PNCConf error when clicking Done
7 years 1 month ago #144405 by bevins
post what it says under Debug file information......
7 years 1 month ago #144412 by LuisGZ
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./7i76e.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./7i76e.hal:8: /usr/bin/rtapi_app exited without becoming ready
./7i76e.hal:8: insmod for hm2_eth failed, returned -1
2255
Stopping realtime threads
Unloading hal components
7 years 1 month ago #144416 by rodw
That sounds like the ip address is wrong on the 7i76e so its not being found.
I'm not sure if its still the case but if you wanted to use 10.10.10.10, you had to edit the generated hal file.
So make sure you can ping the 7i76e and open the hal file in a text editor. I use Geany. If the ip address does not agree, chenge it to what it really is.
The following user(s) said Thank You: LuisGZ
7 years 1 month ago - 7 years 1 month ago #144417 by bevins
Can you ping 10.10.10.10? Thats if you didnt change the ip on the 7i92. Also did you set static ip on linux box? something like 10.10.10.11?
Last edit: 7 years 1 month ago by bevins.
7 years 1 month ago #144423 by PCW
Like bevins suggests, It kind of sounds like the host network is
not setup properly: if the IP address is just wrong on either end you
should get something like:
Starting LinuxCNC...
Found file(REL): ./hm2-servo-7i97.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: 10.10.10.10: Could not retrieve mac address
./hm2-servo-7i97.hal:45: waitpid failed /home/pcw/linuxcnc-dev/bin/rtapi_app hm2_eth
./hm2-servo-7i97.hal:45: /home/pcw/linuxcnc-dev/bin/rtapi_app exited without becoming ready
./hm2-servo-7i97.hal:45: insmod for hm2_eth failed, returned -1
hm2: unloading
7 years 1 month ago #144427 by LuisGZ
You guys were right, I had some messed up config on my ethernet connection profile, I updated it to match the card and voila.
I just got the LinuxCNC program up and running on my steppers, thank you!
Time to create page: 0.380 seconds
