cnc@CNCMILL:~$ dmesg
[ 265.087381] I-pipe: head domain RTAI registered.
[ 265.087387] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 265.087426] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 265.087429] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12467820, CLK_FREQ 2393909000, CPU_FREQ 2393909000
[ 265.087432] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 265.087435] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12467820, 12467820, 10591250
[ 265.105746] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 265.105793] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 265.105798] RTAI[sched]: hard timer type/freq = APIC/12467820(Hz); default timing: oneshot; linear timed lists.
[ 265.105801] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393909000 hz.
[ 265.105804] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 265.121707] RTAI[math]: loaded.
[ 280.420366] hm2: loading Mesa HostMot2 driver version 0.15
[ 298.531635] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 298.531683] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 298.534215] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 298.590659] Board hm2_5i25.0.7i73.0.1 Hardware Mode 0 = nokeyboardnodisplay
[ 298.592245] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoder
[ 298.594157] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalog
[ 298.596093] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalog
[ 298.597599] Board hm2_5i25.0.7i73.0.1 Hardware Mode 1 = nokeyboarddisplay
[ 298.599570] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplay
[ 298.601930] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplay
[ 298.604521] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplay
[ 298.606266] Board hm2_5i25.0.7i73.0.1 Hardware Mode 2 = keyboard4by8nodisplay
[ 298.608498] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode4by8
[ 298.611078] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode4by8
[ 298.613666] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode4by8
[ 298.615280] Board hm2_5i25.0.7i73.0.1 Hardware Mode 3 = keyboard4by8display
[ 298.617929] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode4by8
[ 298.620938] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode4by8
[ 298.624187] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode4by8
[ 298.625920] Board hm2_5i25.0.7i73.0.1 Hardware Mode 4 = keyboard8by8nodisplay
[ 298.628152] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderkeycode8by8
[ 298.630732] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogkeycode8by8
[ 298.633309] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogkeycode8by8
[ 298.634922] Board hm2_5i25.0.7i73.0.1 Hardware Mode 5 = keyboard8by8display
[ 298.637583] Board hm2_5i25.0.7i73.0.1 Software Mode 0 = inputoutputencoderdisplaykeycode8by8
[ 298.640580] Board hm2_5i25.0.7i73.0.1 Software Mode 1 = inputoutputencoderanalogdisplaykeycode8by8
[ 298.643806] Board hm2_5i25.0.7i73.0.1 Software Mode 2 = inputoutputencoderanalogwidedisplaykeycode8by8
[ 298.760693] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 298.760698] hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
[ 298.760701] hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
[ 298.760704] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
[ 298.760706] hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
[ 298.760709] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
[ 298.760712] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
[ 298.760714] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
[ 298.760717] hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
[ 298.760720] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
[ 298.760723] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
[ 298.760725] hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
[ 298.760727] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 298.760730] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Smart Serial Interface #0, pin TxData1 (Output)
[ 298.760733] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Smart Serial Interface #0, pin RxData1 (Input)
[ 298.760736] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #0, pin Muxed Index (Input)
[ 298.760738] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #0, pin Muxed B (Input)
[ 298.760741] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #0, pin Muxed A (Input)
[ 298.760744] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 298.760746] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 298.760748] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 298.760750] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 298.760752] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 298.760754] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 298.760756] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 298.760758] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 298.760760] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 298.760762] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 298.760765] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder Select #2, pin Mux Select 0 (Output)
[ 298.760768] hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
[ 298.760770] hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
[ 298.760773] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 298.760776] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
[ 298.760778] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
[ 298.760781] hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 298.760875] hm2/hm2_5i25.0: registered
[ 298.760878] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 1005.398790] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 1005.398796] hm2/hm2_5i25.0: unregistered
[ 1005.398859] hm2_pci: driver unloaded
[ 1005.400828] hm2: unloading
[ 1005.450866] RTAI[math]: unloaded.
[ 1005.452939] SCHED releases registered named ALIEN PEDV$D
[ 1005.458863] RTAI[malloc]: unloaded.
[ 1005.556014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1005.557976] I-pipe: head domain RTAI unregistered.
[ 1005.558015] RTAI[hal]: unmounted.
cnc@CNCMILL:~$
