5i25/7i76 beginner issues
6 years 3 months ago - 6 years 3 months ago #173754 by Fasteagle102
Got it. I found those details about the power pins in the 7i76 manual. That will help very much. I just didn't understand at the time.
Thanks again !
Last edit: 6 years 3 months ago by Fasteagle102.
6 years 3 months ago #173755 by tommylight
5i25 internal data and 7i76 with one 7i76 should work.
See attachment:
The following user(s) said Thank You: Fasteagle102
6 years 3 months ago #173831 by Fasteagle102
Thanks again Tommylight, You are good !
The mill is working now, but in only one direction. All axis are only running in one direction and then a short pause and then again when I am in the pncconfig program and testing/tuning axis. Can you please help me figure that out too ? After that I know I will have to tune the axis and a hole new set of growing pain. But, don't get me wrong. I know that with no pain there is no gain.
6 years 3 months ago #173840 by tommylight
What drives are you using ? Some pictures of the wiring could help.
Also set the step time and step space to 5000, dir stuff to 20000, for now.
6 years 3 months ago #174104 by Fasteagle102
Sorry for the delay, here are the pics of the driver and motor. Please let me know if you need more detail.
It appears the x motor is working back and forth, but just needs calibration, the y and z motor only in one direction and A motor gets an error message. I'm thinking the dip switch positions need to match the rest. Do you agree ?
Also, the changes on the step time and space and direction didn't have any change to the sound or speed of the x motor or any other ones as well. Is it supposed to ?
BTW, the wiring as you can see in the pic are two whites and two yellows, I have them terminating on the 7i76 card to the relative 5v signals and step and direction signal. I will double check them again. Each driver has a 5 volt signal for both the step and direction, can they be crossed and still work ok ? It's just hard to get a picture of that detail.
Thanks again !
Time to create page: 0.071 seconds
