Mesa 7I76e + PTC TermoSensor
7 years 8 months ago #126443 by MarcoGaspar
Hello,
My spindle have a ptc termo sensor ....it's possible connect it to mesa 7i76e a show the value in axis?
If its possible to do it.... its possible to stop the machine if the temp rise up?
Best Regards,
Marco Gaspar
7 years 8 months ago #126456 by andypugh
The 7i76E can be configured to have 4 analogue inputs (8 bit resolution)
www.mesanet.com/pdf/parallel/7i76eman.pdf page 18
www.ni.com/white-paper/7112/en/
However be aware that the full-scale on the analogue inputs is quite high, so you might need an amplifier (simple op-amp circuit maybe)
An alternative might be to see if this
uk.rs-online.com/web/p/temperature-senso...ity-sensors/1659406/
works with this LinuxCNC driver:
linuxcnc.org/docs/devel/html/man/man9/max31855.9.html
If the data format is similar then the signal can be convered in HAL to read an actual temperature (the "lincurve" component would be handy for this)
7 years 8 months ago #126458 by andypugh
Here is another alternative:
www.petervis.com/GCSE_Design_and_Technol...with-thermistor.html
Wire that to a single-channel HAL encoder counter and use the velocity output as a measure of temperature.
7 years 8 months ago #126459 by PCW
Replied by PCW on topic Mesa 7I76e + PTC TermoSensor
Do you have the PTC specifications?
7 years 8 months ago #126460 by rodw
Replied by rodw on topic Mesa 7I76e + PTC TermoSensor
You can find little LM358 low signal amplifier modules on ebay if you need to use say 5 volts.. If you use 24 volts as a power source, this will give you about 60% of the 36 volt range of the input. I think you could use wcomp to trigger your over temp threshold
7 years 8 months ago #126463 by MarcoGaspar
PCW wrote: Do you have the PTC specifications?
No.. it's a renaud spindle only know that is a ptc sensor.
Time to create page: 0.523 seconds
