PNCconf encountered an error
6 years 11 months ago - 6 years 11 months ago #150568 by little_sparky
jonty@jonty:~$ halrun halcmd: loadrt hostmot2 Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 halcmd: loadrt hm2_eth board_ip="10.10.10.10" hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: ERROR: 10.10.10.10: Could not retrieve mac address hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11) <stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_eth <stdin>:2: /usr/bin/rtapi_app exited without becoming ready <stdin>:2: insmod for hm2_eth failed, returned -1 halcmd: hm2: unloading Note: Using POSIX realtime jonty@jonty:~$
Last edit: 6 years 11 months ago by little_sparky.
6 years 11 months ago - 6 years 11 months ago #150584 by PCW
Replied by PCW on topic PNCconf encountered an error
What does the command
ip a
return? or
ping 10.10.10.10
Last edit: 6 years 11 months ago by PCW.
6 years 11 months ago - 6 years 11 months ago #150604 by little_sparky
ip a
jonty@jonty:~$ ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether 00:11:11:90:7c:9d brd ff:ff:ff:ff:ff:ff inet 10.10.10.11/24 brd 10.10.10.255 scope global eth0 valid_lft forever preferred_lft forever inet6 fe80::211:11ff:fe90:7c9d/64 scope link valid_lft forever preferred_lft forever jonty@jonty:~$
ping 10.10.10.10
jonty@jonty:~$ ping 10.10.10.10 PING 10.10.10.10 (10.10.10.10): 56 data bytes 64 bytes from 10.10.10.10: icmp_seq=0 ttl=64 time=0.243 ms 64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.233 ms 64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.369 ms 64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.236 ms 64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.245 ms 64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.244 ms 64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.232 ms 64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.236 ms ^C--- 10.10.10.10 ping statistics --- 8 packets transmitted, 8 packets received, 0% packet loss round-trip min/avg/max/stddev = 0.232/0.255/0.369/0.043 ms jonty@jonty:~$
mesaflash --device 7i76e --addr 10.10.10.10 --readhmi
jonty@jonty:~$ mesaflash --device 7i76e --addr 10.10.10.10 --readhmi Configuration Name: HOSTMOT2 General configuration information: BoardName : MESA7I76 FPGA Size: 16 KGates FPGA Pins: 256 Number of IO Ports: 3 Width of one I/O port: 17 Clock Low frequency: 100.0000 MHz Clock High frequency: 200.0000 MHz IDROM Type: 3 Instance Stride 0: 4 Instance Stride 1: 64 Register Stride 0: 256 Register Stride 1: 256 Modules in configuration: Module: DPLL There are 1 of DPLL in configuration Version: 0 Registers: 7 BaseAddress: 7000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: WatchDog There are 1 of WatchDog in configuration Version: 0 Registers: 3 BaseAddress: 0C00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: IOPort There are 3 of IOPort in configuration Version: 0 Registers: 5 BaseAddress: 1000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: StepGen There are 5 of StepGen in configuration Version: 2 Registers: 10 BaseAddress: 2000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: QCount There are 1 of QCount in configuration Version: 2 Registers: 5 BaseAddress: 3000 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Module: SSerial There are 1 of SSerial in configuration Version: 0 Registers: 6 BaseAddress: 5A00 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 64 bytes Module: LED There are 1 of LED in configuration Version: 0 Registers: 1 BaseAddress: 0200 ClockFrequency: 100.000 MHz Register Stride: 256 bytes Instance Stride: 4 bytes Configuration pin-out: IO Connections for on-card Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 0 IOPort StepGen 0 Dir/Table2 (Out) 14 1 IOPort StepGen 0 Step/Table1 (Out) 2 2 IOPort StepGen 1 Dir/Table2 (Out) 15 3 IOPort StepGen 1 Step/Table1 (Out) 3 4 IOPort StepGen 2 Dir/Table2 (Out) 16 5 IOPort StepGen 2 Step/Table1 (Out) 4 6 IOPort StepGen 3 Dir/Table2 (Out) 17 7 IOPort StepGen 3 Step/Table1 (Out) 5 8 IOPort StepGen 4 Dir/Table2 (Out) 6 9 IOPort StepGen 4 Step/Table1 (Out) 7 10 IOPort SSerial 0 TXData1 (Out) 8 11 IOPort SSerial 0 RXData1 (In) 9 12 IOPort SSerial 0 TXData2 (Out) 10 13 IOPort SSerial 0 RXData2 (In) 11 14 IOPort QCount 0 Quad-IDX (In) 12 15 IOPort QCount 0 Quad-B (In) 13 16 IOPort QCount 0 Quad-A (In) IO Connections for P1 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 17 IOPort None 14 18 IOPort None 2 19 IOPort None 15 20 IOPort None 3 21 IOPort None 16 22 IOPort None 4 23 IOPort None 17 24 IOPort None 5 25 IOPort None 6 26 IOPort None 7 27 IOPort None 8 28 IOPort None 9 29 IOPort None 10 30 IOPort None 11 31 IOPort None 12 32 IOPort None 13 33 IOPort None IO Connections for P2 Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir 1 34 IOPort None 14 35 IOPort None 2 36 IOPort None 15 37 IOPort None 3 38 IOPort None 16 39 IOPort None 4 40 IOPort None 17 41 IOPort None 5 42 IOPort None 6 43 IOPort None 7 44 IOPort None 8 45 IOPort None 9 46 IOPort None 10 47 IOPort None 11 48 IOPort None 12 49 IOPort None 13 50 IOPort None jonty@jonty:~$
uname -v
jonty@jonty:~$ uname -v #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) jonty@jonty:~$ uname -a
uname -a
jonty@jonty:~$ uname -a Linux jonty 4.9.0-8-rt-686-pae #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) i686 GNU/Linux
hal
# Generated by PNCconf at Mon Nov 18 17:28:25 2019 # If you make changes to this file, they will be # overwritten when you run PNCconf again loadrt trivkins loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES loadrt hostmot2 loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx" setp hm2_7i76e.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.z,pid.s addf hm2_7i76e.0.