Hakan wrote: But where will you calculate the motor rpms for the different gears?.
The component I wrote did this. But I see that you seem to have abandoned my version about 40 posts ago.
Hakan wrote: I think the intention was to merge your version with another version.
The speed_out pin was lost in that process.
Bengt, you need to
1. Add the speed_out pin in the gearcomp3 componentCode:pin out float speed_out "Motor speed needed";
2. In the "if" statement at the end, add at the endwhen the right gear is engaged, andCode:speed_out = speed/speedratio;when the wrong gear is engaged.Code:speed_out = 0.0;
3. halcompile and resinstall component
4. Change the hal file toCode:net spindlespeed <= gearcomp3.0.speed_out => hm2_7i76e.0.7i76.0.0.spinout
Bengt, you need to
]net spindlespeed <= gearcomp3.0.speed-out => hm2_7i76e.0.7i76.0.0.spinout[
PROGRESS
I think there is something wrong with speedratio that is shown as 0.18 and should be just about 1.0 or a bit less.
Some tweaking but what to change?
