PNCconf encountered an error
6 years 11 months ago - 6 years 11 months ago #150562 by little_sparky
wow you are a star.
I just edited the line in the file (will test in a few minutes) and noticed you wrote it, you must be a genius!
cmorley wrote: In a terminal:
uname -r
should let you know what kernel you are using in general:
RTAI will have rtai in the name
Preemptive will have _rt in the name
most others will have generic in the name
I just checked
uname -r
4.9.0-8-rt-686-pae
cheers, Jonty
Last edit: 6 years 11 months ago by little_sparky.
6 years 11 months ago #150563 by cmorley
genius no.
glutton for punishment maybe :)
Glad I could help.
Chris
6 years 11 months ago #150564 by little_sparky
Chris, changing the line in the code worked and I no longer receive an error message.
However, now when I save the PNCconfig and open on the desktop it comes up with the following error.
I think it is because I have not downloaded hm2_eth or hostmot2 (if thats the same thing?). However I have been looking online and looked through the hm2_eth manual and still have no idea how to download or install it.
Error message:
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.7.14 Machine configuration directory is '/home/jonty/linuxcnc/configs/my_TESTLinuxCNC_machine' Machine configuration file is 'my_TESTLinuxCNC_machine.ini' INIFILE=/home/jonty/linuxcnc/configs/my_TESTLinuxCNC_machine/my_TESTLinuxCNC_machine.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./my_TESTLinuxCNC_machine.hal hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: ERROR: 192.168.1.121: Could not retrieve mac address Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Killing task linuxcncsvr, PID=1184 hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11) ./my_TESTLinuxCNC_machine.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth ./my_TESTLinuxCNC_machine.hal:8: /usr/bin/rtapi_app exited without becoming ready ./my_TESTLinuxCNC_machine.hal:8: insmod for hm2_eth failed, returned -1 1184 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Note: Using POSIX realtime Kernel message information: [ 0.000000] Linux version 4.9.0-8-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) [ 0.000000] CPU0: Hyper-Threading is disabled [ 0.000000] x86/fpu: Legacy x87 FPU detected. [ 0.000000] e820: BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable [ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001f73ffff] usable [ 0.000000] BIOS-e820: [mem 0x000000001f740000-0x000000001f74ffff] ACPI data [ 0.000000] BIOS-e820: [mem 0x000000001f750000-0x000000001f7fffff] ACPI NVS [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU! [ 0.000000] SMBIOS 2.3 present. [ 0.000000] DMI: /D845GVSR , BIOS VA84510A.86A.0050.P18.0409222329 09/22/2004 [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable [ 0.000000] e820: last_pfn = 0x1f740 max_arch_pfn = 0x1000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-DFFFF uncachable [ 0.000000] E0000-FFFFF write-back [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask FE0000000 write-back [ 0.000000] 1 base 01F800000 mask FFF800000 uncachable [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- UC [ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [c00ff780] [ 0.000000] initial memory mapped: [mem 0x00000000-0x15ffffff] [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] BRK [0x15a91000, 0x15a91fff] PGTABLE [ 0.000000] BRK [0x15a92000, 0x15a93fff] PGTABLE [ 0.000000] BRK [0x15a94000, 0x15a94fff] PGTABLE [ 0.000000] BRK [0x15a95000, 0x15a95fff] PGTABLE [ 0.000000] RAMDISK: [mem 0x1d0f2000-0x1e70cfff] [ 0.000000] ACPI: Early table checksum verification disabled [ 0.000000] ACPI: RSDP 0x00000000000F77A0 000014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT 0x000000001F740000 000030 (v01 INTEL D845GVS1 20040922 MSFT 00000097) [ 0.000000] ACPI: FACP 0x000000001F740200 000074 (v01 INTEL D845GVS1 20040922 MSFT 00000097) [ 0.000000] ACPI: DSDT 0x000000001F740370 00415D (v01 INTEL D845GVS1 0000010A MSFT 0100000D) [ 0.000000] ACPI: FACS 0x000000001F750000 000040 [ 0.000000] ACPI: APIC 0x000000001F740300 000068 (v01 INTEL D845GVS1 20040922 MSFT 00000097) [ 0.000000] ACPI: