Mesa Card 6i25. Linux CNC Error during program operation
6 years 2 months ago - 6 years 2 months ago #177700 by JZHA1985
I have a 6i25 running a G540 (basic ballscrews, direct drive, nothing fancy at all) and flashed the board using the Mesaflash utility using the command line. I'm using the latest stable release, a J1900 board, and everything is rather vanilla.
Other than the weird pinmapping and my inability to figure out the limit switches everything runs smoothly.
I used the default 1khz basethread (?) and had a few days of stability but recently had an issue with a complex program which forced me back to simply using a parallel port due to the risk of failure.
I apologize for pasting it all--I think a third through it goes over how the system encountered latency and had to shut down but obviously my understanding isn't particularly deep.
This is what I found most relevant in an attempt to save one time from going through the entire dump:
task: 1409597 cycles, min=0.000019, max=0.123975, avg=0.010411, 15 latency excursions (> 10x expected cycle time of 0.010000s)
(I'm guessing that I can lower down how many times per second everything is updated--but the docs don't elaborate much and my knowledge is apparent from my post)
Please excuse the photos I took of the screen.
I simply used the defaults the wizard provided--only "interesting" thing I can think of is I'm using a 5mm per turn ballscrew and have the units set to inches.
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.5 LINUXCNC - 2.7.15 Machine configuration directory is '/home/user/linuxcnc/configs/my_LinuxCNC_machine' Machine configuration file is 'my_LinuxCNC_machine.ini' INIFILE=/home/user/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini PARAMETER_FILE=linuxcnc.var TASK=milltask HALUI=halui DISPLAY=axis Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui Found file(REL): ./my_LinuxCNC_machine.hal Found file(REL): ./custom.hal Starting TASK program: milltask Starting DISPLAY program: axis task: main loop took 0.114786 seconds task: main loop took 0.123899 seconds task: main loop took 0.119922 seconds task: main loop took 0.117950 seconds task: main loop took 0.101951 seconds task: main loop took 0.119916 seconds task: main loop took 0.121978 seconds task: main loop took 0.101914 seconds task: main loop took 0.113981 seconds task: main loop took 0.101954 seconds Shutting down and cleaning up LinuxCNC... Running HAL shutdown script task: 1409597 cycles, min=0.000019, max=0.123975, avg=0.010411, 15 latency excursions (> 10x expected cycle time of 0.010000s) Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: python: malloc.c:4665: _int_malloc: Assertion `victim->fd_nextsize->bk_nextsize == victim' failed. /usr/bin/linuxcnc: line 864: 3427 Aborted $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS 3376 3424 Stopping realtime threads Unloading hal components Kernel message information: [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009dc00 (usable) [ 0.000000] BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable) [ 0.000000] BIOS-e820: 0000000020000000 - 0000000020100000 (reserved) [ 0.000000] BIOS-e820: 0000000020100000 - 00000000b9586000 (usable) [ 0.000000] BIOS-e820: 00000000b9586000 - 00000000b95b6000 (reserved) [ 0.000000] BIOS-e820: 00000000b95b6000 - 00000000b960a000 (usable) [ 0.000000] BIOS-e820: 00000000b960a000 - 00000000b971b000 (ACPI NVS) [ 0.000000] BIOS-e820: 00000000b971b000 - 00000000b9a7d000 (reserved) [ 0.000000] BIOS-e820: 00000000b9a7d000 - 00000000b9a7e000 (usable) [ 0.000000] BIOS-e820: 00000000b9a7e000 - 00000000b9ac0000 (reserved) [ 