- Thank you received: 79
The drives were the original ones from a Tormach 1100 series 1 mill. Research says they were basically clones of the G201 drives
Todd Zuercher wrote: If the motor is 3amp / coil I would think you would set the drive up for 3 amps.
But 3 drives and motors even at 3 amps may be more than that power-supply can handle. (at the half step position the drive would be applying 3amps to both coils of the motor, that would be 18 amps total!)
Have you tried only connecting 1 drive?
Leon82 wrote: I think the geckos want 18 minimum volts.
And on my machine when I had three steppers hooked up even though it was a 60-volt supply it never got above like 45. {A Chinese adjustable unit}.
So it is quite possible you may not have enough voltage