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf pid.x.do-pid-calcs servo-thread addf pid.y.do-pid-calcs servo-thread addf pid.z.do-pid-calcs servo-thread addf pid.s.do-pid-calcs servo-thread addf hm2_7i76e.0.write servo-thread setp hm2_7i76e.0.dpll.01.timer-us -50 setp hm2_7i76e.0.stepgen.timer-number 1 # external output signals # external input signals #******************* # AXIS X #******************* setp pid.x.Pgain [AXIS_0]P setp pid.x.Igain [AXIS_0]I setp pid.x.Dgain [AXIS_0]D setp pid.x.bias [AXIS_0]BIAS setp pid.x.FF0 [AXIS_0]FF0 setp pid.x.FF1 [AXIS_0]FF1 setp pid.x.FF2 [AXIS_0]FF2 setp pid.x.deadband [AXIS_0]DEADBAND setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT setp pid.x.error-previous-target true setp pid.x.maxerror .0005 net x-index-enable <=> pid.x.index-enable net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.01.dirsetup [AXIS_0]DIRSETUP setp hm2_7i76e.0.stepgen.01.dirhold [AXIS_0]DIRHOLD setp hm2_7i76e.0.stepgen.01.steplen [AXIS_0]STEPLEN setp hm2_7i76e.0.stepgen.01.stepspace [AXIS_0]STEPSPACE setp hm2_7i76e.0.stepgen.01.position-scale [AXIS_0]STEP_SCALE setp hm2_7i76e.0.stepgen.01.step_type 0 setp hm2_7i76e.0.stepgen.01.control-type 1 setp hm2_7i76e.0.stepgen.01.maxaccel [AXIS_0]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.01.maxvel [AXIS_0]STEPGEN_MAXVEL # ---closedloop stepper signals--- net x-pos-cmd <= axis.0.motor-pos-cmd net x-vel-cmd <= axis.0.joint-vel-cmd net x-output => hm2_7i76e.0.stepgen.01.velocity-cmd net x-pos-fb <= hm2_7i76e.0.stepgen.01.position-fb net x-pos-fb => axis.0.motor-pos-fb net x-enable <= axis.0.amp-enable-out net x-enable => hm2_7i76e.0.stepgen.01.enable # ---setup home / limit switch signals--- net x-home-sw => axis.0.home-sw-in net x-neg-limit => axis.0.neg-lim-sw-in net x-pos-limit => axis.0.pos-lim-sw-in #******************* # AXIS Y #******************* setp pid.y.Pgain [AXIS_1]P setp pid.y.Igain [AXIS_1]I setp pid.y.Dgain [AXIS_1]D setp pid.y.bias [AXIS_1]BIAS setp pid.y.FF0 [AXIS_1]FF0 setp pid.y.FF1 [AXIS_1]FF1 setp pid.y.FF2 [AXIS_1]FF2 setp pid.y.deadband [AXIS_1]DEADBAND setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT setp pid.y.error-previous-target true setp pid.y.maxerror .0005 net y-index-enable <=> pid.y.index-enable net y-enable => pid.y.enable net y-pos-cmd => pid.y.command net y-vel-cmd => pid.y.command-deriv net y-pos-fb => pid.y.feedback net y-output => pid.y.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.02.dirsetup [AXIS_1]DIRSETUP setp hm2_7i76e.0.stepgen.02.dirhold [AXIS_1]DIRHOLD setp hm2_7i76e.0.stepgen.02.steplen [AXIS_1]STEPLEN setp hm2_7i76e.0.stepgen.02.stepspace [AXIS_1]STEPSPACE setp hm2_7i76e.0.stepgen.02.position-scale [AXIS_1]STEP_SCALE setp hm2_7i76e.0.stepgen.02.step_type 0 setp hm2_7i76e.0.stepgen.02.control-type 1 setp hm2_7i76e.0.stepgen.02.maxaccel [AXIS_1]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.02.maxvel [AXIS_1]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y-pos-cmd <= axis.1.motor-pos-cmd net y-vel-cmd <= axis.1.joint-vel-cmd net y-output => hm2_7i76e.0.stepgen.02.velocity-cmd net y-pos-fb <= hm2_7i76e.0.stepgen.02.position-fb net y-pos-fb => axis.1.motor-pos-fb net y-enable <= axis.1.amp-enable-out net y-enable => hm2_7i76e.0.stepgen.02.enable # Step Gen signals/setup for tandem axis stepper setp hm2_7i76e.0.stepgen.03.dirsetup [AXIS_1]DIRSETUP setp hm2_7i76e.0.stepgen.03.dirhold [AXIS_1]DIRHOLD setp hm2_7i76e.0.stepgen.03.steplen [AXIS_1]STEPLEN setp hm2_7i76e.0.stepgen.03.stepspace [AXIS_1]STEPSPACE setp hm2_7i76e.0.stepgen.03.position-scale [AXIS_1]STEP_SCALE setp hm2_7i76e.0.stepgen.03.step_type 0 setp hm2_7i76e.0.stepgen.03.control-type 1 setp hm2_7i76e.0.stepgen.03.maxaccel [AXIS_1]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.03.maxvel [AXIS_1]STEPGEN_MAXVEL # ---Tandem stepper signals--- net y-output => hm2_7i76e.0.stepgen.03.velocity-cmd net y-enable => hm2_7i76e.0.stepgen.03.enable # ---setup home / limit switch signals--- net y-home-sw => axis.1.home-sw-in net y-neg-limit => axis.1.neg-lim-sw-in net y-pos-limit => axis.1.pos-lim-sw-in #******************* # AXIS Z #******************* setp pid.z.Pgain [AXIS_2]P setp pid.z.Igain [AXIS_2]I setp pid.z.Dgain [AXIS_2]D setp pid.z.bias [AXIS_2]BIAS setp pid.z.FF0 [AXIS_2]FF0 setp pid.z.FF1 [AXIS_2]FF1 setp pid.z.FF2 [AXIS_2]FF2 setp pid.z.deadband [AXIS_2]DEADBAND setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT setp pid.z.error-previous-target true setp pid.z.maxerror .0005 net z-index-enable <=> pid.z.index-enable net z-enable => pid.z.enable net z-pos-cmd => pid.z.command net z-vel-cmd => pid.z.command-deriv net z-pos-fb => pid.z.feedback net z-output => pid.z.output # Step Gen signals/setup setp hm2_7i76e.0.stepgen.00.dirsetup [AXIS_2]DIRSETUP setp hm2_7i76e.0.stepgen.00.dirhold [AXIS_2]DIRHOLD setp hm2_7i76e.0.stepgen.00.steplen [AXIS_2]STEPLEN setp hm2_7i76e.0.stepgen.00.stepspace [AXIS_2]STEPSPACE setp hm2_7i76e.0.stepgen.00.position-scale [AXIS_2]STEP_SCALE setp hm2_7i76e.0.stepgen.00.step_type 0 setp hm2_7i76e.0.stepgen.00.control-type 1 setp hm2_7i76e.0.stepgen.00.maxaccel [AXIS_2]STEPGEN_MAXACCEL setp hm2_7i76e.0.stepgen.00.maxvel [AXIS_2]STEPGEN_MAXVEL # ---closedloop stepper signals--- net z-pos-cmd <= axis.2.motor-pos-cmd net z-vel-cmd <= axis.2.joint-vel-cmd net z-output => hm2_7i76e.0.stepgen.00.velocity-cmd net z-pos-fb <= hm2_7i76e.0.stepgen.00.position-fb net z-pos-fb => axis.2.motor-pos-fb net z-enable <= axis.2.amp-enable-out net z-enable => hm2_7i76e.0.stepgen.00.enable # ---setup home / limit switch signals--- net z-home-sw => axis.2.home-sw-in net z-neg-limit => axis.2.neg-lim-sw-in net z-pos-limit => axis.2.pos-lim-sw-in #******************* # SPINDLE S #******************* setp pid.s.Pgain [SPINDLE_9]P setp pid.s.Igain [SPINDLE_9]I setp pid.s.Dgain [SPINDLE_9]D setp pid.s.bias [SPINDLE_9]BIAS setp pid.s.FF0 [SPINDLE_9]FF0 setp pid.s.FF1 [SPINDLE_9]FF1 setp pid.s.FF2 [SPINDLE_9]FF2 setp pid.s.deadband [SPINDLE_9]DEADBAND setp pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT setp pid.s.error-previous-target true net spindle-index-enable <=> pid.s.index-enable net spindle-enable => pid.s.enable net spindle-vel-cmd-rpm => pid.s.command net spindle-vel-fb-rpm => pid.s.feedback net spindle-output <= pid.s.output # ---setup spindle control signals--- net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs net spindle-vel-cmd-rpm <= motion.spindle-speed-out net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs net spindle-enable <= motion.spindle-on net spindle-cw <= motion.spindle-forward net spindle-ccw <= motion.spindle-reverse net spindle-brake <= motion.spindle-brake net spindle-revs => motion.spindle-revs net spindle-at-speed => motion.spindle-at-speed net spindle-vel-fb-rps => motion.spindle-speed-in net spindle-index-enable <=> motion.spindle-index-enable # ---Setup spindle at speed signals--- sets spindle-at-speed true #****************************** # connect miscellaneous signals #****************************** # ---HALUI signals--- net joint-select-a halui.joint.0.select net x-is-homed halui.joint.0.is-homed net jog-x-pos halui.jog.0.plus net