0.000000] BIOS-e820: 00000000b9ac0000 - 00000000b9c2e000 (usable) [ 0.000000] BIOS-e820: 00000000b9c2e000 - 00000000b9ffa000 (reserved) [ 0.000000] BIOS-e820: 00000000b9ffa000 - 00000000ba000000 (usable) [ 0.000000] BIOS-e820: 00000000e00f8000 - 00000000e00f9000 (reserved) [ 0.000000] BIOS-e820: 00000000fed01000 - 00000000fed02000 (reserved) [ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved) [ 0.000000] BIOS-e820: 0000000100000000 - 00000001c0000000 (usable) [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU! [ 0.000000] SMBIOS 2.8 present. [ 0.000000] DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Q1900B-ITX, BIOS P1.80 12/10/2015 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0xba000 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-E7FFF write-through [ 0.000000] E8000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask F80000000 write-back [ 0.000000] 1 base 080000000 mask FC0000000 write-back [ 0.000000] 2 base 0BA800000 mask FFF800000 uncachable [ 0.000000] 3 base 0BB000000 mask FFF000000 uncachable [ 0.000000] 4 base 0BC000000 mask FFC000000 uncachable [ 0.000000] 5 base 100000000 mask F80000000 write-back [ 0.000000] 6 base 180000000 mask FC0000000 write-back [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] e820 update range: 00000000ba800000 - 0000000100000000 (usable) ==> (reserved) [ 0.000000] found SMP MP-table at [c00fd6d0] fd6d0 [ 0.000000] initial memory mapped : 0 - 01800000 [ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff] [ 0.000000] RAMDISK: 3652e000 - 3728f000 [ 0.000000] ACPI: RSDP 000f04a0 00024 (v02 ALASKA) [ 0.000000] ACPI: XSDT b9690080 0007C (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FACP b969b3c0 0010C (v05 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: DSDT b9690190 0B229 (v02 ALASKA A M I 01072009 INTL 20120913) [ 0.000000] ACPI: FACS b971af80 00040 [ 0.000000] ACPI: APIC b969b4d0 00084 (v03 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: FPDT b969b558 00044 (v01 ALASKA A M I 01072009 AMI 00010013) [ 0.000000] ACPI: MCFG b969b5a0 0003C (v01 ALASKA A M I 01072009 MSFT 00000097) [ 0.000000] ACPI: LPIT b969b5e0 00104 (v01 ALASKA A M I 00000003 VLV2 0100000D) [ 0.000000] ACPI: AAFT b969b6e8 000D7 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097) [ 0.000000] ACPI: HPET b969b7c0 00038 (v01 ALASKA A M I 01072009 AMI. 00000005) [ 0.000000] ACPI: SSDT b969b7f8 00763 (v01 PmRef CpuPm 00003000 INTL 20061109) [ 0.000000] ACPI: SSDT b969bf60 00290 (v01 PmRef Cpu0Tst 00003000 INTL 20061109) [ 0.000000] ACPI: SSDT b969c1f0 0017A (v01 PmRef ApTst 00003000 INTL 20061109) [ 0.000000] ACPI: UEFI b969c370 00042 (v01 ALASKA A M I 00000000 00000000) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 2088MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x000ba000 [ 0.000000] Movable zone start PFN for each node [ 0.000000] Early memory PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009d [ 0.000000] 0: 0x00000100 -> 0x00020000 [ 0.000000] 0: 0x00020100 -> 0x000b9586 [ 0.000000] 0: 0x000b95b6 -> 0x000b960a [ 0.000000] 0: 0x000b9a7d -> 0x000b9a7e [ 0.000000] 0: 0x000b9ac0 -> 0x000b9c2e [ 0.000000] 0: 0x000b9ffa -> 0x000ba000 [ 0.000000] On node 0 totalpages: 759260 [ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4dee200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3949 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221230 pages, LIFO batch:31 [ 0.000000] HighMem zone: 4177 pages used for memmap [ 0.000000] HighMem zone: 528128 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x408 