ASF! 0x000000001F7444D0 000084 (v16 AMIASF I845GASF 00000001 MSFT 0100000D) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 0MB HIGHMEM available. [ 0.000000] 503MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 1f740000 [ 0.000000] low ram: 0 - 1f740000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff] [ 0.000000] Normal [mem 0x0000000001000000-0x000000001f73ffff] [ 0.000000] HighMem empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009efff] [ 0.000000] node 0: [mem 0x0000000000100000-0x000000001f73ffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000001f73ffff] [ 0.000000] On node 0 totalpages: 128734 [ 0.000000] free_area_init_node: node 0, pgdat d5829780, node_mem_map df254028 [ 0.000000] DMA zone: 40 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3998 pages, LIFO batch:0 [ 0.000000] Normal zone: 1219 pages used for memmap [ 0.000000] Normal zone: 124736 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] Reserving Intel graphics memory at 0x000000001f800000-0x000000001fffffff [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1]) [ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] smpboot: Allowing 2 CPUs, 1 hotplug CPUs [ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff] [ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff] [ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff] [ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff] [ 0.000000] e820: [mem 0x20000000-0xffffffff] available for PCI devices [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns [ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1 [ 0.000000] percpu: Embedded 101 pages/cpu @df187000 s381472 r0 d32224 u413696 [ 0.000000] pcpu-alloc: s381472 r0 d32224 u413696 alloc=101*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127475 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-686-pae root=/dev/sda1 ro quiet [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] Initializing HighMem for node 0 (00000000:00000000) [ 0.000000] Memory: 474880K/514936K available (6035K kernel code, 628K rwdata, 1756K rodata, 1060K init, 592K bss, 40056K reserved, 0K cma-reserved, 0K highmem) [ 0.000000] virtual kernel memory layout: fixmap : 0xffd36000 - 0xfffff000 (2852 kB) pkmap : 0xffa00000 - 0xffc00000 (2048 kB) vmalloc : 0xdff40000 - 0xff9fe000 ( 506 MB) lowmem : 0xc0000000 - 0xdf740000 ( 503 MB) .init : 0xd583d000 - 0xd5946000 (1060 kB) .data : 0xd55e51f4 - 0xd583b280 (2392 kB) .text : 0xd5000000 - 0xd55e51f4 (6036 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] SLUB: HWalign=128, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2. [ 0.000000] RCU kthread priority: 1. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS:2304 nr_irqs:440 16 [ 0.000000] CPU 0 irqstacks, hard=dec3e000 soft=dec80000 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] tsc: Fast TSC calibration using PIT [ 0.000000] tsc: Detected 2400.068 MHz processor [ 0.004009] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.13 BogoMIPS (lpj=9600272) [ 0.004011] pid_max: default: 32768 minimum: 301 [ 0.004061] ACPI: Core revision 20160831 [ 0.012247] ACPI: 1 ACPI AML tables successfully acquired and loaded [ 0.012313] Security Framework initialized [ 0.012316] Yama: disabled by default; enable with sysctl kernel.yama.* [ 0.012331] AppArmor: AppArmor disabled by boot time parameter [ 0.012362] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.012364] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.012993] mce: CPU supports 4 MCE banks [ 0.013009] CPU0: Thermal monitoring enabled (TM1) [ 0.013023] process: using mwait in idle threads [ 0.013040] Last level iTLB entries: 4KB 128, 2MB 128, 4MB 128 [ 0.013041] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0 [ 0.013045] Spectre V2 : Mitigation: Full generic retpoline [ 0.013046] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch [ 0.013048] Speculative Store Bypass: Vulnerable [ 0.034989] ftrace: allocating 24078 entries in 48 pages [ 0.064279] smpboot: Max logical packages: 2 [ 0.064294] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.064678] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.108000] smpboot: CPU0: Intel(R) Celeron(R) CPU 2.40GHz (family: 0xf, model: 0x4, stepping: 0x1) [ 0.108000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver. [ 0.108000] ... version: 0 [ 0.108000] ... bit width: 40 [ 0.108000] ... generic registers: 18 [ 0.108000] ... value mask: 000000ffffffffff [ 0.108000] ... max period: 0000007fffffffff [ 0.108000] ... fixed-purpose events: 0 [ 0.108000] ... event mask: 000000000003ffff [ 0.160116] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. [ 0.168024] x86: Booted up 1 node, 1 CPUs [ 0.168030] smpboot: Total of 1 processors activated (4800.13 BogoMIPS) [ 0.168919] devtmpfs: initialized [ 0.172115] PM: Registering ACPI NVS region [mem 0x1f750000-0x1f7fffff] (720896 bytes) [ 0.172320] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.172330] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.172425] pinctrl core: initialized pinctrl subsystem [ 0.172797] NET: Registered protocol family 16 [ 0.176065] cpuidle: using governor ladder [ 0.176084] cpuidle: using governor menu [ 0.176199] ACPI: bus type PCI registered [ 0.176205] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.176359] PCI: Using configuration type 1 for base access [ 0.180228] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.196222] ACPI: Added _OSI(Module Device) [ 0.196226] ACPI: Added _OSI(Processor Device) [ 0.196228] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.196231] ACPI: Added _OSI(Processor Aggregator Device) [ 0.196757] ACPI: Executed 2 blocks of module-level executable AML code [ 0.202362] ACPI: Interpreter enabled [ 0.202418] ACPI: (supports S0 S1 S4 S5) [ 0.202422] ACPI: Using IOAPIC for interrupt routing [ 0.202519] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.207245] ACPI: Power Resource [URP1] (off) [ 0.207360] ACPI: Power Resource [URP2] (off) [ 0.207470] ACPI: Power Resource [FDDP] (off) [ 0.207585] ACPI: Power Resource [LPTP] (off) [ 0.215485] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.215501] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI] [ 0.215514] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM [ 0.215522] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge. [ 0.215929] PCI host bridge to bus 0000:00 [ 0.215936] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window] [ 0.215940] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window] [ 0.215944] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window] [ 0.215947] pci_bus 0000:00: root bus resource [mem 0x1f800000-0xffffffff window] [ 0.215952] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.215975] pci 0000:00:00.0: [8086:2560] type 00 class 0x060000 [ 0.216064] pci 0000:00:00.0: reg 0x10: [mem 0xe0000000-0xefffffff pref] [ 0.216312] pci 0000:00:02.0: [8086:2562] type 00 class 0x030000 [ 0.216336] pci 0000:00:02.0: reg 0x10: [mem 0xf0000000-0xf7ffffff pref] [ 0.216347] pci 0000:00:02.0: reg 0x14: [mem 0xffa80000-0xffafffff] [ 0.216600] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300 [ 0.216659] pci 0000:00:1d.0: reg 0x20: [io 0xe800-0xe81f] [ 0.216835] pci 0000:00:1d.0: System wakeup disabled by ACPI [ 0.216959] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300 [ 0.217020] pci 0000:00:1d.1: reg 0x20: [io 0xe880-0xe89f] [ 0.217188] pci 0000:00:1d.1: System wakeup disabled by ACPI [ 0.217305] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300 [ 0.217366] pci 0000:00:1d.2: reg 0x20: [io 0xec00-0xec1f] [ 0.217533] pci 0000:00:1d.2: System wakeup disabled by ACPI [ 0.217661] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320 [ 0.217689] pci 0000:00:1d.7: reg 0x10: [mem 0xffa7fc00-0xffa7ffff] [ 0.217814] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.217948] pci 0000:00:1d.7: System wakeup disabled by ACPI [ 0.218054] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400 [ 0.218189] pci 0000:00:1e.0: System wakeup disabled by ACPI [ 0.218296] pci 0000:00:1f.0: [8086:24c0] type 00 class 0x060100 [ 0.218302] * The chipset may have PM-Timer Bug. Due to workarounds for a bug, * this clock source is slow. If you are sure your timer does not have * this bug, please use "acpi_pm_good" to disable the workaround [ 0.218396] pci 0000:00:1f.0: quirk: [io 0x0400-0x047f] claimed by ICH4 ACPI/GPIO/TCO [ 0.218403] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH4 GPIO [ 0.218579] pci 0000:00:1f.1: [8086:24cb] type 00 class 0x01018a [ 0.218600] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007] [ 0.218613] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003] [ 0.218625] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007] [ 0.218638] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003] [ 0.218651] pci 0000:00:1f.1: reg 0x20: [io 0xffa0-0xffaf] [ 0.218665] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff] [ 0.218682] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7] [ 0.218685] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6] [ 0.218688] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177] [ 0.218691] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376] [ 0.218865] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500 [ 0.218925] pci 0000:00:1f.3: reg 0x20: [io 0xe000-0xe01f] [ 0.219109] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100 [ 0.219131] pci 0000:00:1f.5: reg 0x10: [io 0xe400-0xe4ff] [ 0.219143] pci 0000:00:1f.5: reg 0x14: [io 0xe080-0xe0bf] [ 0.219156] pci 0000:00:1f.5: reg 0x18: [mem 0xffa7f800-0xffa7f9ff] [ 0.219168] pci 0000:00:1f.5: reg 0x1c: [mem 0xffa7f400-0xffa7f4ff] [ 0.219236] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold [ 0.219471] pci 0000:01:00.0: [11c1:048c] type 00 class 0x078000 [ 0.219495] pci 0000:01:00.0: reg 0x10: [mem 0xff8ffc00-0xff8ffcff] [ 0.219508] pci 0000:01:00.0: reg 0x14: [io 0xdc00-0xdc07] [ 0.219520] pci 0000:01:00.0: reg 0x18: [io 0xd800-0xd8ff] [ 0.219604] pci 0000:01:00.0: supports D2 [ 0.219607] pci 0000:01:00.0: PME# supported from D2 D3hot D3cold [ 0.219743] pci 0000:01:08.0: [8086:1039] type 00 class 0x020000 [ 0.219767] pci 0000:01:08.0: reg 0x10: [mem 0xff8fe000-0xff8fefff] [ 0.219779] pci 0000:01:08.0: reg 0x14: [io 0xd480-0xd4bf] [ 0.219867] pci 0000:01:08.0: supports D1 D2 [ 0.219871] pci 0000:01:08.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.220085] pci 0000:00:1e.0: PCI bridge to [bus 01] (subtractive decode) [ 0.220094] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff] [ 0.220100] pci 0000:00:1e.0: bridge window [mem 0xff800000-0xff8fffff] [ 0.220107] pci 0000:00:1e.0: bridge window [mem 0xcea00000-0xceafffff pref] [ 0.220111] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode) [ 0.220115] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode) [ 0.220118] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode) [ 0.220121] pci 0000:00:1e.0: bridge window [mem 0x1f800000-0xffffffff window] (subtractive decode) [ 0.220139] pci_bus 0000:00: on NUMA node 0 [ 0.222319] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.222520] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 9 10 11 12 14 15) [ 0.222718] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 14 15) [ 0.222911] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 9 10 11 12 14 15) [ 0.223107] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.223304] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.223494] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled. [ 0.223689] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 14 15) [ 0.224421] vgaarb: setting as boot device: PCI:0000:00:02.0 [ 0.224427] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.224437] vgaarb: loaded [ 0.224441] vgaarb: bridge control possible 0000:00:02.0 [ 0.228072] PCI: Using ACPI for IRQ routing [ 0.228080] PCI: pci_cache_line_size set to 64 bytes [ 0.228145] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff] [ 0.228151] e820: reserve RAM buffer [mem 0x1f740000-0x1fffffff] [ 0.232231] clocksource: Switched to clocksource refined-jiffies [ 0.257865] VFS: Disk quotas dquot_6.6.0 [ 0.257932] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.258225] pnp: PnP ACPI init [ 0.258438] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.258982] system 00:01: [io 0x04d0-0x04d1] has been reserved [ 0.258996] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.259206] pnp 00:02: [dma 2] [ 0.259348] pnp 