PNCconf encountered an error
18 Nov 2019 06:22 #150566 by little_sparky
Replied by little_sparky on topic PNCconf encountered an error
yeah I noticed that, I went in and changed it to 10.10.10.10 in the hal file, is this the way to do it? still had no luck connecting
18 Nov 2019 06:32 #150567 by cmorley
Replied by cmorley on topic PNCconf encountered an error
That is what to do.
network problems are not my strength.
if you open a terminal type halrun
then enter:
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10"
What happens?
18 Nov 2019 06:36 - 18 Nov 2019 06:36 #150568 by little_sparky
jonty@jonty:~$ halrun
halcmd: loadrt hostmot2
Note: Using POSIX realtime
halcmd: loadrt hm2_eth board_ip="10.10.10.10"
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: 10.10.10.10: Could not retrieve mac address
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
<stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_eth
<stdin>:2: /usr/bin/rtapi_app exited without becoming ready
<stdin>:2: insmod for hm2_eth failed, returned -1
halcmd: hm2: unloading
jonty@jonty:~$
Last edit: 18 Nov 2019 06:36 by little_sparky.
18 Nov 2019 15:52 - 18 Nov 2019 15:53 #150584 by PCW
Replied by PCW on topic PNCconf encountered an error
What does the command
ip a
return? or
ping 10.10.10.10
Last edit: 18 Nov 2019 15:53 by PCW.
19 Nov 2019 01:31 - 19 Nov 2019 01:35 #150604 by little_sparky
ip a
jonty@jonty:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 00:11:11:90:7c:9d brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.11/24 brd 10.10.10.255 scope global eth0
    inet6 fe80::211:11ff:fe90:7c9d/64 scope link
jonty@jonty:~$
ping 10.10.10.10
jonty@jonty:~$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10): 56 data bytes
64 bytes from 10.10.10.10: icmp_seq=0 ttl=64 time=0.243 ms
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.233 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.369 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.236 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.245 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.244 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.232 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.236 ms
^C--- 10.10.10.10 ping statistics ---
8 packets transmitted, 8 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.232/0.255/0.369/0.043 ms
jonty@jonty:~$
mesaflash --device 7i76e --addr 10.10.10.10 --readhmi
jonty@jonty:~$ mesaflash --device 7i76e --addr 10.10.10.10 --readhmi
Configuration Name: HOSTMOT2
  BoardName : MESA7I76
  FPGA Size: 16 KGates
  FPGA Pins: 256
  Number of IO Ports: 3
  Width of one I/O port: 17
  Clock Low frequency: 100.0000 MHz
  Clock High frequency: 200.0000 MHz
  IDROM Type: 3
  Instance Stride 0: 4
  Instance Stride 1: 64
  Register Stride 0: 256
  Register Stride 1: 256
Modules in configuration:
  Module: DPLL
  There are 1 of DPLL in configuration
  Version: 0
  Registers: 7
  BaseAddress: 7000
  ClockFrequency: 100.000 MHz
  Register Stride: 256 bytes
  Instance Stride: 4 bytes
  Module: WatchDog
  There are 1 of WatchDog in configuration
  Version: 0
  Registers: 3
  BaseAddress: 0C00
  Module: IOPort
  There are 3 of IOPort in configuration
  Version: 0
  Registers: 5
  BaseAddress: 1000
  Module: StepGen
  There are 5 of StepGen in configuration
  Version: 2
  Registers: 10
  BaseAddress: 2000
  Module: QCount
  There are 1 of QCount in configuration
  Version: 2
  Registers: 5
  BaseAddress: 3000
  Module: SSerial
  There are 1 of SSerial in configuration
  Version: 0
  Registers: 6
  BaseAddress: 5A00
  Instance Stride: 64 bytes
  Module: LED
  There are 1 of LED in configuration
  Version: 0
  Registers: 1
  BaseAddress: 0200
Configuration pin-out:
IO Connections for on-card
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       StepGen          0        Dir/Table2      (Out)
14      1   IOPort       StepGen          0        Step/Table1     (Out)
 2      2   IOPort       StepGen          1        Dir/Table2      (Out)
15      3   IOPort       StepGen          1        Step/Table1     (Out)
 3      4   IOPort       StepGen          2        Dir/Table2      (Out)
16      5   IOPort       StepGen          2        Step/Table1     (Out)
 4      6   IOPort       StepGen          3        Dir/Table2      (Out)
17      7   IOPort       StepGen          3        Step/Table1     (Out)
 5      8   IOPort       StepGen          4        Dir/Table2      (Out)
 6      9   IOPort       StepGen          4        Step/Table1     (Out)
 7     10   IOPort       SSerial          0        TXData1         (Out)
 8     11   IOPort       SSerial          0        RXData1         (In)
 9     12   IOPort       SSerial          0        TXData2         (Out)
10     13   IOPort       SSerial          0        RXData2         (In)
11     14   IOPort       QCount           0        Quad-IDX        (In)
12     15   IOPort       QCount           0        Quad-B          (In)
13     16   IOPort       QCount           0        Quad-A          (In)
IO Connections for P1
 1     17   IOPort       None
14     18   IOPort       None
 2     19   IOPort       None
15     20   IOPort       None
 3     21   IOPort       None
16     22   IOPort       None
 4     23   IOPort       None
17     24   IOPort       None
 5     25   IOPort       None
 6     26   IOPort       None
 7     27   IOPort       None
 8     28   IOPort       None
 9     29   IOPort       None
10     30   IOPort       None
11     31   IOPort       None
12     32   IOPort       None
13     33   IOPort       None
IO Connections for P2
 1     34   IOPort       None
14     35   IOPort       None
 2     36   IOPort       None
15     37   IOPort       None
 3     38   IOPort       None
16     39   IOPort       None
 4     40   IOPort       None
17     41   IOPort       None
 5     42   IOPort       None
 6     43   IOPort       None
 7     44   IOPort       None
 8     45   IOPort       None
 9     46   IOPort       None
10     47   IOPort       None
11     48   IOPort       None