jog-x-neg halui.jog.0.minus net jog-x-analog halui.jog.0.analog net joint-select-b halui.joint.1.select net y-is-homed halui.joint.1.is-homed net jog-y-pos halui.jog.1.plus net jog-y-neg halui.jog.1.minus net jog-y-analog halui.jog.1.analog net joint-select-c halui.joint.2.select net z-is-homed halui.joint.2.is-homed net jog-z-pos halui.jog.2.plus net jog-z-neg halui.jog.2.minus net jog-z-analog halui.jog.2.analog net jog-selected-pos halui.jog.selected.plus net jog-selected-neg halui.jog.selected.minus net spindle-manual-cw halui.spindle.forward net spindle-manual-ccw halui.spindle.reverse net spindle-manual-stop halui.spindle.stop net machine-is-on halui.machine.is-on net jog-speed halui.jog-speed net MDI-mode halui.mode.is-mdi # ---coolant signals--- net coolant-mist <= iocontrol.0.coolant-mist net coolant-flood <= iocontrol.0.coolant-flood # ---probe signal--- net probe-in => motion.probe-input # ---motion control signals--- net in-position <= motion.in-position net machine-is-enabled <= motion.motion-enabled # ---digital in / out signals--- # ---estop signals--- net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in # ---toolchange signals for custom tool changer--- net tool-number <= iocontrol.0.tool-prep-number net tool-change-request <= iocontrol.0.tool-change net tool-change-confirmed => iocontrol.0.tool-changed net tool-prepare-request <= iocontrol.0.tool-prepare net tool-prepare-confirmed => iocontrol.0.tool-prepared
ini
# Generated by PNCconf at Mon Nov 18 17:28:25 2019 # If you make changes to this file, they will be # overwritten when you run PNCconf again [EMC] MACHINE = my_TESTLinuxCNC_machine DEBUG = 0 [DISPLAY] DISPLAY = axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 2.000000 MAX_SPINDLE_OVERRIDE = 1.000000 MIN_SPINDLE_OVERRIDE = 0.500000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/jonty/linuxcnc/nc_files INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 6.000000 MAX_LINEAR_VELOCITY = 25.000000 MIN_LINEAR_VELOCITY = 0.500000 DEFAULT_ANGULAR_VELOCITY = 12.000000 MAX_ANGULAR_VELOCITY = 180.000000 MIN_ANGULAR_VELOCITY = 1.666667 EDITOR = gedit GEOMETRY = xyz [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 SERVO_PERIOD = 170000 [HOSTMOT2] # **** This is for info only **** # DRIVER0=hm2_eth # BOARD0=7i76e [HAL] HALUI = halui HALFILE = my_TESTLinuxCNC_machine.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal [HALUI] [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = mm ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 2.50 MAX_LINEAR_VELOCITY = 25.00 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl #******************** # Axis X #******************** [AXIS_0] TYPE = LINEAR HOME = 0.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 31.25 STEPGEN_MAXACCEL = 937.50 P = 5882.35294118 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 # these are in nanoseconds DIRSETUP = 6000 DIRHOLD = 8000 STEPLEN = 1800 STEPSPACE = 1800 STEP_SCALE = 1200.0 MIN_LIMIT = -0.01 MAX_LIMIT = 1200.0 HOME_OFFSET = 0.0 #******************** # Axis Y #******************** [AXIS_1] TYPE = LINEAR HOME = 0.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 31.25 STEPGEN_MAXACCEL = 937.50 P = 5882.35294118 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 # these are in nanoseconds DIRSETUP = 6000 DIRHOLD = 8000 STEPLEN = 1800 STEPSPACE = 1800 STEP_SCALE = 1200.0 MIN_LIMIT = -0.01 MAX_LIMIT = 2400.0 HOME_OFFSET = 0.0 #******************** # Axis Z #******************** [AXIS_2] TYPE = LINEAR HOME = 0.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 750.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 31.25 STEPGEN_MAXACCEL = 937.50 P = 5882.35294118 I = 0.0 D = 0.0 FF0 = 0.0 FF1 = 1.0 FF2 = 0.0 BIAS = 0.0 DEADBAND = 0.0 MAX_OUTPUT = 0.0 # these are in nanoseconds DIRSETUP = 6000 DIRHOLD = 8000 STEPLEN = 1800 STEPSPACE = 1800 STEP_SCALE = 80.0 MIN_LIMIT = -100.0 MAX_LIMIT = 0.01 HOME_OFFSET = 0.0 #******************** # Spindle #******************** [SPINDLE_9] P = 0 I = 0 D = 0 FF0 = 1 FF1 = 0 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 2000
error message
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.7.14 Machine configuration directory is '/home/jonty/linuxcnc/configs/my_TESTLinuxCNC_machine' Machine configuration file is 'my_TESTLinuxCNC_machine.ini' INIFILE=/home/jonty/linuxcnc/configs/my_TESTLinuxCNC_machine/my_TESTLinuxCNC_machine.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./my_TESTLinuxCNC_machine.hal hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: ERROR: 192.168.1.121: Could not retrieve mac address Shutting down and cleaning up LinuxCNC... Running HAL shutdown script Killing task linuxcncsvr, PID=1296 hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime Unexpected realtime delay on task 0 This Message will only display once per session. Run the Latency Test and resolve before continuing. iptables: No chain/target/match by that name. hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11) ./my_TESTLinuxCNC_machine.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth ./my_TESTLinuxCNC_machine.hal:8: /usr/bin/rtapi_app exited without becoming ready ./my_TESTLinuxCNC_machine.hal:8: insmod for hm2_eth failed, returned -1 1296 PID TTY STAT TIME COMMAND Stopping realtime threads Unloading hal components Note: Using POSIX realtime Kernel message information: [ 0.000000] Linux version 4.9.0-8-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) [ 0.000000] CPU0: Hyper-Threading is disabled [ 0.000000] x86/fpu: Legacy x87 FPU detected. [ 0.000000] e820: BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable [ 0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001f73ffff] usable [ 0.000000] BIOS-e820: [mem 0x000000001f740000-0x000000001f74ffff] ACPI data [ 0.000000] BIOS-e820: [mem 0x000000001f750000-0x000000001f7fffff] ACPI NVS [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU! [ 0.000000] SMBIOS 2.3 present. [ 0.000000] DMI: /D845GVSR , BIOS VA84510A.86A.0050.P18.0409222329 09/22/2004 [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable [ 0.000000] e820: last_pfn = 0x1f740 max_arch_pfn = 0x1000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-DFFFF uncachable [ 0.000000] E0000-FFFFF write-back [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask FE0000000 write-back [ 0.000000] 1 base 01F800000 mask FFF800000 uncachable [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WC UC- UC [ 