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x04] enabled) [ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x06] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high dfl lint[0x7d]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] res edge lint[0xbe]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] dfl dfl lint[0x77]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x04] low level lint[0x15]) [ 0.000000] ACPI: NMI not connected to LINT 1! [ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-86 [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) [ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) [ 0.000000] ACPI: IRQ0 used by override. [ 0.000000] ACPI: IRQ2 used by override. [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000 [ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 103 [ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000 [ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000 [ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000 [ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020100000 [ 0.000000] Allocating PCI resources starting at ba000000 (gap: ba000000:260f8000) [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632 [ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 753307 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=bbee9588-3801-4398-ad23-ad8b5c9b9ab1 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 6094720 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:000ba000) [ 0.000000] Memory: 2986572k/3047424k available (3495k kernel code, 50468k reserved, 1237k data, 416k init, 2129220k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB) [ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB) [ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:1024 16 [ 0.000000] CPU 0 irqstacks, hard=f4408000 soft=f440a000 [ 0.000000] Extended CMOS year: 2000 [ 0.000000] Interrupt pipeline (release #3) [ 0.000000] spurious 8259A interrupt: IRQ7. [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration using PIT [ 0.004000] Detected 2000.082 MHz processor. [ 0.000003] Calibrating delay loop (skipped), value calculated using timer frequency.. 4000.16 BogoMIPS (lpj=8000328) [ 0.000010] pid_max: default: 32768 minimum: 301 [ 0.000091] Security Framework initialized [ 0.000098] AppArmor: AppArmor disabled by boot time parameter [ 0.000130] Mount-cache hash table entries: 512 [ 0.000419] Initializing cgroup subsys cpuacct [ 0.000424] Initializing cgroup subsys memory [ 0.000436] Initializing cgroup subsys devices [ 0.000440] Initializing cgroup subsys freezer [ 0.000444] Initializing cgroup subsys net_cls [ 0.000448] Initializing cgroup subsys blkio [ 0.000459] Initializing cgroup subsys perf_event [ 0.000499] CPU: Physical Processor ID: 0 [ 0.000502] CPU: Processor Core ID: 0 [ 0.000508] ENERGY_PERF_BIAS: Set to 'normal', was 'performance' [ 0.000509] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8) [ 0.010005] mce: CPU supports 6 MCE banks [ 0.010016] CPU0: Thermal monitoring enabled (TM1) [ 0.010107] ACPI: Core revision 20120320 [ 0.028361] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.029088] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0 [ 0.068705] CPU0: Intel(R) Celeron(R) CPU J1900 @ 1.99GHz stepping 03 [ 0.174003] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver. [ 0.174017] ... version: 3 [ 0.174021] ... bit width: 40 [ 0.174024] ... generic registers: 2 [ 0.174027] ... value mask: 000000ffffffffff [ 0.174031] ... max period: 000000007fffffff [ 0.174034] ... fixed-purpose events: 3 [ 0.174038] ... event mask: 0000000700000003 [ 0.186074] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.197993] CPU 1 