12     49   IOPort       None
13     50   IOPort       None
jonty@jonty:~$
uname -v
jonty@jonty:~$ uname -v
#1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
jonty@jonty:~$ uname -a
uname -a
Linux jonty 4.9.0-8-rt-686-pae #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) i686 GNU/Linux
hal
# Generated by PNCconf at Mon Nov 18 17:28:25 2019
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config=" num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx"
setp    hm2_7i76e.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_7i76e.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf hm2_7i76e.0.write         servo-thread
setp hm2_7i76e.0.dpll.01.timer-us -50
setp hm2_7i76e.0.stepgen.timer-number 1
# external output signals
# external input signals
#  AXIS X
setp   pid.x.Pgain     [AXIS_0]P
setp   pid.x.Igain     [AXIS_0]I
setp   pid.x.Dgain     [AXIS_0]D
setp   pid.x.bias      [AXIS_0]BIAS
setp   pid.x.FF0       [AXIS_0]FF0
setp   pid.x.FF1       [AXIS_0]FF1
setp   pid.x.FF2       [AXIS_0]FF2
setp   pid.x.deadband  [AXIS_0]DEADBAND
setp   pid.x.maxoutput [AXIS_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
setp   pid.x.maxerror .0005
net x-index-enable  <=> pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-vel-cmd       =>  pid.x.command-deriv
net x-pos-fb        =>  pid.x.feedback
net x-output        =>  pid.x.output
# Step Gen signals/setup
setp   hm2_7i76e.0.stepgen.01.dirsetup        [AXIS_0]DIRSETUP
setp   hm2_7i76e.0.stepgen.01.dirhold         [AXIS_0]DIRHOLD
setp   hm2_7i76e.0.stepgen.01.steplen         [AXIS_0]STEPLEN
setp   hm2_7i76e.0.stepgen.01.stepspace       [AXIS_0]STEPSPACE
setp   hm2_7i76e.0.stepgen.01.position-scale  [AXIS_0]STEP_SCALE
setp   hm2_7i76e.0.stepgen.01.step_type        0
setp   hm2_7i76e.0.stepgen.01.control-type     1
setp   hm2_7i76e.0.stepgen.01.maxaccel         [AXIS_0]STEPGEN_MAXACCEL
setp   hm2_7i76e.0.stepgen.01.maxvel           [AXIS_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= axis.0.motor-pos-cmd
net x-vel-cmd    <= axis.0.joint-vel-cmd
net x-output     => hm2_7i76e.0.stepgen.01.velocity-cmd
net x-pos-fb     <= hm2_7i76e.0.stepgen.01.position-fb
net x-pos-fb     => axis.0.motor-pos-fb
net x-enable     <= axis.0.amp-enable-out
net x-enable     => hm2_7i76e.0.stepgen.01.enable
# ---setup home / limit switch signals---
net x-home-sw     =>  axis.0.home-sw-in
net x-neg-limit     =>  axis.0.neg-lim-sw-in
net x-pos-limit     =>  axis.0.pos-lim-sw-in
#  AXIS Y
setp   pid.y.Pgain     [AXIS_1]P
setp   pid.y.Igain     [AXIS_1]I
setp   pid.y.Dgain     [AXIS_1]D
setp   pid.y.bias      [AXIS_1]BIAS
setp   pid.y.FF0       [AXIS_1]FF0
setp   pid.y.FF1       [AXIS_1]FF1
setp   pid.y.FF2       [AXIS_1]FF2
setp   pid.y.deadband  [AXIS_1]DEADBAND
setp   pid.y.maxoutput [AXIS_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror .0005
net y-index-enable  <=> pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-vel-cmd       =>  pid.y.command-deriv
net y-pos-fb        =>  pid.y.feedback
net y-output        =>  pid.y.output
setp   hm2_7i76e.0.stepgen.02.dirsetup        [AXIS_1]DIRSETUP
setp   hm2_7i76e.0.stepgen.02.dirhold         [AXIS_1]DIRHOLD
setp   hm2_7i76e.0.stepgen.02.steplen         [AXIS_1]STEPLEN
setp   hm2_7i76e.0.stepgen.02.stepspace       [AXIS_1]STEPSPACE
setp   hm2_7i76e.0.stepgen.02.position-scale  [AXIS_1]STEP_SCALE
setp   hm2_7i76e.0.stepgen.02.step_type        0
setp   hm2_7i76e.0.stepgen.02.control-type     1
setp   hm2_7i76e.0.stepgen.02.maxaccel         [AXIS_1]STEPGEN_MAXACCEL
setp   hm2_7i76e.0.stepgen.02.maxvel           [AXIS_1]STEPGEN_MAXVEL
net y-pos-cmd    <= axis.1.motor-pos-cmd
net y-vel-cmd    <= axis.1.joint-vel-cmd
net y-output     => hm2_7i76e.0.stepgen.02.velocity-cmd
net y-pos-fb     <= hm2_7i76e.0.stepgen.02.position-fb
net y-pos-fb     => axis.1.motor-pos-fb
net y-enable     <= axis.1.amp-enable-out
net y-enable     => hm2_7i76e.0.stepgen.02.enable
# Step Gen signals/setup for tandem axis stepper
setp   hm2_7i76e.0.stepgen.03.dirsetup        [AXIS_1]DIRSETUP
setp   hm2_7i76e.0.stepgen.03.dirhold         [AXIS_1]DIRHOLD
setp   hm2_7i76e.0.stepgen.03.steplen         [AXIS_1]STEPLEN
setp   hm2_7i76e.0.stepgen.03.stepspace       [AXIS_1]STEPSPACE
setp   hm2_7i76e.0.stepgen.03.position-scale  [AXIS_1]STEP_SCALE
setp   hm2_7i76e.0.stepgen.03.step_type        0
setp   hm2_7i76e.0.stepgen.03.control-type     1
setp   hm2_7i76e.0.stepgen.03.maxaccel         [AXIS_1]STEPGEN_MAXACCEL
setp   hm2_7i76e.0.stepgen.03.maxvel           [AXIS_1]STEPGEN_MAXVEL
# ---Tandem stepper signals---
net y-output                             => hm2_7i76e.0.stepgen.03.velocity-cmd
net y-enable                             => hm2_7i76e.0.stepgen.03.enable
net y-home-sw     =>  axis.1.home-sw-in
net y-neg-limit     =>  axis.1.neg-lim-sw-in
net y-pos-limit     =>  axis.1.pos-lim-sw-in
#  AXIS Z
setp   pid.z.Pgain     [AXIS_2]P
setp   pid.z.Igain     [AXIS_2]I
setp   pid.z.Dgain     [AXIS_2]D
setp   pid.z.bias      [AXIS_2]BIAS
setp   pid.z.FF0       [AXIS_2]FF0
setp   pid.z.FF1       [AXIS_2]FF1
setp   pid.z.FF2       [AXIS_2]FF2
setp   pid.z.deadband  [AXIS_2]DEADBAND
setp   pid.z.maxoutput [AXIS_2]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror .0005
net z-index-enable  <=> pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-vel-cmd       =>  pid.z.command-deriv
net z-pos-fb        =>  pid.z.feedback
net z-output        =>  pid.z.output
setp   hm2_7i76e.0.stepgen.00.dirsetup        [AXIS_2]DIRSETUP
setp   hm2_7i76e.0.stepgen.00.dirhold         [AXIS_2]DIRHOLD
setp   hm2_7i76e.0.stepgen.00.steplen         [AXIS_2]STEPLEN
setp   hm2_7i76e.0.stepgen.00.stepspace       [AXIS_2]STEPSPACE
setp   hm2_7i76e.0.stepgen.00.position-scale  [AXIS_2]STEP_SCALE
setp   hm2_7i76e.0.stepgen.00.step_type        0
setp   hm2_7i76e.0.stepgen.00.control-type     1
setp   hm2_7i76e.0.stepgen.00.maxaccel         [AXIS_2]STEPGEN_MAXACCEL
setp   hm2_7i76e.0.stepgen.00.maxvel           [AXIS_2]STEPGEN_MAXVEL
net z-pos-cmd    <= axis.2.motor-pos-cmd
net z-vel-cmd    <= axis.2.joint-vel-cmd
