Spindle configuration for Mesa 5i25 + 7i76
- TheChosenOne
7 years 1 month ago #145775
by TheChosenOne
Replied by TheChosenOne on topic Spindle configuration for Mesa 5i25 + 7i76
Thank you. I plugged +10VDC and VFIELD LED lights up. mesaflash output did not change, LinuxCNC starts without any error but spindle still does not work.
- Thank you received: 5334
7 years 1 month ago #145779
Replied by PCW on topic Spindle configuration for Mesa 5i25 + 7i76
The mesaflash output will not change, the startup log will however and the
missing pins will be available in the hal file
The spindle not working is most likely a wiring or hal/ini file setup issue
The following user(s) said Thank You: TheChosenOne
- pl7i92
- Thank you received: 358
7 years 1 month ago #145853
by pl7i92
Replied by pl7i92 on topic Spindle configuration for Mesa 5i25 + 7i76
you shoudt check """#""" uncomment all errors
and look first if the pins are available
is the 5i25 7i76 a plug and play component or did you flash it with the firmware
- TheChosenOne
7 years 1 month ago #145857
by TheChosenOne
Problem is solved! Beside lack of power in TB1 I had incorrect settings in VFD.
Thank you for your help!
Time to create page: 3.134 seconds