0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [c00ff780] [ 0.000000] initial memory mapped: [mem 0x00000000-0x0dffffff] [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] BRK [0x0da51000, 0x0da51fff] PGTABLE [ 0.000000] BRK [0x0da52000, 0x0da53fff] PGTABLE [ 0.000000] BRK [0x0da54000, 0x0da54fff] PGTABLE [ 0.000000] BRK [0x0da55000, 0x0da55fff] PGTABLE [ 0.000000] RAMDISK: [mem 0x1d0f2000-0x1e70cfff] [ 0.000000] ACPI: Early table checksum verification disabled [ 0.000000] ACPI: RSDP 0x00000000000F77A0 000014 (v00 ACPIAM) [ 0.000000] ACPI: RSDT 0x000000001F740000 000030 (v01 INTEL D845GVS1 20040922 MSFT 00000097) [ 0.000000] ACPI: FACP 0x000000001F740200 000074 (v01 INTEL D845GVS1 20040922 MSFT 00000097) [ 0.000000] ACPI: DSDT 0x000000001F740370 00415D (v01 INTEL D845GVS1 0000010A MSFT 0100000D) [ 0.000000] ACPI: FACS 0x000000001F750000 000040 [ 0.000000] ACPI: APIC 0x000000001F740300 000068 (v01 INTEL D845GVS1 20040922 MSFT 00000097) [ 0.000000] ACPI: ASF! 0x000000001F7444D0 000084 (v16 AMIASF I845GASF 00000001 MSFT 0100000D) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 0MB HIGHMEM available. [ 0.000000] 503MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 1f740000 [ 0.000000] low ram: 0 - 1f740000 [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000001000-0x0000000000ffffff] [ 0.000000] Normal [mem 0x0000000001000000-0x000000001f73ffff] [ 0.000000] HighMem empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000001000-0x000000000009efff] [ 0.000000] node 0: [mem 0x0000000000100000-0x000000001f73ffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000001f73ffff] [ 0.000000] On node 0 totalpages: 128734 [ 0.000000] free_area_init_node: node 0, pgdat cd829780, node_mem_map df254028 [ 0.000000] DMA zone: 40 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3998 pages, LIFO batch:0 [ 0.000000] Normal zone: 1219 pages used for memmap [ 0.000000] Normal zone: 124736 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] Reserving Intel graphics memory at 0x000000001f800000-0x000000001fffffff [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1]) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1]) [ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] smpboot: Allowing 2 CPUs, 1 hotplug CPUs [ 0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff] [ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff] [ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff] [ 0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff] [ 0.000000] e820: [mem 0x20000000-0xffffffff] available for PCI devices [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns [ 0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1 [ 0.000000] percpu: Embedded 101 pages/cpu @df187000 s381472 r0 d32224 u413696 [ 0.000000] pcpu-alloc: s381472 r0 d32224 u413696 alloc=101*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 127475 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-686-pae root=/dev/sda1 ro quiet [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] Initializing HighMem for node 0 (00000000:00000000) [ 0.000000] Memory: 475136K/514936K available (6035K kernel code, 628K rwdata, 1756K rodata, 1060K init, 592K bss, 39800K reserved, 0K cma-reserved, 0K highmem) [ 0.000000] virtual kernel memory layout: fixmap : 0xffd36000 - 0xfffff000 (2852 kB) pkmap : 0xffa00000 - 0xffc00000 (2048 kB) vmalloc : 0xdff40000 - 0xff9fe000 ( 506 MB) lowmem : 0xc0000000 - 0xdf740000 ( 503 MB) .init : 0xcd83d000 - 0xcd946000 (1060 kB) .data : 0xcd5e51f4 - 0xcd83b280 (2392 kB) .text : 0xcd000000 - 0xcd5e51f4 (6036 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] SLUB: HWalign=128, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2. [ 0.000000] RCU kthread priority: 1. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS:2304 nr_irqs:440 16 [ 0.000000] CPU 0 irqstacks, hard=dec3e000 soft=dec80000 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] tsc: Fast TSC calibration using PIT [ 0.000000] tsc: Detected 2400.225 MHz processor [ 0.004007] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.45 BogoMIPS (lpj=9600900) [ 0.004010] pid_max: default: 32768 minimum: 301 [ 0.004058] ACPI: Core revision 20160831 [ 0.012292] ACPI: 1 ACPI AML tables successfully acquired and loaded [ 0.012360] Security Framework initialized [ 0.012363] Yama: disabled by default; enable with sysctl kernel.yama.* [ 0.012376] AppArmor: AppArmor disabled by boot time parameter [ 0.012404] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.012406] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.013019] mce: CPU supports 4 MCE banks [ 0.013034] CPU0: Thermal monitoring enabled (TM1) [ 0.013049] process: using mwait in idle threads [ 0.013064] Last level iTLB entries: 4KB 128, 2MB 128, 4MB 128 [ 0.013066] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0 [ 0.013070] Spectre V2 : Mitigation: Full generic retpoline [ 0.013071] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch [ 0.013072] Speculative Store Bypass: Vulnerable [ 0.035018] ftrace: allocating 24078 entries in 48 pages [ 0.064275] smpboot: Max logical packages: 2 [ 0.064291] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.064674] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 [ 0.108000] smpboot: CPU0: Intel(R) Celeron(R) CPU 2.40GHz (family: 0xf, model: 0x4, stepping: 0x1) [ 0.108000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver. [ 0.108000] ... version: 0 [ 0.108000] ... bit width: 40 [ 0.108000] ... generic registers: 18 [ 0.108000] ... value mask: 000000ffffffffff [ 0.108000] ... max period: 0000007fffffffff [ 0.108000] ... fixed-purpose events: 0 [ 0.108000] ... event mask: 000000000003ffff [ 0.160117] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter. [ 0.168022] x86: Booted up 1 node, 1 CPUs [ 0.168029] smpboot: Total of 1 processors activated (4800.45 BogoMIPS) [ 0.168905] devtmpfs: initialized [ 0.172111] PM: Registering ACPI NVS region [mem 0x1f750000-0x1f7fffff] (720896 bytes) [ 0.172308] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.172318] futex hash table entries: 512 (order: 3, 32768 bytes) [ 0.172403] pinctrl core: initialized pinctrl subsystem [ 0.172759] NET: Registered protocol family 16 [ 0.176060] cpuidle: using governor ladder [ 0.176079] cpuidle: using governor menu [ 0.176188] ACPI: bus type PCI registered [ 0.176194] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.176345] PCI: Using configuration type 1 