net z-output     => hm2_7i76e.0.stepgen.00.velocity-cmd
net z-pos-fb     <= hm2_7i76e.0.stepgen.00.position-fb
net z-pos-fb     => axis.2.motor-pos-fb
net z-enable     <= axis.2.amp-enable-out
net z-enable     => hm2_7i76e.0.stepgen.00.enable
net z-home-sw     =>  axis.2.home-sw-in
net z-neg-limit     =>  axis.2.neg-lim-sw-in
net z-pos-limit     =>  axis.2.pos-lim-sw-in
#  SPINDLE S
setp   pid.s.Pgain     [SPINDLE_9]P
setp   pid.s.Igain     [SPINDLE_9]I
setp   pid.s.Dgain     [SPINDLE_9]D
setp   pid.s.bias      [SPINDLE_9]BIAS
setp   pid.s.FF0       [SPINDLE_9]FF0
setp   pid.s.FF1       [SPINDLE_9]FF1
setp   pid.s.FF2       [SPINDLE_9]FF2
setp   pid.s.deadband  [SPINDLE_9]DEADBAND
setp   pid.s.maxoutput [SPINDLE_9]MAX_OUTPUT
setp   pid.s.error-previous-target true
net spindle-index-enable  <=> pid.s.index-enable
net spindle-enable        =>  pid.s.enable
net spindle-vel-cmd-rpm     => pid.s.command
net spindle-vel-fb-rpm      => pid.s.feedback
net spindle-output        <=  pid.s.output
net spindle-vel-cmd-rps        <=  motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs    <=  motion.spindle-speed-out-rps-abs
net spindle-vel-cmd-rpm        <=  motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs    <=  motion.spindle-speed-out-abs
net spindle-enable             <=  motion.spindle-on
net spindle-cw                 <=  motion.spindle-forward
net spindle-ccw                <=  motion.spindle-reverse
net spindle-brake              <=  motion.spindle-brake
net spindle-revs               =>  motion.spindle-revs
net spindle-at-speed           =>  motion.spindle-at-speed
net spindle-vel-fb-rps         =>  motion.spindle-speed-in
net spindle-index-enable      <=>  motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
#  ---HALUI signals---
net joint-select-a        halui.joint.0.select
net x-is-homed            halui.joint.0.is-homed
net jog-x-pos             halui.jog.0.plus
net jog-x-neg             halui.jog.0.minus
net jog-x-analog          halui.jog.0.analog
net joint-select-b        halui.joint.1.select
net y-is-homed            halui.joint.1.is-homed
net jog-y-pos             halui.jog.1.plus
net jog-y-neg             halui.jog.1.minus
net jog-y-analog          halui.jog.1.analog
net joint-select-c        halui.joint.2.select
net z-is-homed            halui.joint.2.is-homed
net jog-z-pos             halui.jog.2.plus
net jog-z-neg             halui.jog.2.minus
net jog-z-analog          halui.jog.2.analog
net jog-selected-pos      halui.jog.selected.plus
net jog-selected-neg      halui.jog.selected.minus
net spindle-manual-cw     halui.spindle.forward
net spindle-manual-ccw    halui.spindle.reverse
net spindle-manual-stop   halui.spindle.stop
net machine-is-on         halui.machine.is-on
net jog-speed             halui.jog-speed
net MDI-mode              halui.mode.is-mdi
#  ---coolant signals---
net coolant-mist      <=  iocontrol.0.coolant-mist
net coolant-flood     <=  iocontrol.0.coolant-flood
#  ---probe signal---
net probe-in     =>  motion.probe-input
#  ---motion control signals---
net in-position               <=  motion.in-position
net machine-is-enabled        <=  motion.motion-enabled
#  ---digital in / out signals---
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-out     =>  iocontrol.0.emc-enable-in
#  ---toolchange signals for custom tool changer---
net tool-number             <=  iocontrol.0.tool-prep-number
net tool-change-request     <=  iocontrol.0.tool-change
net tool-change-confirmed   =>  iocontrol.0.tool-changed
net tool-prepare-request    <=  iocontrol.0.tool-prepare
net tool-prepare-confirmed  =>  iocontrol.0.tool-prepared
ini
[EMC]
MACHINE = my_TESTLinuxCNC_machine
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/jonty/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 170000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_eth
# BOARD0=7i76e
[HAL]
HALUI = halui
HALFILE = my_TESTLinuxCNC_machine.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 2.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 5882.35294118
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 6000
DIRHOLD    = 8000
STEPLEN    = 1800
STEPSPACE  = 1800
STEP_SCALE = 1200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 1200.0
HOME_OFFSET = 0.0
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 5882.35294118
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 6000
DIRHOLD    = 8000
STEPLEN    = 1800
STEPSPACE  = 1800
STEP_SCALE = 1200.0
MIN_LIMIT = -0.01
MAX_LIMIT = 2400.0
HOME_OFFSET = 0.0
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 5882.35294118
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 6000
DIRHOLD    = 8000
STEPLEN    = 1800
STEPSPACE  = 1800
STEP_SCALE = 80.0
MIN_LIMIT = -100.0
MAX_LIMIT = 0.01
HOME_OFFSET = 0.0
# Spindle
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
error message
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.14
Machine configuration directory is '/home/jonty/linuxcnc/configs/my_TESTLinuxCNC_machine'
Machine configuration file is 'my_TESTLinuxCNC_machine.ini'
INIFILE=/home/jonty/linuxcnc/configs/my_TESTLinuxCNC_machine/my_TESTLinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./my_TESTLinuxCNC_machine.hal
hm2_eth: ERROR: 192.168.1.121: Could not retrieve mac address
Running HAL shutdown script
Killing task linuxcncsvr, PID=1296
hm2: unloading
Debug file information:
Unexpected realtime delay on task 0
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
iptables: No chain/target/match by that name.
./my_TESTLinuxCNC_machine.hal:8: waitpid failed /usr/bin/rtapi_app hm2_eth
./my_TESTLinuxCNC_machine.hal:8: /usr/bin/rtapi_app exited without becoming ready
./my_TESTLinuxCNC_machine.hal:8: insmod for hm2_eth failed, returned -1
1296
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[    0.000000] Linux version 4.9.0-8-rt-686-pae (debian-kernel@lists.debian.org) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08)
[    0.000000] CPU0: Hyper-Threading is disabled
[    0.000000] x86/fpu: Legacy x87 FPU detected.
