Starting from scratch (again) - need help (apparently a lot)
6 years 9 months ago #154009 by PCW
I usually suggest
Steplen 5000
Stepspace 5000
DirSetup 20000
DirHold 20000
As a starting point since these will work with almost any drive,
and there is no disadvantage to long times until they limit your
maximum velocity.
6 years 9 months ago #154010 by mooser
20000 (wow)
OK, i'll reset them as see if they cause any issues once this is connected to the actual machine bed.
Wiring in the limit switches now, Spindle is next
M
6 years 9 months ago - 6 years 9 months ago #155217 by mooser
Random Update
Today I managed to get all the new parts, wires, etc all into one location and after a few backsteps and a spindle VFD wiring confusion (Sorted out thanks to PCW) I now have....
Movement in X and Z axis, both directions
Z limit and home working and back installed
X limit and home working (but not installed, really need to change the way I had the switch mounted so maybe now is the time)
remote E-stop switch working
Spindle speed and direction kind of working (RPM is way off, haven't done anything with the gear ranges yet but it spins up and down and reverses :)
Still waiting on new gears for the spindle encoder and I'll mount something temp in the mean time.
Need to tidy up the wiring a bunch as they are just loosely run over from the bulkhead fittings but I wanted to fire everything up before going nuts with the zip ties :)
Anyway, with all the various help from all the various people.... movement!!!
Next up, getting the spindle gears/rpm dialed in and maybe the encoder at the same time (would make it easier than using the laser tach on the pulleys...)
M
Last edit: 6 years 9 months ago by mooser.
Time to create page: 0.353 seconds
