Help needed to get my 7i76E + 7i85S + 7i73 on my mill going.
andypugh wrote: This adds an extra output that can be used with the message HAL component to say which gear should be selected. (using bitslice to convert the int to individual bits)
Actually, requiring bitslice is laziness on my part.
Will have a look tomorrow and see if I can grasp this code, thanks Andy.
Already spotted one error i have a comma where a semicolon belongs
for (i = 0; spindle_speed_in > speeds && i < 14; i++);
andypugh wrote: Again, done at work in Windows, so no guarantees of any sort.
Is above OK?
bengt@debian:~/linuxcnc$ sudo halcompile --compile GB_2speed.comp
[sudo] password for bengt:
GB_2speed.comp:17:25: Array name contains no #: 'message'
> pin out bit message[14];
Where in the compfile should a message be written and how?
tecno wrote: GB_2speed.comp:17:25: Array name contains no #: 'message'
That needs to be
pin out bit message-##[14]
"message" is an existing and separate HAL component.Where in the compfile should a message be written and how?