[    0.000000] e820: BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009fbff] usable
[    0.000000] BIOS-e820: [mem 0x000000000009fc00-0x000000000009ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000001f73ffff] usable
[    0.000000] BIOS-e820: [mem 0x000000001f740000-0x000000001f74ffff] ACPI data
[    0.000000] BIOS-e820: [mem 0x000000001f750000-0x000000001f7fffff] ACPI NVS
[    0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[    0.000000] SMBIOS 2.3 present.
[    0.000000] DMI:  /D845GVSR                       , BIOS VA84510A.86A.0050.P18.0409222329 09/22/2004
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] e820: last_pfn = 0x1f740 max_arch_pfn = 0x1000000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-DFFFF uncachable
[    0.000000]   E0000-FFFFF write-back
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask FE0000000 write-back
[    0.000000]   1 base 01F800000 mask FFF800000 uncachable
[    0.000000]   2 disabled
[    0.000000]   3 disabled
[    0.000000]   4 disabled
[    0.000000]   5 disabled
[    0.000000]   6 disabled
[    0.000000]   7 disabled
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WC  UC- UC
[    0.000000] found SMP MP-table at [mem 0x000ff780-0x000ff78f] mapped at [c00ff780]
[    0.000000] initial memory mapped: [mem 0x00000000-0x0dffffff]
[    0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[    0.000000] BRK [0x0da51000, 0x0da51fff] PGTABLE
[    0.000000] BRK [0x0da52000, 0x0da53fff] PGTABLE
[    0.000000] BRK [0x0da54000, 0x0da54fff] PGTABLE
[    0.000000] BRK [0x0da55000, 0x0da55fff] PGTABLE
[    0.000000] RAMDISK: [mem 0x1d0f2000-0x1e70cfff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000000F77A0 000014 (v00 ACPIAM)
[    0.000000] ACPI: RSDT 0x000000001F740000 000030 (v01 INTEL  D845GVS1 20040922 MSFT 00000097)
[    0.000000] ACPI: FACP 0x000000001F740200 000074 (v01 INTEL  D845GVS1 20040922 MSFT 00000097)
[    0.000000] ACPI: DSDT 0x000000001F740370 00415D (v01 INTEL  D845GVS1 0000010A MSFT 0100000D)
[    0.000000] ACPI: FACS 0x000000001F750000 000040
[    0.000000] ACPI: APIC 0x000000001F740300 000068 (v01 INTEL  D845GVS1 20040922 MSFT 00000097)
[    0.000000] ACPI: ASF! 0x000000001F7444D0 000084 (v16 AMIASF I845GASF 00000001 MSFT 0100000D)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 0MB HIGHMEM available.
[    0.000000] 503MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 1f740000
[    0.000000]   low ram: 0 - 1f740000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   Normal   [mem 0x0000000001000000-0x000000001f73ffff]
[    0.000000]   HighMem  empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009efff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x000000001f73ffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000001f73ffff]
[    0.000000] On node 0 totalpages: 128734
[    0.000000] free_area_init_node: node 0, pgdat cd829780, node_mem_map df254028
[    0.000000]   DMA zone: 40 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3998 pages, LIFO batch:0
[    0.000000]   Normal zone: 1219 pages used for memmap
[    0.000000]   Normal zone: 124736 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] Reserving Intel graphics memory at 0x000000001f800000-0x000000001fffffff
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] smpboot: Allowing 2 CPUs, 1 hotplug CPUs
[    0.000000] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.000000] PM: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.000000] e820: [mem 0x20000000-0xffffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645519600211568 ns
[    0.000000] setup_percpu: NR_CPUS:32 nr_cpumask_bits:32 nr_cpu_ids:2 nr_node_ids:1
[    0.000000] percpu: Embedded 101 pages/cpu @df187000 s381472 r0 d32224 u413696
[    0.000000] pcpu-alloc: s381472 r0 d32224 u413696 alloc=101*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 127475
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.9.0-8-rt-686-pae root=/dev/sda1 ro quiet
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] Initializing HighMem for node 0 (00000000:00000000)
[    0.000000] Memory: 475136K/514936K available (6035K kernel code, 628K rwdata, 1756K rodata, 1060K init, 592K bss, 39800K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] virtual kernel memory layout:
                   fixmap  : 0xffd36000 - 0xfffff000   (2852 kB)
                   pkmap   : 0xffa00000 - 0xffc00000   (2048 kB)
                   vmalloc : 0xdff40000 - 0xff9fe000   ( 506 MB)
                   lowmem  : 0xc0000000 - 0xdf740000   ( 503 MB)
                     .init : 0xcd83d000 - 0xcd946000   (1060 kB)
                     .data : 0xcd5e51f4 - 0xcd83b280   (2392 kB)
                     .text : 0xcd000000 - 0xcd5e51f4   (6036 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] SLUB: HWalign=128, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] 	RCU restricting CPUs from NR_CPUS=32 to nr_cpu_ids=2.
[    0.000000] 	RCU kthread priority: 1.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[    0.000000] NR_IRQS:2304 nr_irqs:440 16
[    0.000000] CPU 0 irqstacks, hard=dec3e000 soft=dec80000
[    0.000000] Console: colour VGA+ 80x25
[    0.000000] console [tty0] enabled
[    0.000000] tsc: Fast TSC calibration using PIT
[    0.000000] tsc: Detected 2400.225 MHz processor
[    0.004007] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.45 BogoMIPS (lpj=9600900)
[    0.004010] pid_max: default: 32768 minimum: 301
[    0.004058] ACPI: Core revision 20160831
[    0.012292] ACPI: 1 ACPI AML tables successfully acquired and loaded
[    0.012360] Security Framework initialized
[    0.012363] Yama: disabled by default; enable with sysctl kernel.yama.*
[    0.012376] AppArmor: AppArmor disabled by boot time parameter
[    0.012404] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.012406] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.013019] mce: CPU supports 4 MCE banks
[    0.013034] CPU0: Thermal monitoring enabled (TM1)
[    0.013049] process: using mwait in idle threads
[    0.013064] Last level iTLB entries: 4KB 128, 2MB 128, 4MB 128
[    0.013066] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 64, 1GB 0
[    0.013070] Spectre V2 : Mitigation: Full generic retpoline
[    0.013071] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.013072] Speculative Store Bypass: Vulnerable
[    0.035018] ftrace: allocating 24078 entries in 48 pages
[    0.064275] smpboot: Max logical packages: 2
[    0.064291] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.064674] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.108000] smpboot: CPU0: Intel(R) Celeron(R) CPU 2.40GHz (family: 0xf, model: 0x4, stepping: 0x1)
[    0.108000] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[    0.108000] ... version:                0
[    0.108000] ... bit width:              40
[    0.108000] ... generic registers:      18
[    0.108000] ... value mask:             000000ffffffffff
[    0.108000] ... max period:             0000007fffffffff
[    0.108000] ... fixed-purpose events:   0
[    0.108000] ... event mask:             000000000003ffff
[    0.160117] NMI watchdog: enabled on all CPUs, permanently consumes one hw-PMU counter.
