Errors on mesa-card selection
6 years 3 months ago - 6 years 3 months ago #174361 by Reinhard
Replied by Reinhard on topic Errors on mesa-card selection
Hi Chris,
thank you for your fast reaction!
I refreshed repository, but I don't get a save button.
... and my window looks quite different than yours.
What desktop are you using?
Axis was translated in the INI or just on the pncconf page?
In pncconf - page "Screen" in the "GUI Screen list"-combobox.
May be, you could add the save option to the window-closing dialog, when hitting the cross icon from titlebar to close application. That's the only way out, so may be good place?
cheers Reinhard
Last edit: 6 years 3 months ago by Reinhard.
6 years 3 months ago #174362 by cmorley
Replied by cmorley on topic Errors on mesa-card selection
Yes looks like the buildbot is stuck..so no new updates till fixed.
I use Mint 13
I couldn't figure out how to get it to not translate.
Yes that could be handy to save before quit too.
6 years 3 months ago #174381 by Reinhard
No, my fault.
Didn't was aware, that changes in python scripts require a run of make :ohmy:
I use Mint 13
Looks very nice in deed!
I tried xfce actually, as it seems to be new default of linuxcnc, but I can't find it usable.
May be I'm too old - I miss so many kde features, I'm used to ...
When you open screen.glade with a text-editor and search for "screen_names", then you find out, that each entry is tagged with an attribute "translatable". Turn that attributes to "no" and the problem is fixed ;)
cheers Reinhard
6 years 3 months ago #174458 by cmorley
Ahh I assumed you were using a installed version... yes some python needs 'compiled', which I think actually just moves them.
mint 13 with cinnamon; probably cinnamon is possible in other distributions.
Thanks I fixed the translation problem with your instructions.
I changed the save data button to the quit dialog and improved the quit dialog's messages
Chris
6 years 3 months ago #174515 by Reinhard
Hi Chris,
just refreshed installation and quit-dialog looks weired now:
Don't know, what happened.
Dialog has no window-decorations, which is quite unusual on glade parts.
The previous dialog looked ok.
6 years 3 months ago #174538 by cmorley
I made it a popup rather then toplevel window - so it has no window-decorators.
I can change that. What window manager are you using - that does look awful!.
You must have a low resolution set on your monitor too? the words look very large.
Is the quit dialog smaller then before?
Time to create page: 0.143 seconds