00:02: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.259939] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.260785] pnp 00:04: [dma 3] [ 0.260991] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active) [ 0.262014] system 00:05: [io 0x0400-0x047f] has been reserved [ 0.262021] system 00:05: [io 0x0680-0x06ff] has been reserved [ 0.262025] system 00:05: [io 0x0480-0x04bf] has been reserved [ 0.262032] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.262040] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.262051] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.262628] system 00:06: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.262637] system 00:06: [mem 0x000c0000-0x000dffff] could not be reserved [ 0.262641] system 00:06: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.262645] system 00:06: [mem 0x00100000-0x1f7fffff] could not be reserved [ 0.262655] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.263091] pnp: PnP ACPI: found 7 devices [ 0.263099] PnPBIOS: Disabled [ 0.303695] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns [ 0.303722] clocksource: Switched to clocksource acpi_pm [ 0.303775] pci 0000:00:1f.1: BAR 5: assigned [mem 0x20000000-0x200003ff] [ 0.303788] pci 0000:00:1e.0: PCI bridge to [bus 01] [ 0.303794] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff] [ 0.303802] pci 0000:00:1e.0: bridge window [mem 0xff800000-0xff8fffff] [ 0.303808] pci 0000:00:1e.0: bridge window [mem 0xcea00000-0xceafffff pref] [ 0.303819] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window] [ 0.303822] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window] [ 0.303826] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window] [ 0.303829] pci_bus 0000:00: resource 7 [mem 0x1f800000-0xffffffff window] [ 0.303833] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff] [ 0.303836] pci_bus 0000:01: resource 1 [mem 0xff800000-0xff8fffff] [ 0.303839] pci_bus 0000:01: resource 2 [mem 0xcea00000-0xceafffff pref] [ 0.303843] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7 window] [ 0.303846] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff window] [ 0.303849] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff window] [ 0.303853] pci_bus 0000:01: resource 7 [mem 0x1f800000-0xffffffff window] [ 0.303853] NET: Registered protocol family 2 [ 0.303853] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.303853] TCP bind hash table entries: 4096 (order: 4, 114688 bytes) [ 0.303853] TCP: Hash tables configured (established 4096 bind 4096) [ 0.303853] UDP hash table entries: 256 (order: 2, 16384 bytes) [ 0.303853] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes) [ 0.303853] NET: Registered protocol family 1 [ 0.303853] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff] [ 0.303853] pci 0000:01:08.0: Firmware left e100 interrupts enabled; disabling [ 0.303853] PCI: CLS 64 bytes, default 64 [ 0.303853] Unpacking initramfs... [ 1.249280] Freeing initrd memory: 22636K [ 1.250348] audit: initializing netlink subsys (disabled) [ 1.250402] audit: type=2000 audit(1574056254.247:1): initialized [ 1.255392] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 1.259796] zbud: loaded [ 1.262296] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) [ 1.266480] io scheduler noop registered [ 1.266484] io scheduler deadline registered [ 1.266603] io scheduler cfq registered (default) [ 1.266879] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 1.266894] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 1.267180] GHES: HEST is not enabled! [ 1.267337] isapnp: Scanning for PnP cards... [ 1.621916] isapnp: No Plug & Play device found [ 1.622149] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.642675] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A [ 1.643745] Linux agpgart interface v0.103 [ 1.643959] agpgart-intel 0000:00:00.0: Intel 845G Chipset [ 1.656667] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000 [ 1.657153] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.660564] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.660585] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.661033] mousedev: PS/2 mouse device common for all mice [ 