Peterdeleu wrote: With Stepconf I see a smoot displacement of the tool.
And that is something I want to have solved
PCW wrote: Normally you should setup the 7I77 to use external 5V power (as suggested in the manual)
For external 7I77 5V power:
5I25 W2 DOWN
7I77 W5 RIGHT
5V power supplied to 7I77 TB1
Note that 5V encoders should work at 4.7V so I suspect you have some other issues
1. Are the encoder single ended or differential? (how many wires)
2. Are the 7I77 encoder inputs jumpered to match the encoder type?
