2/7i92_C11Gx2D.bit
mesaflash --device 7i92 --addr 10.10.10.10 --readhmid
Verified write, ports and pins.
Desktop menu>Applications>CNC>Pncconf Wizard
Page 5 at Mesa Card 0. Configuration Page doesn't have a default 7i92 board and C11Gx2D firmware in populated menu.
freeby.mesanet.com/7i92step.zip
Extracted 7i92step.zip
Placed 7i92.ini and hm2-pidstepper.hal at /home/shawn/linuxcnc/configs
Desktop menu>CNC>LinuxCNC>LinuxCNC Cofiguration Selector Current: 7i92.ini
My Configurations (tree) 7i92 No details available.
Double left click mouse opens AXIS.
Revert Pncconf Wizard and page 5. How does 7i92 board and C11Gx2D firmare get in populated menu? That to configure ports and pins, accept component changes and proceed Wizard.
Mesa 7i92M FPGA
Last edit: 8 years 7 months ago by smplc. Reason: 9i92 to 7i92
Time to create page: 0.614 seconds
