- Thank you received: 5334
Peterdeleu wrote: It all becomes clear to me
But still some questions..
I'll use Fusion as CAD/CAM.
After generating the G-code with the LinuxCNC postprocessor, I'm able to load the code into LinuxCNC.
Even tool changes are working.
These are the first lines of an example of the code generated by Fusion:
(1001)
(T11 D=10. CR=0. - ZMIN=-46. - FLAT END MILL)
(T12 D=2. CR=0. TAPER=118DEG - ZMIN=-6. - DRILL)
(T15 D=4. CR=0. TAPER=118DEG - ZMIN=-46. - DRILL)
N10 G90 G94 G17 G91.1
N15 G21
N20 G53 G0 Z0.
(2D POCKET10)
N25 M9
N30 T11 M6
N35 T12
N40 S9700 M3
N45 G54
N50 M8
N55 G0 X-2.216 Y175.52
At line N30 LinuxCNC stops and ask me to change the tool to 11.
But I have a Biesse with multiple heads. I know how to add tools and tool offsets in LinuxCNC, but how an I automize this ?
Each tool is fixed on the head. A specific pneumatic cilinder must be activated to push the tool down if in the G-code a tool change is asked. Because each tool is fixed on a different location, I will need to enter an offset. That that's more or less clear.
My question is, how can I activate the correct pneumatic cilinder without making changes in the G-code.
Greetz,
Peter