irqstacks, hard=f44f2000 soft=f44f4000 [ 0.197998] Booting Node 0, Processors #1 [ 0.208023] Initializing CPU#1 [ 0.220524] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.225943] CPU 2 irqstacks, hard=f4504000 soft=f4506000 [ 0.225948] #2 [ 0.235886] Initializing CPU#2 [ 0.248458] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.253883] CPU 3 irqstacks, hard=f4516000 soft=f4518000 [ 0.253888] #3 Ok. [ 0.263827] Initializing CPU#3 [ 0.276398] NMI watchdog: enabled, takes one hw-pmu counter. [ 0.276458] Brought up 4 CPUs [ 0.276464] Total of 4 processors activated (16000.65 BogoMIPS). [ 0.277321] devtmpfs: initialized [ 0.277749] PM: Registering ACPI NVS region [mem 0xb960a000-0xb971afff] (1118208 bytes) [ 0.278016] dummy: [ 0.278128] NET: Registered protocol family 16 [ 0.278338] ACPI: bus type pci registered [ 0.278442] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.278449] PCI: not using MMCONFIG [ 0.278880] PCI: Using configuration type 1 for base access [ 0.280153] bio: create slab <bio-0> at 0 [ 0.280350] ACPI: Added _OSI(Module Device) [ 0.280356] ACPI: Added _OSI(Processor Device) [ 0.280361] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.280366] ACPI: Added _OSI(Processor Aggregator Device) [ 0.286362] ACPI: EC: Look up EC in DSDT [ 0.308122] ACPI: Interpreter enabled [ 0.308139] ACPI: (supports S0 S4 S5) [ 0.308186] ACPI: Using IOAPIC for interrupt routing [ 0.308343] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000) [ 0.310402] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources [ 0.310407] PCI: Using MMCONFIG for extended config space [ 0.321810] ACPI: Power Resource [USBC] (on) [ 0.324696] ACPI: Power Resource [FN00] (off) [ 0.326161] ACPI: No dock devices found. [ 0.326171] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.326728] \_SB_.PCI0:_OSC invalid UUID [ 0.326732] _OSC request data:1 8 0 [ 0.326744] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.327390] pci_root PNP0A08:00: host bridge window [io 0x0000-0x006f] [ 0.327396] pci_root PNP0A08:00: host bridge window [io 0x0078-0x0cf7] [ 0.327402] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] [ 0.327407] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.327412] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] [ 0.327417] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000fffff] [ 0.327422] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xd0805ffe] [ 0.327490] PCI host bridge to bus 0000:00 [ 0.327496] pci_bus 0000:00: root bus resource [io 0x0000-0x006f] [ 0.327502] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7] [ 0.327507] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff] [ 0.327512] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff] [ 0.327517] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff] [ 0.327522] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff] [ 0.327527] pci_bus 0000:00: root bus resource [mem 0xc0000000-0xd0805ffe] [ 0.327544] pci 0000:00:00.0: [8086:0f00] type 00 class 0x060000 [ 0.327603] pci 0000:00:02.0: [8086:0f31] type 00 class 0x030000 [ 0.327623] pci 0000:00:02.0: reg 10: [mem 0xd0000000-0xd03fffff] [ 0.327640] pci 0000:00:02.0: reg 18: [mem 0xc0000000-0xcfffffff pref] [ 0.327656] pci 0000:00:02.0: reg 20: [io 0xf080-0xf087] [ 0.327730] pci 0000:00:13.0: [8086:0f21] type 00 class 0x01018a [ 0.327751] pci 0000:00:13.0: reg 10: [io 0xf070-0xf077] [ 0.327765] pci 0000:00:13.0: reg 14: [io 0xf060-0xf063] [ 0.327778] pci 0000:00:13.0: reg 18: [io 0xf050-0xf057] [ 0.327791] pci 0000:00:13.0: reg 1c: [io 0xf040-0xf043] [ 0.327804] pci 0000:00:13.0: reg 20: [io 0xf030-0xf03f] [ 