Can't configure Mesa 7i92
- dannym
11 years 1 month ago #63109
by dannym
Replied by dannym on topic Can't configure Mesa 7i92
Where did you get your 7i92_G540x2D.bit from?
- Thank you received: 5334
11 years 1 month ago #63110
Replied by PCW on topic Can't configure Mesa 7i92
7i92.zip from mesa
- dannym
11 years 1 month ago - 11 years 1 month ago #63176
by dannym
OK do me a solid and type "mesaflash --device 7i92 --verbose" and quote what it returns to you.
What position do the W5/W6 jumpers need to be in for this?
Last edit: 11 years 1 month ago by dannym.
11 years 1 month ago - 11 years 1 month ago #63213
This is not bit file related, I suspect you are not running the latest mesaflash
If you compiled mesaflash from source did you do a:
after make?
The linuxcnc repository has been updated with the latest mesaflash as well
so
sudo apt-get update
sudo apt-get install mesaflash
should work also
sudo make install
so
sudo apt-get update
should work also
Last edit: 11 years 1 month ago by PCW.
- dannym
11 years 1 month ago #63222
by dannym
I did exactly as stated on the GitHub site:
Would that still be a problem?
In the source directory, install dependency and build:
sudo apt-get install libpci-dev
make
- dannym
11 years 1 month ago #63322
by dannym
OK, I did that and Mesaflash works, ip=10.10.10.10!
Now when running with that 7i92.hal, I get:
./hm2-pidstepper.hal:42: Can't find module 'hm2_eth' in /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
5124
I added "loadrt hm2_eth board_ip=10.10.10.10", no difference.
5124
Time to create page: 2.531 seconds
