This compiles, but I would like to know what following lines actually does (as I think it is wrong).
pin in float gear.#.ratio[12];
motor_speed_out = spindle_speed_in * gear_ratio(gear);
As the spindle should go max at HI/LO motorspeed on each gear max and only adjust to min speed of that gear via VFD.
component GB_2speed;
pin in bit spindle-enable-in;
pin out bit spindle-enable-out;
pin in float spindle-speed-in;
pin out float motor-speed-out;
pin in float gear.#.min-speed[12];
pin in float gear.#.max-speed[12];
pin in bit high-gear;
pin in bit gear-AH;
pin in bit gear-BH;
pin in bit gear-B;
pin in bit gear-C;
pin in bit gear-D;
pin in bit gear-E;
license "gpl";
function _;
FUNCTION(_){
int gear;
if (spindle_speed_in == 0) return;
switch (gear_AH + gear_BH * 2 + gear_B * 4 + gear_C * 8 + gear_D * 16 + gear_E *32) {
case 1: // Gear AH
gear = (high_gear != 0) ? 1 : 7;
break;
case 2: // Gear BH
gear = (high_gear != 0) ? 2 : 8;
break;
case 3: // Gear B
gear = (high_gear != 0) ? 3 : 9;
break;
case 4: // Gear C
gear = (high_gear != 0) ? 4 : 10;
break;
case 5: // Gear D
gear = (high_gear != 0) ? 5 : 11;
break;
case 6: // Gear E
gear = (high_gear != 0) ? 6 : 12;
break;
default: // gear selection is bitmasked to be able to spot double-engagement
gear = 0;
if (gear >= 0 && spindle_speed_in >= gear_min_speed(gear) && spindle_speed_in <= gear_max_speed(gear)) {
spindle_enable_out = spindle_enable_in;
} else {
motor_speed_out = 0;
spindle_enable_out = 0;