0.327818] pci 0000:00:13.0: reg 24: [io 0xf020-0xf02f] [ 0.327881] pci 0000:00:1a.0: [8086:0f18] type 00 class 0x108000 [ 0.327913] pci 0000:00:1a.0: reg 10: [mem 0xd0500000-0xd05fffff] [ 0.327930] pci 0000:00:1a.0: reg 14: [mem 0xd0400000-0xd04fffff] [ 0.328027] pci 0000:00:1a.0: PME# supported from D0 D3hot [ 0.328061] pci 0000:00:1c.0: [8086:0f48] type 01 class 0x060400 [ 0.328125] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold [ 0.328154] pci 0000:00:1c.1: [8086:0f4a] type 01 class 0x060400 [ 0.328219] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold [ 0.328250] pci 0000:00:1c.2: [8086:0f4c] type 01 class 0x060400 [ 0.328312] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold [ 0.328341] pci 0000:00:1c.3: [8086:0f4e] type 01 class 0x060400 [ 0.328403] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold [ 0.328447] pci 0000:00:1d.0: [8086:0f34] type 00 class 0x0c0320 [ 0.328481] pci 0000:00:1d.0: reg 10: [mem 0xd0805000-0xd08053ff] [ 0.328594] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold [ 0.328628] pci 0000:00:1f.0: [8086:0f1c] type 00 class 0x060100 [ 0.328737] pci 0000:00:1f.3: [8086:0f12] type 00 class 0x0c0500 [ 0.328777] pci 0000:00:1f.3: reg 10: [mem 0xd0804000-0xd080401f] [ 0.328857] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f] [ 0.329019] pci 0000:01:00.0: [104c:8240] type 01 class 0x060400 [ 0.329127] pci 0000:01:00.0: supports D1 D2 [ 0.333706] pci 0000:00:1c.0: PCI bridge to [bus 01-02] [ 0.333716] pci 0000:00:1c.0: bridge window [mem 0xd0700000-0xd07fffff] [ 0.333824] pci 0000:02:00.0: [2718:5125] type 00 class 0x110000 [ 0.333851] pci 0000:02:00.0: reg 10: [mem 0xd0700000-0xd070ffff] [ 0.334028] pci 0000:01:00.0: PCI bridge to [bus 02-02] [ 0.334044] pci 0000:01:00.0: bridge window [mem 0xd0700000-0xd07fffff] [ 0.334129] pci 0000:03:00.0: [10ec:8168] type 00 class 0x020000 [ 0.334151] pci 0000:03:00.0: reg 10: [io 0xe000-0xe0ff] [ 0.334186] pci 0000:03:00.0: reg 18: [mem 0xd0604000-0xd0604fff 64bit] [ 0.334209] pci 0000:03:00.0: reg 20: [mem 0xd0600000-0xd0603fff 64bit pref] [ 0.334267] pci 0000:03:00.0: supports D1 D2 [ 0.334272] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.341688] pci 0000:00:1c.1: PCI bridge to [bus 03-03] [ 0.341696] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff] [ 0.341703] pci 0000:00:1c.1: bridge window [mem 0xd0600000-0xd06fffff] [ 0.341753] pci 0000:00:1c.2: PCI bridge to [bus 04-04] [ 0.341806] pci 0000:00:1c.3: PCI bridge to [bus 05-05] [ 0.341835] pci_bus 0000:00: on NUMA node 0 [ 0.341843] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.342330] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT] [ 0.342464] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT] [ 0.342596] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT] [ 0.342722] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT] [ 0.343010] \_SB_.PCI0:_OSC invalid UUID [ 0.343015] _OSC request data:1 f 0 [ 0.343026] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f) [ 0.356562] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.356714] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.356863] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.357012] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.357162] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled. [ 0.357313] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled. [ 0.357465] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15) [ 0.357613] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15) [ 0.357791] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none [ 0.357807] vgaarb: loaded [ 0.357811] vgaarb: bridge control possible 0000:00:02.0 [ 0.357867] PCI: Using ACPI for IRQ routing [ 0.364389] PCI: pci_cache_line_size set to 64 bytes [ 0.364471] reserve RAM buffer: 000000000009dc00 - 000000000009ffff [ 0.364477] reserve RAM buffer: 00000000b9586000 - 00000000bbffffff [ 0.364482] reserve RAM buffer: 00000000b960a000 - 00000000bbffffff [ 0.364487] reserve RAM buffer: 00000000b9a7e000 - 00000000bbffffff [ 0.364492] reserve RAM buffer: 00000000b9c2e000 - 00000000bbffffff [ 0.364497] reserve RAM buffer: 00000000ba000000 - 00000000bbffffff [ 0.364721] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0 [ 0.364733] hpet0: 3 comparators, 64-bit 14.318180 MHz counter [ 0.367765] Switching to clocksource hpet [ 0.367886] pnp: PnP ACPI init [ 0.367906] ACPI: bus type pnp registered [ 0.367941] pnp 00:00: [io 0x0070-0x0077] [ 0.367986] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.368056] pnp 00:01: [mem 0xfed00000-0xfed003ff] [ 0.368063] pnp 00:01: IRQ 8 override to edge, high [ 0.368077] pnp 00:01: [irq 8] [ 0.368123] pnp 00:01: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.368475] pnp 00:02: [bus 00-ff] [ 0.368481] pnp 00:02: [io 0x0070-0x0077] [ 0.368486] pnp 00:02: [io 0x0cf8-0x0cff] [ 0.368491] pnp 00:02: [io 0x0000-0x006f window] [ 0.368496] pnp 00:02: [io 0x0078-0x0cf7 window] [ 0.368501] pnp 00:02: [io 0x0d00-0xffff window] [ 0.368506] pnp 00:02: [mem 0x000a0000-0x000bffff window] [ 0.368511] pnp 00:02: [mem 0x000c0000-0x000dffff window] [ 0.368516] pnp 00:02: [mem 0x000e0000-0x000fffff window] [ 0.368520] pnp 00:02: [mem 0x00000000 window] [ 0.368525] pnp 00:02: [mem 0x00000000-0xffffffff window] [ 0.368530] pnp 00:02: [mem 0xc0000000-0xd0805ffe window] [ 0.368615] pnp 00:02: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active) [ 0.368773] pnp 00:03: [mem 0xff000000-0xffffffff] [ 0.368825] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active) [ 0.368856] pnp 00:04: [io 0x002e-0x002f] [ 0.368862] pnp 00:04: [io 0x004e-0x004f] [ 0.368866] pnp 00:04: [io 0x0061] [ 0.368870] pnp 00:04: [io 0x0063] [ 0.368874] pnp 00:04: [io 0x0065] [ 0.368879] pnp 00:04: [io 0x0067] [ 0.368883] pnp 00:04: [io 0x0070] [ 0.368887] pnp 00:04: [io 0x0080-0x008f] [ 0.368891] pnp 00:04: [io 0x0092] [ 0.368896] pnp 00:04: [io 0x00b2-0x00b3] [ 0.368900] pnp 00:04: [io 0x0680-0x069f] [ 0.368905] pnp 00:04: [io 0x0400-0x047f] [ 0.368909] pnp 00:04: [io 0x0500-0x05fe] [ 0.368991] system 00:04: [io 0x0680-0x069f] has been reserved [ 0.368998] system 00:04: [io 0x0400-0x047f] has been reserved [ 0.369004] system 00:04: [io 0x0500-0x05fe] has been reserved [ 0.369010] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.369182] pnp 00:05: [io 0x0000-0xffffffff disabled] [ 0.369189] pnp 00:05: [io 0x0000-0xffffffff disabled] [ 0.369194] pnp 00:05: [io 0x0290-0x029f] [ 0.369198] pnp 00:05: [io 0x0000-0xffffffff disabled] [ 0.369273] system 00:05: [io 0x0290-0x029f] has been reserved [ 0.369280] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.370279] pnp 00:06: [io 0x0378-0x037f] [ 0.370285] pnp 00:06: [io 0x0778-0x077f] [ 0.370296] pnp 00:06: [irq 5] [ 0.370301] pnp 00:06: [dma 3] [ 0.370655] pnp 00:06: Plug and Play ACPI device, IDs PNP0400 PNP0401 (active) [ 0.371170] pnp 00:07: [io 0x03f8-0x03ff] [ 0.371181] pnp 00:07: [irq 4] [ 0.371186] pnp 00:07: [dma 0 disabled] [ 0.371306] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.371967] pnp 00:08: [io 0x02f8-0x02ff] [ 0.371978] pnp 00:08: [irq 3] [ 0.371983] pnp 00:08: [dma 0 disabled] [ 0.372099] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.372631] pnp 00:09: [mem 0xe0000000-0xefffffff] [ 