[    0.168022] x86: Booted up 1 node, 1 CPUs
[    0.168029] smpboot: Total of 1 processors activated (4800.45 BogoMIPS)
[    0.168905] devtmpfs: initialized
[    0.172111] PM: Registering ACPI NVS region [mem 0x1f750000-0x1f7fffff] (720896 bytes)
[    0.172308] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.172318] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.172403] pinctrl core: initialized pinctrl subsystem
[    0.172759] NET: Registered protocol family 16
[    0.176060] cpuidle: using governor ladder
[    0.176079] cpuidle: using governor menu
[    0.176188] ACPI: bus type PCI registered
[    0.176194] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.176345] PCI: Using configuration type 1 for base access
[    0.180217] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    0.196214] ACPI: Added _OSI(Module Device)
[    0.196219] ACPI: Added _OSI(Processor Device)
[    0.196221] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.196224] ACPI: Added _OSI(Processor Aggregator Device)
[    0.196739] ACPI: Executed 2 blocks of module-level executable AML code
[    0.202314] ACPI: Interpreter enabled
[    0.202369] ACPI: (supports S0 S1 S4 S5)
[    0.202372] ACPI: Using IOAPIC for interrupt routing
[    0.202466] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.207155] ACPI: Power Resource [URP1] (off)
[    0.207269] ACPI: Power Resource [URP2] (off)
[    0.207375] ACPI: Power Resource [FDDP] (off)
[    0.207492] ACPI: Power Resource [LPTP] (off)
[    0.215331] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.215345] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI]
[    0.215357] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM
[    0.215365] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge.
[    0.215770] PCI host bridge to bus 0000:00
[    0.215777] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.215781] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.215785] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.215788] pci_bus 0000:00: root bus resource [mem 0x1f800000-0xffffffff window]
[    0.215793] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.215815] pci 0000:00:00.0: [8086:2560] type 00 class 0x060000
[    0.215832] pci 0000:00:00.0: reg 0x10: [mem 0xe0000000-0xefffffff pref]
[    0.216134] pci 0000:00:02.0: [8086:2562] type 00 class 0x030000
[    0.216158] pci 0000:00:02.0: reg 0x10: [mem 0xf0000000-0xf7ffffff pref]
[    0.216170] pci 0000:00:02.0: reg 0x14: [mem 0xffa80000-0xffafffff]
[    0.216432] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300
[    0.216492] pci 0000:00:1d.0: reg 0x20: [io  0xe800-0xe81f]
[    0.216663] pci 0000:00:1d.0: System wakeup disabled by ACPI
[    0.216789] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300
[    0.216850] pci 0000:00:1d.1: reg 0x20: [io  0xe880-0xe89f]
[    0.217018] pci 0000:00:1d.1: System wakeup disabled by ACPI
[    0.217137] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300
[    0.217197] pci 0000:00:1d.2: reg 0x20: [io  0xec00-0xec1f]
[    0.217362] pci 0000:00:1d.2: System wakeup disabled by ACPI
[    0.217486] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320
[    0.217515] pci 0000:00:1d.7: reg 0x10: [mem 0xffa7fc00-0xffa7ffff]
[    0.217640] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[    0.217771] pci 0000:00:1d.7: System wakeup disabled by ACPI
[    0.217879] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[    0.218012] pci 0000:00:1e.0: System wakeup disabled by ACPI
[    0.218120] pci 0000:00:1f.0: [8086:24c0] type 00 class 0x060100
[    0.218127] * The chipset may have PM-Timer Bug. Due to workarounds for a bug,
               * this clock source is slow. If you are sure your timer does not have
               * this bug, please use "acpi_pm_good" to disable the workaround
[    0.218221] pci 0000:00:1f.0: quirk: [io  0x0400-0x047f] claimed by ICH4 ACPI/GPIO/TCO
[    0.218228] pci 0000:00:1f.0: quirk: [io  0x0480-0x04bf] claimed by ICH4 GPIO
[    0.218405] pci 0000:00:1f.1: [8086:24cb] type 00 class 0x01018a
[    0.218427] pci 0000:00:1f.1: reg 0x10: [io  0x0000-0x0007]
[    0.218440] pci 0000:00:1f.1: reg 0x14: [io  0x0000-0x0003]
[    0.218452] pci 0000:00:1f.1: reg 0x18: [io  0x0000-0x0007]
[    0.218465] pci 0000:00:1f.1: reg 0x1c: [io  0x0000-0x0003]
[    0.218478] pci 0000:00:1f.1: reg 0x20: [io  0xffa0-0xffaf]
[    0.218492] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff]
[    0.218509] pci 0000:00:1f.1: legacy IDE quirk: reg 0x10: [io  0x01f0-0x01f7]
[    0.218512] pci 0000:00:1f.1: legacy IDE quirk: reg 0x14: [io  0x03f6]
[    0.218515] pci 0000:00:1f.1: legacy IDE quirk: reg 0x18: [io  0x0170-0x0177]
[    0.218518] pci 0000:00:1f.1: legacy IDE quirk: reg 0x1c: [io  0x0376]
[    0.218690] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500
[    0.218749] pci 0000:00:1f.3: reg 0x20: [io  0xe000-0xe01f]
[    0.218933] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100
[    0.218955] pci 0000:00:1f.5: reg 0x10: [io  0xe400-0xe4ff]
[    0.218967] pci 0000:00:1f.5: reg 0x14: [io  0xe080-0xe0bf]
[    0.218980] pci 0000:00:1f.5: reg 0x18: [mem 0xffa7f800-0xffa7f9ff]
[    0.218992] pci 0000:00:1f.5: reg 0x1c: [mem 0xffa7f400-0xffa7f4ff]
[    0.219060] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[    0.219297] pci 0000:01:00.0: [11c1:048c] type 00 class 0x078000
[    0.219320] pci 0000:01:00.0: reg 0x10: [mem 0xff8ffc00-0xff8ffcff]
[    0.219333] pci 0000:01:00.0: reg 0x14: [io  0xdc00-0xdc07]
[    0.219346] pci 0000:01:00.0: reg 0x18: [io  0xd800-0xd8ff]
[    0.219429] pci 0000:01:00.0: supports D2
[    0.219433] pci 0000:01:00.0: PME# supported from D2 D3hot D3cold
[    0.219572] pci 0000:01:08.0: [8086:1039] type 00 class 0x020000
[    0.219594] pci 0000:01:08.0: reg 0x10: [mem 0xff8fe000-0xff8fefff]
[    0.219607] pci 0000:01:08.0: reg 0x14: [io  0xd480-0xd4bf]
[    0.219694] pci 0000:01:08.0: supports D1 D2
[    0.219698] pci 0000:01:08.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.219841] pci 0000:00:1e.0: PCI bridge to [bus 01] (subtractive decode)
[    0.219848] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.219855] pci 0000:00:1e.0:   bridge window [mem 0xff800000-0xff8fffff]
[    0.219861] pci 0000:00:1e.0:   bridge window [mem 0xcea00000-0xceafffff pref]
[    0.219865] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7 window] (subtractive decode)
[    0.219869] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff window] (subtractive decode)
[    0.219872] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff window] (subtractive decode)
[    0.219876] pci 0000:00:1e.0:   bridge window [mem 0x1f800000-0xffffffff window] (subtractive decode)
[    0.219892] pci_bus 0000:00: on NUMA node 0
