PNCconf encountered an error
6 years 11 months ago #150555 by little_sparky
Hi All,
I tried to test my motors after a fresh install of linux cnc and recieved this message.
Does anyone know how to solve?
Thank you in advance!
6 years 11 months ago #150557 by cmorley
What version of linuxcnc?
6 years 11 months ago #150558 by cmorley
I bet 2.7.14 - there is a fix for this but it hasn't been released yet.
It's a one line change if you want to try to fix it yourself.
change (aprox line 1641 in /usr/bin/pncconf:
elif hal.is_rt and not hal.kernel_version == actual_kernel:
to
elif hal.is_kernelspace and hal.kernel_version != actual_kernel:
See if that works. Not that many people use RTAI any more
Chris
6 years 11 months ago #150559 by little_sparky
I downloaded the "linuxcnc-stretch-uspace-i386-r13.iso" image which gave me version 2.7.14.
In the future I need to download 2.8 or master to run PlasmaC but am unable to for some reason. Have that discussio thread here forum.linuxcnc.org/39-pncconf/37798-mesa...-board-found?start=0
6 years 11 months ago #150560 by little_sparky
cmorley wrote: Not that many people use RTAI any more
how do you know it is RTAI?
I was meant to download RTPREEMPT as I am using a mesa board.
6 years 11 months ago #150561 by cmorley
An educated guess based on the error. That is what the line of code is doing - figuring out what kind of realtime system is being used.
In a terminal:
uname -r
should let you know what kernel you are using in general:
RTAI will have rtai in the name
Preemptive will have _rt in the name
most others will have generic in the name
Chris
Time to create page: 0.144 seconds
