PnCConf and setting up PWM on 7i96
- GND
01 Apr 2020 22:55 #162396
by GND
Replied by GND on topic PnCConf and setting up PWM on 7i96
No problem;
26 bit IN TRUE hm2_7i96.0.pwmgen.00.enable
26 float IN 1 hm2_7i96.0.pwmgen.00.value <== spindle-speed
==> hm2_7i96.0.pwmgen.00.value
26 bit RW FALSE hm2_7i96.0.pwmgen.00.out0.invert_output
26 bit RW FALSE hm2_7i96.0.pwmgen.00.out0.is_opendrain
26 bit RW FALSE hm2_7i96.0.pwmgen.00.out1.invert_output
26 bit RW FALSE hm2_7i96.0.pwmgen.00.out1.is_opendrain
26 s32 RW 1 hm2_7i96.0.pwmgen.00.output-type
26 float RW 5000 hm2_7i96.0.pwmgen.00.scale
26 u32 RW 0x00004E20 hm2_7i96.0.pwmgen.pdm_frequency
26 u32 RW 0x000003E8 hm2_7i96.0.pwmgen.pwm_frequency
hm2_7i96.0.pwmgen.00.out0.invert_output hm2_7i96.0.gpio.025.invert_output
hm2_7i96.0.pwmgen.00.out0.is_opendrain hm2_7i96.0.gpio.025.is_opendrain
hm2_7i96.0.pwmgen.00.out1.invert_output hm2_7i96.0.gpio.026.invert_output
hm2_7i96.0.pwmgen.00.out1.is_opendrain hm2_7i96.0.gpio.026.is_opendrain
Hope that gives you some clues....
Graeme
Graeme
- Thank you received: 5330
01 Apr 2020 23:08 #162399
Replied by PCW on topic PnCConf and setting up PWM on 7i96
OK so if the scale is 5000 did you try setting the spindle speed to 2500 (that should be 50% duty cycle)
The current value of 1 would be close to 0 PWM duty cycle
- GND
01 Apr 2020 23:10 #162400
by GND
This is with 51% dialed in for spindle speed override....
26 float IN 0.51 hm2_7i96.0.pwmgen.00.value <== spindle-speed
I thought it looked convincing!
- GND
01 Apr 2020 23:14 #162401
by GND
I presume that just dialing a spindle override should affect the PWM output - if the spindle is enabled? Or do I need to achieve it via MDI, or by some other means?
01 Apr 2020 23:19 #162403
I would do it with mdi
S2500 M3
S2500 M3
- GND
01 Apr 2020 23:27 #162406
by GND
Guess what! That worked...
It seems strange that I was getting the value I selected via the override visible on the PWM value pin - but maybe it was a slightly artificial test. Either way, I'm more than happy with that and can now make progress.
Many thanks - once again - for your exceptional support.
Cheers
Graeme
Cheers
Graeme
Time to create page: 0.114 seconds
