Not sure where to ask so, so I'll ask here
6 years 4 months ago #172065 by rodw
Aciera wrote:
I use a non USB wireless pendant that has a hard wired receiver that uses one of the 7i76e mpg
Sounds interesting. Could you provide some more information on that?
One of these cdxhctech.com/html/eProduct/view_386.html
there are a few options but they do have 7i76e compatible one..
There is some more info about this in my Spaceship plasma build thread.
The following user(s) said Thank You: Desertboy, Aciera
6 years 4 months ago #172089 by Desertboy
This is what I have
And one of these
6 years 4 months ago #172102 by rodw
6 years 3 months ago #173394 by Desertboy
My Mesa 7i76 should be with me tomorrow finally.
Can I fit it in the same enclosure as the stepper drivers and PSU (Toroidal transformer build)?
I'm trying minimize interference, will be driven by a 5i25 via a shielded PP cable and I will ground the PC case chassis and my vfd is going into a grounded PC case all my wiring is CY cable shielding is already grounded.
6 years 3 months ago #173398 by rodw
Desertboy wrote: My Mesa 7i76 should be with me tomorrow finally.
You should be OK. but if you wanted to be sure you could add some metal screen as as per this diagram from the Lam Technologies DS1076 stepper driver manual (but it also was suggesting the wiring based on a 3 phase system so I suspect its overkill
Time to create page: 0.190 seconds
