Not for now, you need to use the LinuxCNC pncconf Wizard from the menu to create a config, then check if everything works as expected.Fasteagle102 wrote: Ok, will do. Is there any particular file you would like to see other than dmesg or lvpci ?
That is wrong, both of them go to + , and they have a common groundFasteagle102 wrote: I have 24 volts + on Vin and - on Vfield.