1.661134] rtc_cmos 00:00: RTC can wake from S4 [ 1.661435] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0 [ 1.661591] rtc_cmos 00:00: alarms up to one month, 114 bytes nvram [ 1.662884] NET: Registered protocol family 10 [ 1.667692] mip6: Mobile IPv6 [ 1.667701] NET: Registered protocol family 17 [ 1.667710] mpls_gso: MPLS GSO support [ 1.668352] microcode: sig=0xf41, pf=0x4, revision=0x17 [ 1.668504] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 1.668517] Using IPI No-Shortcut mode [ 1.668927] registered taskstats version 1 [ 1.669010] zswap: loaded using pool lzo/zbud [ 1.669102] ima: No TPM chip found, activating TPM-bypass! [ 1.669111] ima: Allocated hash algorithm: sha256 [ 1.673653] rtc_cmos 00:00: setting system clock to 2019-11-18 05:50:54 UTC (1574056254) [ 1.673734] PM: Hibernation image not present or could not be loaded. [ 1.675371] Freeing unused kernel memory: 1060K [ 1.675548] Write protecting the kernel text: 6040k [ 1.675681] Write protecting the kernel read-only data: 1760k [ 1.729517] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 1.729801] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 1.734127] random: udevadm: uninitialized urandom read (16 bytes read) [ 1.903966] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI [ 1.903971] e100: Copyright(c) 1999-2006 Intel Corporation [ 1.909270] ACPI: bus type USB registered [ 1.909347] usbcore: registered new interface driver usbfs [ 1.909380] usbcore: registered new interface driver hub [ 1.910578] usbcore: registered new device driver usb [ 1.914085] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.915308] uhci_hcd: USB Universal Host Controller Interface driver [ 1.915635] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 1.915654] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1 [ 1.915669] uhci_hcd 0000:00:1d.0: detected 2 ports [ 1.916963] ehci-pci: EHCI PCI platform driver [ 1.921582] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000e800 [ 1.921783] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.921787] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.921791] usb usb1: Product: UHCI Host Controller [ 1.921794] usb usb1: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd [ 1.921797] usb usb1: SerialNumber: 0000:00:1d.0 [ 1.922309] hub 1-0:1.0: USB hub found [ 1.922341] hub 1-0:1.0: 2 ports detected [ 1.923220] ehci-pci 0000:00:1d.7: EHCI Host Controller [ 1.923241] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 2 [ 1.923266] ehci-pci 0000:00:1d.7: debug port 1 [ 1.927216] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported [ 1.935335] SCSI subsystem initialized [ 1.946543] ehci-pci 0000:00:1d.7: irq 23, io mem 0xffa7fc00 [ 1.960358] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 1.960588] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.960593] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.960596] usb usb2: Product: EHCI Host Controller [ 1.960599] usb usb2: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd [ 1.960602] usb usb2: SerialNumber: 0000:00:1d.7 [ 1.961053] hub 2-0:1.0: USB hub found [ 1.961089] hub 2-0:1.0: 6 ports detected [ 1.966776] Floppy drive(s): fd0 is 1.44M [ 1.988317] hub 1-0:1.0: USB hub found [ 1.989218] hub 1-0:1.0: 2 ports detected [ 1.990096] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 1.990116] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 1.990145] uhci_hcd 0000:00:1d.1: detected 2 ports [ 1.990573] libata version 3.00 loaded. [ 1.995432] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e880 [ 1.995640] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.995645] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.995648] usb usb3: Product: UHCI Host Controller [ 1.995651] usb usb3: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd [ 1.995654] usb usb3: SerialNumber: 0000:00:1d.1 [ 1.996246] hub 3-0:1.0: USB hub found [ 1.996289] hub 3-0:1.0: 2 ports detected [ 1.996886] i801_smbus 0000:00:1f.3: SMBus using polling [ 1.997407] ata_piix 0000:00:1f.1: version 2.13 [ 1.997422] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007) [ 2.005679] FDC 0 is a post-1991 82077 [ 2.024831] scsi host0: