PnCConf and setting up PWM on 7i96
- GND
- Topic Author
But I'm now struggling with the final step - to set up a PWM output to drive my spindle speed. I have - I believe - the right firmware in my Mesa card, namely 7i96d_1pwm. But when I get to the page in PnCConf where you choose the firmware, it only shows 7i96d as an option. And therefore it won't let me select a PWM output.
Have I done something wrong? Any help gratefully received!
Cheers
Graeme
- Thank you received: 5334
Pncconf will put in most of the hal/ini boilerplate for spindle control
including spindle enable and direction but you will have to wire the
spindle-output signal to the pwmgen value pin, setup the PWM scaling,
mode and frequency and set the PWMgen enable true
(or wire it to spindle-enable)
Basic PWM setup:
setp hm2_7i96.0.pwmgen.pwm_frequency 10000
setp hm2_7i96.0.pwmgen.00.scale 24000 # full scale is 24000 RPM
setp hm2_7i96.0.pwmgen.00.output-type 1 # standard PWM and direction
net spindle-enable hm2_7i96.0.pwmgen.00.enable
net spindle-speed-out-rpm-abs hm2_7i96.0.pwmgen.00.value
- GND
- Topic Author
No problem - I can do that!
Many thanks for your help, as ever.
Cheers
Graeme
how direction is handled and the startup
PWM state need to be addressed
- Clive S
- Thank you received: 486
I have answered your question on the other forum that you posted the question on. Are you UK based?
- GND
- Topic Author
@PCW - OK. My spindle is forward only, so I presume that removes one issue. When you say the startup PWM state, what do you mean by this? I have been reading the HostMot2 driver manual today, but see no mention of startup state?
Also, can I ask - is it possible to assign the PWM output to specific pins on the 7i96? Or is this fixed in the device configuration? I am presuming the latter from what I've read.
@Clive S - yes, I'm in the UK. I saw and responded to your posting on the other forum, where I was asking some Novamill specific questions. Many thanks for that!
ideally the spindle enable should be a 7I96 SSR output since its guaranteed to be off at
start-up or after a watchdog bite
The PWM output is determined by the firmware loaded, The standard PWM firmware
for the 7I96 replacesSTEP4/DIR4 with PWM/DIR.
You can use the software PWM on almost any I/O pin if you are OK with quite a slow
PWM frequency. For example you could use a SSR output for the software PWM
at say 10Hz PWM frequency and 1% resolution. This would be an easy way to generate
a 0 to 10V signal for a VFD as long as you dont expect fast speed changes.
- GND
- Topic Author
Thanks also for the clarification regarding the physical 7i96 connections used. It's useful to know about the SW option for PWM too - but for my purposes, using the HW PWM generator on STEP4/DIR4 is ideal. Just wanted to be sure where to put the wires!
As ever, thanks for your fast and detailed assistance.
Cheers
Graeme
- GND
- Topic Author
I believe I have everything right, because if I use the Halscope, I can see that the inputs into the PWM function are correct. If I adjust the spindle override in AXIS, I can see the PWM "value" moving between 0 and 1 exactly as expected. The other settings (enable, scale, output-type and pwm_frequency) are all just as I I have set them. But I get no output from the 7i96 pin.
I have an oscilloscope on the step4 pin (tried both the + and -) and nothing. All I see is the Step4+ goes from logic 1 to logic 0 when I run LinuxCNC But no pulse train. I checked the firmware version loaded with Mesaflash, and it has PWM. So now I'm really at a loss....
Any thoughts most welcome!
Cheers
Graeme
halcmd show all | grep pwm
When linuxcnc is running and you expect PWM output?
