tommylight wrote: You need the preempt-RT version for ethernet cards, as PCW suggested above and gave the link.
Thank you tommy for your reply. I didnt mean to disrespect PCW with his response, I just wanted to double check that I definitely needed to install it after I changed the address as I had major difficulty installing it, infact ive had to have an IT technition frined of mine look over it for a few hours to finally get it installed.
Now that I have, ive run into a problem when trying to run the LinuxCNC PlasmaC buildbot installation through a terminal.
When i enter "sudo apt-key adv --keyserver hkp://keys.gnup.net --recv-key E0EE663E" for the first time I got an error but then i installed "sudo apt-get install dirmngr" and got the following response when i re entered the first command.
now when I followed the next set of steps and got to searching the respositories for.
deb
buildbot.linuxcnc.org/
stretch master-rtpreempt
deb-src
it only displayed the following.
any ideas?
thanks in advance
