5i25 configuration with only a G540, no daughterboards
8 years 9 months ago #104532 by PCW
I would use at least 5000 for all times to start
The following user(s) said Thank You: mpicco
8 years 9 months ago #104534 by mpicco
That seems to have helped a bit. It's far less likely to not change direction, however, it still drops the change every so often. Might an even larger number help that?
8 years 9 months ago #104535 by PCW
Might also be the step polarity
In general large values for the direction setup and hold times are
not harmful since direction is only changed at close to 0 velocity
8 years 9 months ago #104686 by mpicco
I gave the direction signals a polarity change, without any improvement. As I use the 'tune' facility and jog an axis in each direction, there appears to be a hesitation (sounds like a bit of grumbling!) prior to an attempted change in direction by the motor. The actual direction isn't always changing ... perhaps 50% of the time.
8 years 9 months ago #104688 by PCW
might be a pncconf issue, I would try LinuxCNC
8 years 8 months ago #105488 by syntetyczny
I understand connection between stepgen and nb. of chanel. What about inputs like E-Stop, and Limits. Are they also connected to specific channel or is it IO port nb in PnCConf?
Time to create page: 0.367 seconds