ata_piix [ 2.033866] e100 0000:01:08.0 eth0: addr 0xff8fe000, irq 20, MAC addr 00:11:11:90:7c:9d [ 2.040163] scsi host1: ata_piix [ 2.040373] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14 [ 2.040377] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15 [ 2.040715] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 2.040739] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 2.040754] uhci_hcd 0000:00:1d.2: detected 2 ports [ 2.044240] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ec00 [ 2.044473] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 2.044477] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.044480] usb usb4: Product: UHCI Host Controller [ 2.044483] usb usb4: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd [ 2.044486] usb usb4: SerialNumber: 0000:00:1d.2 [ 2.044972] hub 4-0:1.0: USB hub found [ 2.045008] hub 4-0:1.0: 2 ports detected [ 2.208290] ata2.01: NODEV after polling detection [ 2.210986] ata2.00: ATAPI: SAMSUNG CD-R/RW SW-252B, R700, max UDMA/33 [ 2.215912] ata2.00: configured for UDMA/33 [ 2.218163] ata1.00: ATA-7: WDC WD1600AAJB-00PVA0, 00.07H00, max UDMA/100 [ 2.218168] ata1.00: 312581808 sectors, multi 16: LBA48 [ 2.220956] ata1.00: configured for UDMA/100 [ 2.225482] scsi 0:0:0:0: Direct-Access ATA WDC WD1600AAJB-0 7H00 PQ: 0 ANSI: 5 [ 2.255807] scsi 1:0:0:0: CD-ROM SAMSUNG CD-R/RW SW-252B R700 PQ: 0 ANSI: 5 [ 2.271168] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB) [ 2.271301] sd 0:0:0:0: [sda] Write Protect is off [ 2.271306] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 2.271357] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.272121] tsc: Refined TSC clocksource calibration: 2400.085 MHz [ 2.272134] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x229887d25b0, max_idle_ns: 440795264680 ns [ 2.290136] sr 1:0:0:0: [sr0] scsi3-mmc drive: 52x/52x writer cd/rw xa/form2 cdda tray [ 2.290141] cdrom: Uniform CD-ROM driver Revision: 3.20 [ 2.290851] sr 1:0:0:0: Attached scsi CD-ROM sr0 [ 2.312608] sda: sda1 sda2 < sda5 > [ 2.314248] sd 0:0:0:0: [sda] Attached SCSI disk [ 2.452081] usb 1-2: new low-speed USB device number 2 using uhci_hcd [ 2.638102] usb 1-2: New USB device found, idVendor=413c, idProduct=2003 [ 2.638109] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.638112] usb 1-2: Product: Dell USB Keyboard [ 2.638115] usb 1-2: Manufacturer: Dell [ 2.665913] hidraw: raw HID events driver (C) Jiri Kosina [ 2.689052] usbcore: registered new interface driver usbhid [ 2.689058] usbhid: USB HID core driver [ 2.694551] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-2/1-2:1.0/0003:413C:2003.0001/input/input3 [ 2.754315] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1d.0-2/input0 [ 2.782429] PM: Starting manual resume from disk [ 2.782442] PM: Hibernation image partition 8:5 present [ 2.782444] PM: Looking for hibernation image. [ 2.782989] PM: Image not found (code -22) [ 2.782994] PM: Hibernation image not present or could not be loaded. [ 2.984735] random: fast init done [ 3.106849] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 3.168152] usb 3-1: new low-speed USB device number 2 using uhci_hcd [ 3.296277] clocksource: Switched to clocksource tsc [ 3.357132] usb 3-1: New USB device found, idVendor=045e, idProduct=0084 [ 3.357140] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.357143] usb 3-1: Product: Basic Optical Mouse [ 3.357146] usb 3-1: Manufacturer: Microsoft [ 3.374945] input: Microsoft Basic Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/0003:045E:0084.0002/input/input4 [ 3.375306] hid-generic 0003:045E:0084.0002: input,hidraw1: USB HID v1.10 Mouse [Microsoft Basic Optical Mouse] on usb-0000:00:1d.1-1/input0 [ 4.198558] ip_tables: (C) 2000-2006 Netfilter Core Team [ 4.301745] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 4.302209] systemd[1]: Detected architecture x86. [ 4.314195] systemd[1]: Set hostname to <jonty>. [ 5.404557] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked. [ 5.404590] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked. [ 5.406924] systemd[1]: Listening on Syslog Socket. [ 5.407392] systemd[1]: Listening on fsck to fsckd communication