Not sure where to ask so, so I'll ask here
6 years 4 months ago #171231 by Desertboy
Hi, I have a Mesa 5i25 PCI card I would now like to use for a simple 3 axis router.
What BOB should I buy?
I have 4 Nema's 2 on the Y, 1 on X and 1 on Z I would like to setup dual homing.
Looking at the choices I think I could use a 7i78 for step/dir/spindle and a cheap PP BOB for limits and MPG
Or get a 7i76 but they are out of stock, which I think can handle all my inputs and step/dir.
If I wanted to add Nema 23's with encoders is that what 7i85 is for? And can you plug both 7i76 and 7i85 in at the same time?
I'm thinking 7i85 lets you use encoders with any stepper drivers by moving the encoding to the Mesa is this correct?
6 years 4 months ago #171250 by PCW
7i76s are in stock now.
The common "5 Axis" parallel port BOB
does have a analog spindle interface ,though its not
isolated since its power is in common with the inputs
In general the multiple encoder interfaces are mainly useful
if you have dual feedback or servo systems, not so much for
using encoder feedback from a step drive.
The following user(s) said Thank You: Desertboy
6 years 4 months ago #172034 by Desertboy
I ordered one now.
Will I need to flash the 5i25? It's got the stock firmware with it it's essentially new although I've had it over 2 years.
Do I just need a normal parallel port cable to connect the 5i25 to the 7i76?
6 years 4 months ago #172040 by PCW
I would reprogram the 5I25 with 5i25_7i76x2.bit just to make sure
You can use a standard IEEE1284 male-male parallel port cable
6 years 4 months ago #172056 by Desertboy
I have 2 MPG's I can use
HB04 USB
or standard multiwire Chinese special
The HB04 has more buttons which would be very useful but I read is less reliable.
Which one would you use?
6 years 4 months ago #172057 by Desertboy
One of the reasons I didn't use the 5i25 was the pc wouldn't boot with it in.
I had a DDCSV to hand.
I later traced the PC not booting to a PSU issue, Mesa told me a very small % had this issue and was a MB issue but I tried 5 different MB's before I swapped the PSU in that case.
As soon as I did swap the PSU 5i25 worked with 3 of the MB's didn;t try the other 2.
So if you ever see someone with a 5i25 PCI that won't boot tell them to swap the PSU first.
Time to create page: 0.274 seconds
