Spindle configuration for Mesa 5i25 + 7i76
- TheChosenOne
7 years 1 month ago - 7 years 1 month ago #145755
by TheChosenOne
Spindle configuration for Mesa 5i25 + 7i76 was created by TheChosenOne
I connected Mesa 7i76 to VFD as andypugh answered in this topic forum.linuxcnc.org/27-driver-boards/3537...wiring-to-mesa-7i76e and used PnCConf Wizard to save following configuration:
Unfortunately I cannot run Linuxcnc due to error:
Can you please tell me how to fix it?
P.S. I use newest version from master branch
./sp-864.hal:197: parameter or pin 'hm2_5i25.0.7i76.0.0.spinout-minlim' not found
Last edit: 7 years 1 month ago by TheChosenOne.
- Thank you received: 5334
7 years 1 month ago - 7 years 1 month ago #145759
Replied by PCW on topic Spindle configuration for Mesa 5i25 + 7i76
You will likely get that error if the 7I76 is not discovered. This is most likely because:
1. The 7I76 has no field power /VIN power
(make sure 7I76 W1 is in the left hand position and that 8 to 32VDC are supplied to TB1)
2. The 7I76 has no 5V power (normally is easiest to use FPGA card power for this so
7I76 W2 in left hand position, FPGA card set to supply 5V power on cable)
3. Wrong firmware on FPGA card (verify with mesaflash --readhmid option)
4. Setup/operate jumper (W3) on 7I76 set to setup mode
make sure W3 is in the "left" or operate position
Last edit: 7 years 1 month ago by PCW.
The following user(s) said Thank You: TheChosenOne
- TheChosenOne
7 years 1 month ago #145762
by TheChosenOne
Replied by TheChosenOne on topic Spindle configuration for Mesa 5i25 + 7i76
Before setting up spindle Linuxcnc run without problems and all axis were moving correctly, so probably 7i76 is discovered and has power(?)
Maybe this report will be helpful:
Warning: Spoiler!
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.0-pre0-658-gc1670850b
Machine configuration directory is '/home/operator/linuxcnc/configs/sp-864'
Machine configuration file is 'sp-864.ini'
INIFILE=/home/operator/linuxcnc/configs/sp-864/sp-864.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./sp-864.hal
Running HAL shutdown script
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:01:02.0
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): StepGen #0, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 001 (P3-14): StepGen #0, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #1, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 003 (P3-15): StepGen #1, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #2, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #2, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #3, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 007 (P3-17): StepGen #3, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #4, pin Direction (Output)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #4, pin Step (Output)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): IOPort
hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin Index (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Encoder #0, pin A (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_5i25.0: registered
hm2_5i25.0: initialized AnyIO board at 0000:01:02.0
hm2_5i25.0: dropping AnyIO board at 0000:01:02.0
hm2/hm2_5i25.0: unregistered
hm2_pci: driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
22912
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f168567f000
Kernel message information:
dmesg: read kernel buffer failed: Operation not permitted
dmesg requires root privilege on this system
Description: Debian GNU/Linux 9.11 (stretch)
Use a terminal to issue the command: sudo dmesg
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Sat Sep 21 16:04:22 CEST 2019
UTC Date: Sat Sep 21 14:04:22 UTC 2019
this program: /usr/bin/linuxcnc_info
uptime: 16:04:22 up 1 day, 3:28, 1 user, load average: 0.12, 0.05, 0.04