Socket. [ 5.407639] systemd[1]: Listening on udev Control Socket. [ 5.407850] systemd[1]: Listening on Journal Socket (/dev/log). [ 5.408235] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 5.528616] random: crng init done [ 5.528623] random: 7 urandom warning(s) missed due to ratelimiting [ 6.036420] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 6.171949] lp: driver loaded but no devices found [ 6.337642] ppdev: user-space parallel port driver [ 6.358528] parport_pc 00:04: reported by Plug and Play ACPI [ 6.358667] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP] [ 6.464435] lp0: using parport0 (interrupt-driven). [ 6.601734] systemd-journald[194]: Received request to flush runtime journal from PID 1 [ 7.755334] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5 [ 7.755351] ACPI: Sleep Button [SLPB] [ 7.755533] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6 [ 7.755541] ACPI: Power Button [PWRF] [ 7.874177] intel_rng: Firmware space is locked read-only. If you can't or intel_rng: don't want to disable this in firmware setup, and if intel_rng: you are certain that your system has a functional intel_rng: RNG, try using the 'no_fwh_detect' option. [ 7.919655] [drm] Initialized [ 7.954230] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 8.061348] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 8.061498] sr 1:0:0:0: Attached scsi generic sg1 type 5 [ 8.650574] input: PC Speaker as /devices/platform/pcspkr/input/input7 [ 8.756129] snd_intel8x0 0000:00:1f.5: intel8x0_measure_ac97_clock: measured 56543 usecs (2724 samples) [ 8.756136] snd_intel8x0 0000:00:1f.5: clocking to 48000 [ 8.978863] agpgart-intel 0000:00:00.0: Intel 845G Chipset [ 8.978888] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable [ 8.979018] agpgart-intel 0000:00:00.0: detected 8192K stolen memory [ 8.979068] [drm] Memory usable by graphics device = 128M [ 8.979075] [drm] Replacing VGA console driver [ 8.984682] Console: switching to colour dummy device 80x25 [ 8.986065] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 8.986069] [drm] Driver supports precise vblank timestamp query. [ 8.986925] [drm:intel_bios_init [i915]] *ERROR* Unexpected child device config size 22 (expected 27 for VBT version 107) [ 8.993018] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem [ 9.000966] [drm] RC6 disabled, disabling runtime PM support [ 9.001147] [drm] initialized overlay support [ 9.005535] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0 [ 9.118962] fbcon: inteldrmfb (fb0) is primary device [ 9.277665] Console: switching to colour frame buffer device 160x64 [ 9.302111] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device [ 9.319611] iTCO_vendor_support: vendor-support=0 [ 9.326215] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11 [ 9.326314] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x0460) [ 9.327345] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 9.756998] Adding 514044k swap on /dev/sda5. Priority:-1 extents:1 across:514044k FS [ 14.816238] e100 0000:01:08.0 eth0: NIC Link is Up 100 Mbps Full Duplex [ 341.296222] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=3362217112 end=3362217113) time 126 us, min 1017, max 1023, scanline start 1015, end 1024 [ 642.867752] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1) [ 642.867955] mce: [Hardware Error]: Machine check events logged [ 642.869287] CPU0: Core temperature/speed normal [ 642.869342] mce: [Hardware Error]: Machine check events logged
6 years 11 months ago #150565 by cmorley
hm2_eth is included with linuxcnc - nothing to download.
Seems you have a network problem connecting to the board.
does your board use address 192.168.1.121?
In your other post you use 10.10.10.10
Chris
6 years 11 months ago #150566 by little_sparky
yeah I noticed that, I went in and changed it to 10.10.10.10 in the hal file, is this the way to do it? still had no luck connecting
6 years 11 months ago #150567 by cmorley
That is what to do.
network problems are not my strength.
if you open a terminal type halrun
then enter:
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10"
What happens?
Time to create page: 0.522 seconds