[    0.222153] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[    0.222360] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 9 10 11 12 14 15)
[    0.222556] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
[    0.222748] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
[    0.222939] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[    0.223137] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
[    0.223330] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
[    0.223524] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 14 15)
[    0.224251] vgaarb: setting as boot device: PCI:0000:00:02.0
[    0.224257] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.224267] vgaarb: loaded
[    0.224270] vgaarb: bridge control possible 0000:00:02.0
[    0.228073] PCI: Using ACPI for IRQ routing
[    0.228081] PCI: pci_cache_line_size set to 64 bytes
[    0.228147] e820: reserve RAM buffer [mem 0x0009fc00-0x0009ffff]
[    0.228153] e820: reserve RAM buffer [mem 0x1f740000-0x1fffffff]
[    0.232228] clocksource: Switched to clocksource refined-jiffies
[    0.257571] VFS: Disk quotas dquot_6.6.0
[    0.257636] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.257911] pnp: PnP ACPI init
[    0.258115] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.258648] system 00:01: [io  0x04d0-0x04d1] has been reserved
[    0.258661] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.258868] pnp 00:02: [dma 2]
[    0.259007] pnp 00:02: Plug and Play ACPI device, IDs PNP0700 (active)
[    0.259602] pnp 00:03: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.260444] pnp 00:04: [dma 3]
[    0.260649] pnp 00:04: Plug and Play ACPI device, IDs PNP0401 (active)
[    0.261661] system 00:05: [io  0x0400-0x047f] has been reserved
[    0.261668] system 00:05: [io  0x0680-0x06ff] has been reserved
[    0.261672] system 00:05: [io  0x0480-0x04bf] has been reserved
[    0.261680] system 00:05: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.261687] system 00:05: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.261699] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.262268] system 00:06: [mem 0x00000000-0x0009ffff] could not be reserved
[    0.262276] system 00:06: [mem 0x000c0000-0x000dffff] could not be reserved
[    0.262281] system 00:06: [mem 0x000e0000-0x000fffff] could not be reserved
[    0.262285] system 00:06: [mem 0x00100000-0x1f7fffff] could not be reserved
[    0.262294] system 00:06: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.262740] pnp: PnP ACPI: found 7 devices
[    0.262749] PnPBIOS: Disabled
[    0.303422] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.303450] clocksource: Switched to clocksource acpi_pm
[    0.303501] pci 0000:00:1f.1: BAR 5: assigned [mem 0x20000000-0x200003ff]
[    0.303514] pci 0000:00:1e.0: PCI bridge to [bus 01]
[    0.303519] pci 0000:00:1e.0:   bridge window [io  0xd000-0xdfff]
[    0.303527] pci 0000:00:1e.0:   bridge window [mem 0xff800000-0xff8fffff]
[    0.303533] pci 0000:00:1e.0:   bridge window [mem 0xcea00000-0xceafffff pref]
[    0.303544] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.303548] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.303551] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.303555] pci_bus 0000:00: resource 7 [mem 0x1f800000-0xffffffff window]
[    0.303558] pci_bus 0000:01: resource 0 [io  0xd000-0xdfff]
[    0.303562] pci_bus 0000:01: resource 1 [mem 0xff800000-0xff8fffff]
[    0.303565] pci_bus 0000:01: resource 2 [mem 0xcea00000-0xceafffff pref]
[    0.303568] pci_bus 0000:01: resource 4 [io  0x0000-0x0cf7 window]
[    0.303571] pci_bus 0000:01: resource 5 [io  0x0d00-0xffff window]
[    0.303575] pci_bus 0000:01: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.303578] pci_bus 0000:01: resource 7 [mem 0x1f800000-0xffffffff window]
[    0.303734] NET: Registered protocol family 2
[    0.303986] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.303986] TCP bind hash table entries: 4096 (order: 4, 114688 bytes)
[    0.303986] TCP: Hash tables configured (established 4096 bind 4096)
[    0.303986] UDP hash table entries: 256 (order: 2, 16384 bytes)
[    0.303986] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[    0.303986] NET: Registered protocol family 1
[    0.303986] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.303986] pci 0000:01:08.0: Firmware left e100 interrupts enabled; disabling
[    0.303986] PCI: CLS 64 bytes, default 64
[    0.303986] Unpacking initramfs...
[    1.241459] Freeing initrd memory: 22636K
[    1.242496] audit: initializing netlink subsys (disabled)
[    1.242549] audit: type=2000 audit(1574126189.239:1): initialized
[    1.247532] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    1.251906] zbud: loaded
[    1.254335] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    1.258513] io scheduler noop registered
[    1.258517] io scheduler deadline registered
[    1.258640] io scheduler cfq registered (default)
[    1.258921] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    1.258936] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    1.259215] GHES: HEST is not enabled!
[    1.259369] isapnp: Scanning for PnP cards...
[    1.613916] isapnp: No Plug & Play device found
[    1.614155] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    1.634685] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    1.635731] Linux agpgart interface v0.103
[    1.635941] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[    1.648635] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[    1.649118] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    1.652552] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.652570] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.653000] mousedev: PS/2 mouse device common for all mice
[    1.653096] rtc_cmos 00:00: RTC can wake from S4
[    1.653391] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[    1.653543] rtc_cmos 00:00: alarms up to one month, 114 bytes nvram
[    1.654815] NET: Registered protocol family 10
[    1.659596] mip6: Mobile IPv6
[    1.659604] NET: Registered protocol family 17
[    1.659614] mpls_gso: MPLS GSO support
[    1.660239] microcode: sig=0xf41, pf=0x4, revision=0x17
[    1.660387] microcode: Microcode Update Driver: v2.01 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[    1.660401] Using IPI No-Shortcut mode
[    1.660816] registered taskstats version 1
[    1.660893] zswap: loaded using pool lzo/zbud
[    1.660983] ima: No TPM chip found, activating TPM-bypass!
[    1.660989] ima: Allocated hash algorithm: sha256
[    1.665520] rtc_cmos 00:00: setting system clock to 2019-11-19 01:16:30 UTC (1574126190)
[    1.665602] PM: Hibernation image not present or could not be loaded.