for base access [ 0.180217] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.196214] ACPI: Added _OSI(Module Device) [ 0.196219] ACPI: Added _OSI(Processor Device) [ 0.196221] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.196224] ACPI: Added _OSI(Processor Aggregator Device) [ 0.196739] ACPI: Executed 2 blocks of module-level executable AML code [ 0.202314] ACPI: Interpreter enabled [ 0.202369] ACPI: (supports S0 S1 S4 S5) [ 0.202372] ACPI: Using IOAPIC for interrupt routing [ 0.202466] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.207155] ACPI: Power Resource [URP1] (off) [ 0.207269] ACPI: Power Resource [URP2] (off) [ 0.207375] ACPI: Power Resource [FDDP] (off) [ 0.207492] ACPI: Power Resource [LPTP] (off) [ 0.215331] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.215345] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI] [ 0.215357] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM [ 0.215365] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge. [ 0.215770] PCI host bridge to bus 0000:00 [ 0.215777] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window] [ 0.215781] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window] [ 0.215785] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window] [ 0.215788] pci_bus 0000:00: root bus resource [mem 0x1f800000-0xffffffff window] [ 0.215793] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.215815] pci 0000:00:00.0: [8086:2560] type 00 class 0x060000 [ 0.215832] pci 0000:00:00.0: reg 0x10: [mem 0xe0000000-0xefffffff pref] [ 0.216134] pci 0000:00:02.0: [8086:2562] type 00 class 0x030000 [ 0.216158] pci 0000:00:02.0: reg 0x10: [mem 0xf0000000-0xf7ffffff pref] [ 0.216170] pci 0000:00:02.0: reg 0x14: [mem 0xffa80000-0xffafffff] [ 0.216432] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300 [ 0.216492] pci 0000:00:1d.0: reg 0x20: [io 0xe800-0xe81f] [ 0.216663] pci 0000:00:1d.0: System wakeup disabled by ACPI [ 0.216789] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300 [ 0.216850] pci 0000:00:1d.1: reg 0x20: [io 0xe880-0xe89f] [ 0.217018] pci 0000:00:1d.1: System wakeup disabled by ACPI [ 0.217137] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300 [ 0.217197] pci 0000:00:1d.2: reg 0x20: [io 0xec00-0xec1f] [ 0.217362] pci 0000:00:1d.2: System wakeup disabled by ACPI [ 0.217486] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320 [ 0.217515] pci 0000:00:1d.7: reg 0x10: [mem 0xffa7fc00-0xffa7ffff] [ 0.217640] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.217771] pci 0000:00:1d.7: System wakeup disabled by ACPI [ 0.217879] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400 [ 0.218012] pci 0000:00:1e.0: System wakeup disabled by ACPI [ 0.218120] pci 0000:00:1f.0: [8086:24c0] type 00 class 0x060100 [ 0.218127] * The chipset may have PM-Timer Bug. Due to workarounds for a bug, * this clock source is slow. If you are sure your timer does not have * this bug, please use "acpi_pm_good" to disable the workaround [ 0.218221] pci 0000:00:1f.0: quirk: [io 0x0400-0x047f] claimed by ICH4 ACPI/GPIO/TCO [ 0.218228] pci 0000:00:1f.0: quirk: [io 0x0480-0x04bf] claimed by ICH4 GPIO [ 0.218405] pci 0000:00:1f.1: [8086:24cb] type 00 class 0x01018a [ 0.218427] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007] [ 0.218440] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003] [ 0.218452] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007] [ 0.218465] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003] [ 0.218478] pci 0000:00:1f.1: reg 0x20: [io 0xffa0-0xffaf] [ 0.218492] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff] [ 0.218509] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io 0x01f0-0x01f7] [ 0.218512] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io 0x03f6] [ 0.218515] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io 0x0170-0x0177] [ 0.218518] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io 0x0376] [ 0.218690] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500 [ 0.218749] pci 0000:00:1f.3: reg 0x20: [io 0xe000-0xe01f] [ 0.218933] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100 [ 0.218955] pci 0000:00:1f.5: reg 0x10: [io 0xe400-0xe4ff] [ 0.218967] pci 0000:00:1f.5: reg 0x14: [io 0xe080-0xe0bf] [ 0.218980] pci 0000:00:1f.5: reg 0x18: [mem 0xffa7f800-0xffa7f9ff] [ 0.218992] pci 0000:00:1f.5: reg 0x1c: [mem 0xffa7f400-0xffa7f4ff] [ 0.219060] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold [ 0.219297] pci 0000:01:00.0: [11c1:048c] type 00 class 0x078000 [ 0.219320] pci 0000:01:00.0: reg 0x10: [mem 0xff8ffc00-0xff8ffcff] [ 0.219333] pci 0000:01:00.0: reg 0x14: [io 0xdc00-0xdc07] [ 0.219346] pci 0000:01:00.0: reg 0x18: [io 0xd800-0xd8ff] [ 0.219429] pci 0000:01:00.0: supports D2 [ 0.219433] pci 0000:01:00.0: PME# supported from D2 D3hot D3cold [ 0.219572] pci 0000:01:08.0: [8086:1039] type 00 class 0x020000 [ 0.219594] pci 0000:01:08.0: reg 0x10: [mem 0xff8fe000-0xff8fefff] [ 0.219607] pci 0000:01:08.0: reg 0x14: [io 0xd480-0xd4bf] [ 0.219694] pci 0000:01:08.0: supports D1 D2 [ 0.219698] pci 0000:01:08.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.219841] pci 0000:00:1e.0: PCI bridge to [bus 01] (subtractive decode) [ 0.219848] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff] [ 0.219855] pci 0000:00:1e.0: bridge window [mem 0xff800000-0xff8fffff] [ 0.219861] pci 0000:00:1e.0: bridge window [mem 0xcea00000-0xceafffff pref] [ 0.219865] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7 window] (subtractive decode) [ 0.219869] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff window] (subtractive decode) [ 0.219872] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode) [ 0.219876] pci 0000:00:1e.0: bridge window [mem 0x1f800000-0xffffffff window] (subtractive decode) [ 0.219892] pci_bus 0000:00: on NUMA node 0 [ 0.222153] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.222360] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 9 10 11 12 14 15) [ 0.222556] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 14 15) [ 0.222748] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 9 10 11 12 14 15) [ 0.222939] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.223137] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12 14 15) [ 0.223330] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled. [ 0.223524] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 14 15) [ 0.224251] vgaarb: setting as boot device: PCI:0000:00:02.0 [ 