lsb_release -sa: Debian Debian GNU/Linux 9.11 (stretch) 9.11 stretch
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/operator/linuxcnc/configs/sp-864
USER: operator
LOGNAME: operator
HOME: /home/operator
EDITOR:
VISUAL:
LANGUAGE: en_US:en
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1680x1050 pixels (444x277 millimeters)
PATH: /usr/bin:/home/operator/linuxcnc/configs/sp-864/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: cnc
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.9.144-3.1 (2019-02-19)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-amd64 root=UUID=4f13fa0a-6a75-4376-8120-7f20047b9819 ro quiet
model name: Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz
cores: 1
cpu MHz: 3300.000
parport:
serial: 0000-0000 : serial
Versions:
gcc: gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
python: Python 2.7.13
git: git version 2.11.0
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.0-pre0-658-gc1670850b
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.9.0~pre0.658.gc1670850b all motion controller for CNC machines and robots (English documentation)
un linuxcnc-sim <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.0~pre0.658.gc1670850b amd64 motion controller for CNC machines and robots
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
VERSION=1.1
TASK=milltask
HALUI=halui
DISPLAY=axis
COORDINATES=XYZ
hm2: unloading
22912
pastebin.com
USER: operator
LOGNAME: operator
EDITOR:
VISUAL:
LANGUAGE: en_US:en
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: cnc
machine -m: x86_64
/proc items:
cores: 1
cpu MHz: 3300.000
parport:
Versions:
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
7 years 1 month ago #145764
The log shows that the field I/O / spindle section of the 7I76 was not discovered
step/dir outputs and the encoder will work without this
- TheChosenOne
7 years 1 month ago - 7 years 1 month ago #145770
by TheChosenOne
W1, W2 and W3 are in left hand position.
Below is a result of mesaflash command:
I don't know what it means. Can you please explain?
➜ mesaflash git:(master) sudo ./mesaflash --device 5i25 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 2 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 10 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort StepGen 0 Dir/Table2 (Out)
14 1 IOPort StepGen 0 Step/Table1 (Out)
2 2 IOPort StepGen 1 Dir/Table2 (Out)
15 3 IOPort StepGen 1 Step/Table1 (Out)
3 4 IOPort StepGen 2 Dir/Table2 (Out)
16 5 IOPort StepGen 2 Step/Table1 (Out)
4 6 IOPort StepGen 3 Dir/Table2 (Out)
17 7 IOPort StepGen 3 Step/Table1 (Out)
5 8 IOPort StepGen 4 Dir/Table2 (Out)
6 9 IOPort StepGen 4 Step/Table1 (Out)
7 10 IOPort SSerial 0 TXData1 (Out)
8 11 IOPort SSerial 0 RXData1 (In)
9 12 IOPort SSerial 0 TXData2 (Out)
10 13 IOPort SSerial 0 RXData2 (In)
11 14 IOPort QCount 0 Quad-IDX (In)
12 15 IOPort QCount 0 Quad-B (In)
13 16 IOPort QCount 0 Quad-A (In)
IO Connections for P2
1 17 IOPort StepGen 5 Dir/Table2 (Out)
14 18 IOPort StepGen 5 Step/Table1 (Out)
2 19 IOPort StepGen 6 Dir/Table2 (Out)
15 20 IOPort StepGen 6 Step/Table1 (Out)
3 21 IOPort StepGen 7 Dir/Table2 (Out)
16 22 IOPort StepGen 7 Step/Table1 (Out)
4 23 IOPort StepGen 8 Dir/Table2 (Out)
17 24 IOPort StepGen 8 Step/Table1 (Out)
5 25 IOPort StepGen 9 Dir/Table2 (Out)
6 26 IOPort StepGen 9 Step/Table1 (Out)
7 27 IOPort SSerial 0 TXData3 (Out)
8 28 IOPort SSerial 0 RXData3 (In)
9 29 IOPort SSerial 0 TXData4 (Out)
10 30 IOPort SSerial 0 RXData4 (In)
11 31 IOPort QCount 1 Quad-IDX (In)
12 32 IOPort QCount 1 Quad-B (In)
13 33 IOPort QCount 1 Quad-A (In)
7 years 1 month ago - 7 years 1 month ago #145772
TB1 (Orange 8 pin terminal block) is the 7I76's field power connection
it needs 8 to 32VDC applied (Plus on pin1 = bottom pin, Minus/Common on top = pin
Time to create page: 2.385 seconds
