How to add a new Mesa card to pncconf?
7 years 2 days ago #149128 by cmorley
Ok do you know what firmware was uploaded to the card?
You can use mesaflash to find out if you don't know
7 years 2 days ago #149131 by terry1992
The firmware is SVST4_8.bit
I just flash it today.
7 years 2 days ago #149133 by cmorley
The 7i80HD card gets you the closest - It will need editing to work.
I would make a minimum config first to see what needs to be adjusted.
The following user(s) said Thank You: terry1992
7 years 2 days ago #149135 by cmorley
one line that will need to be changed is in the main HAL file:
it will look similar to this:
loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=8 num_pwmgens=8 num_stepgens=4" l
should be something like this (change to the actual parport address)
loadrt hm2_7i90 ioaddr=0
Chris
The following user(s) said Thank You: BigDo, terry1992
4 years 9 months ago #233353 by BigDo
i tried the discovery mode with my 7I98 and it worked perfectly.
Very usefull.
Niko
4 years 7 months ago - 4 years 7 months ago #237875 by garrettmin
I need to add the 7i88 to LinuxCNC 7i92.
7i88 isn't in the PNCConf for 7i92.
What do I need to do?
Last edit: 4 years 7 months ago by garrettmin.
Time to create page: 0.254 seconds