0.224257] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.224267] vgaarb: loaded [ 0.224270] vgaarb: bridge control possible 0000:00:02.0 [ 0.228073] PCI: Using ACPI for IRQ routing [ 0.228081] PCI: pci_cache_line_size set to 64 bytes [ 0.228147] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff] [ 0.228153] e820: reserve RAM buffer [mem 0x1f740000-0x1fffffff] [ 0.232228] clocksource: Switched to clocksource refined-jiffies [ 0.257571] VFS: Disk quotas dquot_6.6.0 [ 0.257636] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.257911] pnp: PnP ACPI init [ 0.258115] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.258648] system 00:01: [io 0x04d0-0x04d1] has been reserved [ 0.258661] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.258868] pnp 00:02: [dma 2] [ 0.259007] pnp 00:02: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.259602] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.260444] pnp 00:04: [dma 3] [ 0.260649] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active) [ 0.261661] system 00:05: [io 0x0400-0x047f] has been reserved [ 0.261668] system 00:05: [io 0x0680-0x06ff] has been reserved [ 0.261672] system 00:05: [io 0x0480-0x04bf] has been reserved [ 0.261680] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved [ 0.261687] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved [ 0.261699] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.262268] system 00:06: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.262276] system 00:06: [mem 0x000c0000-0x000dffff] could not be reserved [ 0.262281] system 00:06: [mem 0x000e0000-0x000fffff] could not be reserved [ 0.262285] system 00:06: [mem 0x00100000-0x1f7fffff] could not be reserved [ 0.262294] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.262740] pnp: PnP ACPI: found 7 devices [ 0.262749] PnPBIOS: Disabled [ 0.303422] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns [ 0.303450] clocksource: Switched to clocksource acpi_pm [ 0.303501] pci 0000:00:1f.1: BAR 5: assigned [mem 0x20000000-0x200003ff] [ 0.303514] pci 0000:00:1e.0: PCI bridge to [bus 01] [ 0.303519] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff] [ 0.303527] pci 0000:00:1e.0: bridge window [mem 0xff800000-0xff8fffff] [ 0.303533] pci 0000:00:1e.0: bridge window [mem 0xcea00000-0xceafffff pref] [ 0.303544] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window] [ 0.303548] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window] [ 0.303551] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window] [ 0.303555] pci_bus 0000:00: resource 7 [mem 0x1f800000-0xffffffff window] [ 0.303558] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff] [ 0.303562] pci_bus 0000:01: resource 1 [mem 0xff800000-0xff8fffff] [ 0.303565] pci_bus 0000:01: resource 2 [mem 0xcea00000-0xceafffff pref] [ 0.303568] pci_bus 0000:01: resource 4 [io 0x0000-0x0cf7 window] [ 0.303571] pci_bus 0000:01: resource 5 [io 0x0d00-0xffff window] [ 0.303575] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff window] [ 0.303578] pci_bus 0000:01: resource 7 [mem 0x1f800000-0xffffffff window] [ 0.303734] NET: Registered protocol family 2 [ 0.303986] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.303986] TCP bind hash table entries: 4096 (order: 4, 114688 bytes) [ 0.303986] TCP: Hash tables configured (established 4096 bind 4096) [ 0.303986] UDP hash table entries: 256 (order: 2, 16384 bytes) [ 0.303986] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes) [ 0.303986] NET: Registered protocol family 1 [ 0.303986] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff] [ 0.303986] pci 0000:01:08.0: Firmware left e100 interrupts enabled; disabling [ 0.303986] PCI: CLS 64 bytes, default 64 [ 0.303986] Unpacking initramfs... [ 1.241459] Freeing initrd memory: 22636K [ 1.242496] audit: initializing netlink subsys (disabled) [ 1.242549] audit: type=2000 audit(1574126189.239:1): initialized [ 1.247532] workingset: timestamp_bits=14 max_order=17 bucket_order=3 [ 1.251906] zbud: loaded [ 1.254335] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) [ 1.258513] io scheduler noop registered [ 1.258517] io scheduler deadline registered [ 1.258640] io scheduler cfq registered (default) [ 1.258921] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 1.258936] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 1.259215] GHES: HEST is not enabled! [ 1.259369] isapnp: Scanning for PnP cards... [ 1.613916] isapnp: No Plug & Play device found [ 1.614155] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.634685] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A [ 1.635731] Linux agpgart interface v0.103 [ 1.635941] agpgart-intel 0000:00:00.0: Intel 845G Chipset [ 1.648635] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000 [ 1.649118] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.652552] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.652570] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.653000] mousedev: PS/2 mouse device common for all mice [ 1.653096] rtc_cmos 00:00: RTC can wake from S4 [ 1.653391] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0 [ 1.653543] rtc_cmos 00:00: alarms up to one month, 114 bytes nvram [ 1.654815] NET: Registered protocol family 10 [ 1.659596] mip6: Mobile IPv6 [ 1.659604] NET: Registered protocol family 17 [ 1.659614] mpls_gso: MPLS GSO support [ 1.660239] microcode: sig=0xf41, pf=0x4, revision=0x17 [ 1.660387] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 1.660401] Using IPI No-Shortcut mode [ 1.660816] registered taskstats version 1 [ 1.660893] zswap: loaded using pool lzo/zbud [ 1.660983] ima: No TPM chip found, activating TPM-bypass! [ 1.660989] ima: Allocated hash algorithm: sha256 [ 1.665520] rtc_cmos 00:00: setting system clock to 2019-11-19 01:16:30 UTC (1574126190) [ 1.665602] PM: Hibernation image not present or could not be loaded. [ 1.667167] Freeing unused kernel memory: 1060K [ 1.667338] Write protecting the kernel text: 6040k [ 1.667471] Write protecting the kernel read-only data: 1760k [ 1.721439] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 1.721729] random: systemd-udevd: uninitialized urandom read (16 bytes read) [ 1.724822] random: udevadm: uninitialized urandom read (16 bytes read) [ 1.885990] ACPI: bus type USB registered [ 1.886070] usbcore: registered new interface driver usbfs [ 1.886103] usbcore: registered new interface driver hub [ 1.889338] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI [ 1.889342] e100: Copyright(c) 1999-2006 Intel Corporation [ 1.896653] usbcore: registered new device driver usb [ 1.898368] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.900501] ehci-pci: EHCI PCI platform driver [ 1.900817] ehci-pci 0000:00:1d.7: EHCI Host Controller [ 1.900837] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1 [ 1.900863] ehci-pci 0000:00:1d.7: debug port 1 [ 1.902974] uhci_hcd: USB Universal Host Controller Interface driver [ 1.908659] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported [ 1.913406] ehci-pci 0000:00:1d.7: irq 23, io mem 0xffa7fc00 [ 1.919204] SCSI subsystem initialized [ 1.928192] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 1.928443] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.928448] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.928452] usb usb1: Product: EHCI Host Controller [ 1.928455] usb usb1: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd [ 1.928458] usb usb1: SerialNumber: 0000:00:1d.7 [ 1.928924] hub 1-0:1.0: USB hub found [ 1.928958] hub 1-0:1.0: 6 ports detected [ 1.929711] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 1.929729] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 1.929743] uhci_hcd 0000:00:1d.0: detected 2 ports [ 1.937079] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000e800 [ 1.937291] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.937296] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.937299] usb usb2: Product: UHCI Host Controller [ 1.937303] usb usb2: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd [ 1.937306] usb usb2: SerialNumber: 0000:00:1d.0 [ 1.937743] hub 2-0:1.0: USB hub found [ 1.937787] hub 2-0:1.0: 2 ports detected [ 1.938360] i801_smbus 0000:00:1f.3: SMBus using polling [ 1.938808] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 1.938827] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 1.938841] uhci_hcd 0000:00:1d.1: detected 2 ports [ 1.943400] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e880 [ 1.943606] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.943611] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.943615] usb usb3: Product: UHCI Host Controller [ 1.943618] usb usb3: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd [ 1.943621] usb usb3: SerialNumber: 0000:00:1d.1 [ 1.944154] hub 3-0:1.0: USB hub found [ 1.944197] hub 3-0:1.0: 2 ports detected [ 1.944826] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 1.944845] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 1.944860] uhci_hcd 0000:00:1d.2: detected 2 ports [ 1.947457] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ec00 [ 1.947661] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.947666] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.947669] usb usb4: Product: UHCI Host Controller [ 1.947672] usb usb4: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd [ 1.947675] usb usb4: SerialNumber: 0000:00:1d.2 [ 1.948214] hub 4-0:1.0: USB hub found [ 1.948250] hub 4-0:1.0: 2 ports detected [ 1.951644] Floppy drive(s): fd0 is 1.44M [ 1.972279] libata version 3.00 loaded. [ 1.973298] ata_piix 0000:00:1f.1: version 2.13 [ 1.973319] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007) [ 1.993671] FDC 0 is a post-1991 82077 [ 1.997814] scsi host0: ata_piix [ 2.012624] scsi host1: ata_piix [ 2.012815] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14 [ 2.012821] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15 [ 2.015602] e100 0000:01:08.0 eth0: addr 0xff8fe000, irq 20, MAC addr 00:11:11:90:7c:9d [ 2.180266] ata2.01: NODEV after polling detection [ 2.182994] ata2.00: ATAPI: SAMSUNG CD-R/RW SW-252B, R700, max UDMA/33 [ 2.186489] ata1.00: ATA-7: WDC WD1600AAJB-00PVA0, 00.07H00, max UDMA/100 [ 2.186494] ata1.00: 312581808 sectors, multi 16: LBA48 [ 2.187936] ata2.00: configured for UDMA/33 [ 2.190733] ata1.00: configured for UDMA/100 [ 2.195276] scsi 0:0:0:0: Direct-Access ATA WDC WD1600AAJB-0 7H00 PQ: 0 ANSI: 5 [ 2.223714] scsi 1:0:0:0: CD-ROM SAMSUNG CD-R/RW SW-252B R700 PQ: 0 ANSI: 5 [ 2.238813] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB) [ 2.238933] sd 0:0:0:0: [sda] Write Protect is off [ 2.238939] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 2.238990] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.258291] sr 1:0:0:0: [sr0] scsi3-mmc drive: 52x/52x writer cd/rw xa/form2 cdda tray [ 2.258296] cdrom: Uniform CD-ROM driver Revision: 3.20 [ 2.258927] sr 1:0:0:0: Attached scsi CD-ROM sr0 [ 2.264280] sda: sda1 sda2 < sda5 > [ 2.265544] sd 0:0:0:0: [sda] Attached SCSI disk [ 2.272174] tsc: Refined TSC clocksource calibration: 2400.086 MHz [ 2.272186] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x229888b2c4e, max_idle_ns: 440795222552 ns [ 2.400104] usb 2-2: new low-speed USB device number 2 using uhci_hcd [ 2.587102] usb 2-2: New USB device found, idVendor=413c, idProduct=2003 [ 2.587110] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.587114] usb 2-2: Product: Dell USB Keyboard [ 2.587116] usb 2-2: Manufacturer: Dell [ 2.599908] hidraw: raw HID events driver (C) Jiri Kosina [ 2.620384] usbcore: registered new interface driver usbhid [ 2.620388] usbhid: USB HID core driver [ 2.628340] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:413C:2003.0001/input/input3 [ 2.690125] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1d.0-2/input0 [ 2.740371] PM: Starting manual resume from disk [ 2.740382] PM: Hibernation image partition 8:5 present [ 2.740384] PM: Looking for hibernation image. [ 2.740925] PM: Image not found (code -22) [ 2.740929] PM: Hibernation image not present or could not be loaded. [ 2.940583] random: fast init done [ 3.050132] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 3.136141] usb 3-1: new low-speed USB device number 2 using uhci_hcd [ 3.300164] clocksource: Switched to clocksource tsc [ 3.325059] usb 3-1: New USB device found, idVendor=045e, idProduct=0084 [ 3.325066] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 3.325069] usb 3-1: Product: Basic Optical Mouse [ 3.325072] usb 3-1: Manufacturer: Microsoft [ 3.342693] input: Microsoft Basic Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/0003:045E:0084.0002/input/input4 [ 3.343038] hid-generic 0003:045E:0084.0002: input,hidraw1: USB HID v1.10 Mouse [Microsoft Basic Optical Mouse] on usb-0000:00:1d.1-1/input0 [ 4.125294] ip_tables: (C) 2000-2006 Netfilter Core Team [ 4.228385] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN) [ 