[    1.667167] Freeing unused kernel memory: 1060K
[    1.667338] Write protecting the kernel text: 6040k
[    1.667471] Write protecting the kernel read-only data: 1760k
[    1.721439] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.721729] random: systemd-udevd: uninitialized urandom read (16 bytes read)
[    1.724822] random: udevadm: uninitialized urandom read (16 bytes read)
[    1.885990] ACPI: bus type USB registered
[    1.886070] usbcore: registered new interface driver usbfs
[    1.886103] usbcore: registered new interface driver hub
[    1.889338] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[    1.889342] e100: Copyright(c) 1999-2006 Intel Corporation
[    1.896653] usbcore: registered new device driver usb
[    1.898368] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.900501] ehci-pci: EHCI PCI platform driver
[    1.900817] ehci-pci 0000:00:1d.7: EHCI Host Controller
[    1.900837] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1
[    1.900863] ehci-pci 0000:00:1d.7: debug port 1
[    1.902974] uhci_hcd: USB Universal Host Controller Interface driver
[    1.908659] ehci-pci 0000:00:1d.7: cache line size of 64 is not supported
[    1.913406] ehci-pci 0000:00:1d.7: irq 23, io mem 0xffa7fc00
[    1.919204] SCSI subsystem initialized
[    1.928192] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[    1.928443] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.928448] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.928452] usb usb1: Product: EHCI Host Controller
[    1.928455] usb usb1: Manufacturer: Linux 4.9.0-8-rt-686-pae ehci_hcd
[    1.928458] usb usb1: SerialNumber: 0000:00:1d.7
[    1.928924] hub 1-0:1.0: USB hub found
[    1.928958] hub 1-0:1.0: 6 ports detected
[    1.929711] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[    1.929729] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[    1.929743] uhci_hcd 0000:00:1d.0: detected 2 ports
[    1.937079] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000e800
[    1.937291] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.937296] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.937299] usb usb2: Product: UHCI Host Controller
[    1.937303] usb usb2: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[    1.937306] usb usb2: SerialNumber: 0000:00:1d.0
[    1.937743] hub 2-0:1.0: USB hub found
[    1.937787] hub 2-0:1.0: 2 ports detected
[    1.938360] i801_smbus 0000:00:1f.3: SMBus using polling
[    1.938808] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[    1.938827] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[    1.938841] uhci_hcd 0000:00:1d.1: detected 2 ports
[    1.943400] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000e880
[    1.943606] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    1.943611] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.943615] usb usb3: Product: UHCI Host Controller
[    1.943618] usb usb3: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[    1.943621] usb usb3: SerialNumber: 0000:00:1d.1
[    1.944154] hub 3-0:1.0: USB hub found
[    1.944197] hub 3-0:1.0: 2 ports detected
[    1.944826] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[    1.944845] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[    1.944860] uhci_hcd 0000:00:1d.2: detected 2 ports
[    1.947457] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ec00
[    1.947661] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    1.947666] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.947669] usb usb4: Product: UHCI Host Controller
[    1.947672] usb usb4: Manufacturer: Linux 4.9.0-8-rt-686-pae uhci_hcd
[    1.947675] usb usb4: SerialNumber: 0000:00:1d.2
[    1.948214] hub 4-0:1.0: USB hub found
[    1.948250] hub 4-0:1.0: 2 ports detected
[    1.951644] Floppy drive(s): fd0 is 1.44M
[    1.972279] libata version 3.00 loaded.
[    1.973298] ata_piix 0000:00:1f.1: version 2.13
[    1.973319] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007)
[    1.993671] FDC 0 is a post-1991 82077
[    1.997814] scsi host0: ata_piix
[    2.012624] scsi host1: ata_piix
[    2.012815] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[    2.012821] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[    2.015602] e100 0000:01:08.0 eth0: addr 0xff8fe000, irq 20, MAC addr 00:11:11:90:7c:9d
[    2.180266] ata2.01: NODEV after polling detection
[    2.182994] ata2.00: ATAPI: SAMSUNG CD-R/RW SW-252B, R700, max UDMA/33
[    2.186489] ata1.00: ATA-7: WDC WD1600AAJB-00PVA0, 00.07H00, max UDMA/100
[    2.186494] ata1.00: 312581808 sectors, multi 16: LBA48
[    2.187936] ata2.00: configured for UDMA/33
[    2.190733] ata1.00: configured for UDMA/100
[    2.195276] scsi 0:0:0:0: Direct-Access     ATA      WDC WD1600AAJB-0 7H00 PQ: 0 ANSI: 5
[    2.223714] scsi 1:0:0:0: CD-ROM            SAMSUNG  CD-R/RW SW-252B  R700 PQ: 0 ANSI: 5
[    2.238813] sd 0:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[    2.238933] sd 0:0:0:0: [sda] Write Protect is off
[    2.238939] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.238990] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.258291] sr 1:0:0:0: [sr0] scsi3-mmc drive: 52x/52x writer cd/rw xa/form2 cdda tray
[    2.258296] cdrom: Uniform CD-ROM driver Revision: 3.20
[    2.258927] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    2.264280]  sda: sda1 sda2 < sda5 >
[    2.265544] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.272174] tsc: Refined TSC clocksource calibration: 2400.086 MHz
[    2.272186] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x229888b2c4e, max_idle_ns: 440795222552 ns
[    2.400104] usb 2-2: new low-speed USB device number 2 using uhci_hcd
[    2.587102] usb 2-2: New USB device found, idVendor=413c, idProduct=2003
[    2.587110] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.587114] usb 2-2: Product: Dell USB Keyboard
[    2.587116] usb 2-2: Manufacturer: Dell
[    2.599908] hidraw: raw HID events driver (C) Jiri Kosina
[    2.620384] usbcore: registered new interface driver usbhid
[    2.620388] usbhid: USB HID core driver
[    2.628340] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-2/2-2:1.0/0003:413C:2003.0001/input/input3
[    2.690125] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1d.0-2/input0
[    2.740371] PM: Starting manual resume from disk
[    2.740382] PM: Hibernation image partition 8:5 present
[    2.740384] PM: Looking for hibernation image.
[    2.740925] PM: Image not found (code -22)
[    2.740929] PM: Hibernation image not present or could not be loaded.
[    2.940583] random: fast init done
[    3.050132] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    3.136141] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[    3.300164] clocksource: Switched to clocksource tsc
[    3.325059] usb 3-1: New USB device found, idVendor=045e, idProduct=0084
[    3.325066] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.325069] usb 3-1: Product: Basic Optical Mouse
[    3.325072] usb 3-1: Manufacturer: Microsoft
[    3.342693] input: Microsoft Basic Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-1/3-1:1.0/0003:045E:0084.0002/input/input4
[    3.343038] hid-generic 0003:045E:0084.0002: input,hidraw1: USB HID v1.10 Mouse [Microsoft Basic Optical Mouse] on usb-0000:00:1d.1-1/input0
[    4.125294] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.228385] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
[    4.228834] systemd[1]: Detected architecture x86.
[    4.240945] systemd[1]: Set hostname to <jonty>.
