Just a refresher: I have a 3-Axis/4-motor spindle driven machine running Machinekit. Until today, I was not able to run pncconf to generate at least a starting point for my XML and HAL setup.
In order to see the 5i25 as an option (versus the '5i25-Internal Data'), I created /lib/firmware/hm2/5i25 and copied 5i25_g540x2.xml into it. Lo and Behold! When I attempted to run pncconf, I was now able to select "5i25" as a board.
I forged onward using the data that I've found here and in one or two other sources. Of note:
On the Basic Hardware page: Servo Period as Default (100K), Axis Config: XYZA, Units: mm, Mesa0 = 5i25, Selected First Paraport Address as the default (0x278, OUT), and AXIS as the GUI[/li]
External Controls: Selected "External Button Jogging" and set speed to 100 mm/min. Is this acceptable?
GUI Config Page: Selected "Move Spindle Up..."
Mesa I/O Config Page: Tab 1:
1. Firmware: 5i25_g540x2
2. Unchecked: 7i33 Daughter Board
3. Set:
1. PWM = 20,000
2. PDM = 6, 000,000[
3. Watchdog = 10,000,000 ( From:
linuxcnc.org/docs/html/config/pncconf.html#_mesa_i_o_setup
4. Encoders = 2
5. PWM Generators = 2
6. Step Generators = 10
7. Pins = 34
That's when the wheels fell off, the tranny dropped out, and threw a rod through the block.
As was suggested: I set the Unused StepGen 0 to "X Axis StepGen", followd by StepGen 1 = "Y Axis StepGen", StepGen2 = "Z Axis StepGen", and then, because I didn't know what else to do, I set Unused StepGen 3 to "Y Axis StepGen" and selected the "INV" box, When I attempted to move forward, I was greeted with, "You forgot to designate a stepper or PWM signal for axis a".
Any help on where to go from here, including anything that I need to change, would be greatly appreciated.
Thank you in advance for your time and help.
Leonard