4.228834] systemd[1]: Detected architecture x86. [ 4.240945] systemd[1]: Set hostname to <jonty>. [ 5.264887] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked. [ 5.265005] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked. [ 5.267388] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 5.267799] systemd[1]: Listening on Journal Socket (/dev/log). [ 5.268115] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 5.268544] systemd[1]: Listening on Journal Audit Socket. [ 5.268808] systemd[1]: Listening on udev Control Socket. [ 5.754956] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 5.767280] random: crng init done [ 5.767287] random: 7 urandom warning(s) missed due to ratelimiting [ 6.082659] systemd-journald[188]: Received request to flush runtime journal from PID 1 [ 6.182130] lp: driver loaded but no devices found [ 6.226562] ppdev: user-space parallel port driver [ 6.235325] parport_pc 00:04: reported by Plug and Play ACPI [ 6.235462] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP] [ 6.332944] lp0: using parport0 (interrupt-driven). [ 7.640566] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5 [ 7.640582] ACPI: Sleep Button [SLPB] [ 7.640748] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6 [ 7.640755] ACPI: Power Button [PWRF] [ 7.702241] intel_rng: Firmware space is locked read-only. If you can't or intel_rng: don't want to disable this in firmware setup, and if intel_rng: you are certain that your system has a functional intel_rng: RNG, try using the 'no_fwh_detect' option. [ 7.750690] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 7.753555] [drm] Initialized [ 7.964221] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 7.964400] sr 1:0:0:0: Attached scsi generic sg1 type 5 [ 8.577768] input: PC Speaker as /devices/platform/pcspkr/input/input7 [ 8.608133] snd_intel8x0 0000:00:1f.5: intel8x0_measure_ac97_clock: measured 58528 usecs (2820 samples) [ 8.608141] snd_intel8x0 0000:00:1f.5: clocking to 48000 [ 8.762000] agpgart-intel 0000:00:00.0: Intel 845G Chipset [ 8.762025] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable [ 8.762154] agpgart-intel 0000:00:00.0: detected 8192K stolen memory [ 8.762204] [drm] Memory usable by graphics device = 128M [ 8.762210] [drm] Replacing VGA console driver [ 8.763353] Console: switching to colour dummy device 80x25 [ 8.770478] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 8.770481] [drm] Driver supports precise vblank timestamp query. [ 8.771325] [drm:intel_bios_init [i915]] *ERROR* Unexpected child device config size 22 (expected 27 for VBT version 107) [ 8.779659] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem [ 8.816281] [drm] RC6 disabled, disabling runtime PM support [ 8.816459] [drm] initialized overlay support [ 8.817403] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0 [ 9.017628] fbcon: inteldrmfb (fb0) is primary device [ 9.088342] iTCO_vendor_support: vendor-support=0 [ 9.089593] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11 [ 9.089667] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x0460) [ 9.090579] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0) [ 9.183746] Adding 514044k swap on /dev/sda5. Priority:-1 extents:1 across:514044k FS [ 9.193624] Console: switching to colour frame buffer device 160x64 [ 9.243227] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device [ 14.525343] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 14.528264] e100 0000:01:08.0 eth0: NIC Link is Up 100 Mbps Full Duplex [ 14.536232] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 544.136149] ------------[ cut here ]------------ [ 544.136163] WARNING: CPU: 0 PID: 553 at /build/linux-iJNCu7/linux-4.9.110/debian/build/source_rt/arch/x86/include/asm/fpu/internal.h:534 fpu__restore+0x2bb/0x2f0 [ 544.136218] Modules linked in: iTCO_wdt iTCO_vendor_support evdev i915 intel_powerclamp pcspkr serio_raw snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm snd_timer snd soundcore sg video drm_kms_helper lpc_ich mfd_core shpchp drm rng_core i2c_algo_bit button parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb xts lrw gf128mul ablk_helper cryptd aes_i586 mbcache hid_generic usbhid hid sr_mod cdrom sd_mod ata_generic ata_piix libata psmouse i2c_i801 i2c_smbus scsi_mod ehci_pci uhci_hcd ehci_hcd e100 mii usbcore usb_common floppy [ 544.136225] CPU: 0 PID: 553 Comm: Xorg Not tainted 4.9.0-8-rt-686-pae #1 Debian 4.9.110-3+deb9u6 [ 544.136227] Hardware name: /D845GVSR , BIOS VA84510A.86A.0050.P18.0409222329 09/22/2004 [ 544.136235] da4ade8c cd312d4e 00000000 00000000 cd06d51a cd6db3b8 00000000 00000229 [ 544.136241] cd6cab80 00000216 cd030b3b 00000216 00000009 cd030b3b dae99e80 00000000 [ 544.136247] dae99ec0 da4adea0 cd06d62a 00000009 00000000 00000000 da4adebc cd030b3b [ 544.136248] Call Trace: [ 544.136259] [<cd312d4e>] ? dump_stack+0x55/0x77 [ 544.136265] [<cd06d51a>] ? __warn+0xea/0x110 [ 544.136268] [<cd030b3b>] ? fpu__restore+0x2bb/0x2f0 [ 544.136271] [<cd030b3b>] ? fpu__restore+0x2bb/0x2f0 [ 544.136274] [<cd06d62a>] ? warn_slowpath_null+0x2a/0x30 [ 544.136277] [<cd030b3b>] ? fpu__restore+0x2bb/0x2f0 [ 544.136280] [<cd0325fa>] ? __fpu__restore_sig+0x27a/0x6f0 [ 544.136287] [<cd024e5f>] ? restore_sigcontext.isra.10+0xdf/0x100 [ 544.136289] [<cd025771>] ? sys_sigreturn+0xa1/0xb0 [ 544.136293] [<cd00370a>] ? do_int80_syscall_32+0x6a/0xd0 [ 544.136299] [<cd5e1c7d>] ? entry_INT80_32+0x31/0x31 [ 544.136302] ---[ end trace 0000000000000002 ]--- [ 569.731711] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1) [ 569.731987] mce: [Hardware Error]: Machine check events logged [ 569.735282] CPU0: Core temperature/speed normal [ 569.736107] mce: [Hardware Error]: Machine check events logged [ 704.538172] perf: interrupt took too long (2565 > 2500), lowering kernel.perf_event_max_sample_rate to 77750 [ 759.287854] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=3362242218 end=3362242219) time 182 us, min 1017, max 1023, scanline start 1012, end 1024
6 years 11 months ago #150615 by tommylight
You have 10.10.10.10 in the hal file, but you are getting a response from 192.168.1.121 in the error log ????
Check if the jumper is set correctly on the Mesa board
Make sure you added a gateway and a dns in the network manager, it should be 10.10.10.1
Make sure your computer address is 10.10.10.11 or above, it looks OK in the attached files.
Time to create page: 0.282 seconds