[    5.264887] systemd[1]: rsync.service: Cannot add dependency job, ignoring: Unit rsync.service is masked.
[    5.265005] systemd[1]: live-tools.service: Cannot add dependency job, ignoring: Unit live-tools.service is masked.
[    5.267388] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.267799] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.268115] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.268544] systemd[1]: Listening on Journal Audit Socket.
[    5.268808] systemd[1]: Listening on udev Control Socket.
[    5.754956] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    5.767280] random: crng init done
[    5.767287] random: 7 urandom warning(s) missed due to ratelimiting
[    6.082659] systemd-journald[188]: Received request to flush runtime journal from PID 1
[    6.182130] lp: driver loaded but no devices found
[    6.226562] ppdev: user-space parallel port driver
[    6.235325] parport_pc 00:04: reported by Plug and Play ACPI
[    6.235462] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
[    6.332944] lp0: using parport0 (interrupt-driven).
[    7.640566] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input5
[    7.640582] ACPI: Sleep Button [SLPB]
[    7.640748] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input6
[    7.640755] ACPI: Power Button [PWRF]
[    7.702241] intel_rng: Firmware space is locked read-only. If you can't or
               intel_rng: don't want to disable this in firmware setup, and if
               intel_rng: you are certain that your system has a functional
               intel_rng: RNG, try using the 'no_fwh_detect' option.
[    7.750690] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    7.753555] [drm] Initialized
[    7.964221] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    7.964400] sr 1:0:0:0: Attached scsi generic sg1 type 5
[    8.577768] input: PC Speaker as /devices/platform/pcspkr/input/input7
[    8.608133] snd_intel8x0 0000:00:1f.5: intel8x0_measure_ac97_clock: measured 58528 usecs (2820 samples)
[    8.608141] snd_intel8x0 0000:00:1f.5: clocking to 48000
[    8.762000] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[    8.762025] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable
[    8.762154] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[    8.762204] [drm] Memory usable by graphics device = 128M
[    8.762210] [drm] Replacing VGA console driver
[    8.763353] Console: switching to colour dummy device 80x25
[    8.770478] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    8.770481] [drm] Driver supports precise vblank timestamp query.
[    8.771325] [drm:intel_bios_init [i915]] *ERROR* Unexpected child device config size 22 (expected 27 for VBT version 107)
[    8.779659] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    8.816281] [drm] RC6 disabled, disabling runtime PM support
[    8.816459] [drm] initialized overlay support
[    8.817403] [drm] Initialized i915 1.6.0 20160919 for 0000:00:02.0 on minor 0
[    9.017628] fbcon: inteldrmfb (fb0) is primary device
[    9.088342] iTCO_vendor_support: vendor-support=0
[    9.089593] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[    9.089667] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x0460)
[    9.090579] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    9.183746] Adding 514044k swap on /dev/sda5.  Priority:-1 extents:1 across:514044k FS
[    9.193624] Console: switching to colour frame buffer device 160x64
[    9.243227] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[   14.525343] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   14.528264] e100 0000:01:08.0 eth0: NIC Link is Up 100 Mbps Full Duplex
[   14.536232] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[  544.136149] ------------[ cut here ]------------
[  544.136163] WARNING: CPU: 0 PID: 553 at /build/linux-iJNCu7/linux-4.9.110/debian/build/source_rt/arch/x86/include/asm/fpu/internal.h:534 fpu__restore+0x2bb/0x2f0
[  544.136218] Modules linked in: iTCO_wdt iTCO_vendor_support evdev i915 intel_powerclamp pcspkr serio_raw snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm snd_timer snd soundcore sg video drm_kms_helper lpc_ich mfd_core shpchp drm rng_core i2c_algo_bit button parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb xts lrw gf128mul ablk_helper cryptd aes_i586 mbcache hid_generic usbhid hid sr_mod cdrom sd_mod ata_generic ata_piix libata psmouse i2c_i801 i2c_smbus scsi_mod ehci_pci uhci_hcd ehci_hcd e100 mii usbcore usb_common floppy
[  544.136225] CPU: 0 PID: 553 Comm: Xorg Not tainted 4.9.0-8-rt-686-pae #1 Debian 4.9.110-3+deb9u6
[  544.136227] Hardware name:  /D845GVSR                       , BIOS VA84510A.86A.0050.P18.0409222329 09/22/2004
[  544.136235]  da4ade8c cd312d4e 00000000 00000000 cd06d51a cd6db3b8 00000000 00000229
[  544.136241]  cd6cab80 00000216 cd030b3b 00000216 00000009 cd030b3b dae99e80 00000000
[  544.136247]  dae99ec0 da4adea0 cd06d62a 00000009 00000000 00000000 da4adebc cd030b3b
[  544.136248] Call Trace:
[  544.136259]  [<cd312d4e>] ? dump_stack+0x55/0x77
[  544.136265]  [<cd06d51a>] ? __warn+0xea/0x110
[  544.136268]  [<cd030b3b>] ? fpu__restore+0x2bb/0x2f0
[  544.136271]  [<cd030b3b>] ? fpu__restore+0x2bb/0x2f0
[  544.136274]  [<cd06d62a>] ? warn_slowpath_null+0x2a/0x30
[  544.136277]  [<cd030b3b>] ? fpu__restore+0x2bb/0x2f0
[  544.136280]  [<cd0325fa>] ? __fpu__restore_sig+0x27a/0x6f0
[  544.136287]  [<cd024e5f>] ? restore_sigcontext.isra.10+0xdf/0x100
[  544.136289]  [<cd025771>] ? sys_sigreturn+0xa1/0xb0
[  544.136293]  [<cd00370a>] ? do_int80_syscall_32+0x6a/0xd0
[  544.136299]  [<cd5e1c7d>] ? entry_INT80_32+0x31/0x31
[  544.136302] ---[ end trace 0000000000000002 ]---
[  569.731711] CPU0: Core temperature above threshold, cpu clock throttled (total events = 1)
[  569.731987] mce: [Hardware Error]: Machine check events logged
[  569.735282] CPU0: Core temperature/speed normal
[  569.736107] mce: [Hardware Error]: Machine check events logged
[  704.538172] perf: interrupt took too long (2565 > 2500), lowering kernel.perf_event_max_sample_rate to 77750
[  759.287854] [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=3362242218 end=3362242219) time 182 us, min 1017, max 1023, scanline start 1012, end 1024
Last edit: 19 Nov 2019 01:35 by little_sparky.
19 Nov 2019 08:41 #150615 by tommylight
Replied by tommylight on topic PNCconf encountered an error
You have 10.10.10.10 in the hal file, but you are getting a response from 192.168.1.121 in the error log ????
Check if the jumper is set correctly on the Mesa board
Make sure you added a gateway and a dns in the network manager, it should be 10.10.10.1
Make sure your computer address is 10.10.10.11 or above, it looks OK in the attached files.
Time to create page: 0.774 seconds