0.372638] pnp 00:09: [mem 0xfed01000-0xfed01fff] [ 0.372643] pnp 00:09: [mem 0xfed03000-0xfed03fff] [ 0.372647] pnp 00:09: [mem 0xfed04000-0xfed04fff] [ 0.372652] pnp 00:09: [mem 0xfed0c000-0xfed0ffff] [ 0.372657] pnp 00:09: [mem 0xfed08000-0xfed08fff] [ 0.372661] pnp 00:09: [mem 0xfed1c000-0xfed1cfff] [ 0.372669] pnp 00:09: [mem 0xfee00000-0xfeefffff] [ 0.372674] pnp 00:09: [mem 0xfef00000-0xfeffffff] [ 0.372777] system 00:09: [mem 0xe0000000-0xefffffff] could not be reserved [ 0.372784] system 00:09: [mem 0xfed01000-0xfed01fff] has been reserved [ 0.372790] system 00:09: [mem 0xfed03000-0xfed03fff] has been reserved [ 0.372796] system 00:09: [mem 0xfed04000-0xfed04fff] has been reserved [ 0.372802] system 00:09: [mem 0xfed0c000-0xfed0ffff] has been reserved [ 0.372808] system 00:09: [mem 0xfed08000-0xfed08fff] has been reserved [ 0.372814] system 00:09: [mem 0xfed1c000-0xfed1cfff] has been reserved [ 0.372820] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved [ 0.372826] system 00:09: [mem 0xfef00000-0xfeffffff] has been reserved [ 0.372833] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.375411] pnp: PnP ACPI: found 10 devices [ 0.375416] ACPI: ACPI bus type pnp unregistered [ 0.375421] PnPBIOS: Disabled by ACPI PNP [ 0.415171] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 01-02] add_size 1000 [ 0.415179] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-02] add_size 200000 [ 0.415193] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000 [ 0.415206] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 04-04] add_size 1000 [ 0.415213] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 04-04] add_size 200000 [ 0.415219] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff] to [bus 04-04] add_size 200000 [ 0.415231] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 05-05] add_size 1000 [ 0.415238] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05-05] add_size 200000 [ 0.415244] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 05-05] add_size 200000 [ 0.415259] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.415265] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.415271] pci 0000:00:1c.2: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000 [ 0.415276] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.415282] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000 [ 0.415288] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000 [ 0.415294] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.415299] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.415305] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000 [ 0.415315] pci 0000:00:1c.0: BAR 15: can't assign mem pref (size 0x200000) [ 0.415322] pci 0000:00:1c.1: BAR 15: can't assign mem pref (size 0x200000) [ 0.415329] pci 0000:00:1c.2: BAR 14: can't assign mem (size 0x200000) [ 0.415336] pci 0000:00:1c.2: BAR 15: can't assign mem pref (size 0x200000) [ 0.415342] pci 0000:00:1c.3: BAR 14: can't assign mem (size 0x200000) [ 0.415349] pci 0000:00:1c.3: BAR 15: can't assign mem pref (size 0x200000) [ 0.415356] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff] [ 0.415363] pci 0000:00:1c.2: BAR 13: assigned [io 0x2000-0x2fff] [ 0.415369] pci 0000:00:1c.3: BAR 13: assigned [io 0x3000-0x3fff] [ 0.415380] pci 0000:01:00.0: PCI bridge to [bus 02-02] [ 0.415392] pci 0000:01:00.0: bridge window [mem 0xd0700000-0xd07fffff] [ 0.415408] pci 0000:00:1c.0: PCI bridge to [bus 01-02] [ 0.415413] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff] [ 0.415421] pci 0000:00:1c.0: bridge window [mem 0xd0700000-0xd07fffff] [ 0.415432] pci 0000:00:1c.1: PCI bridge to [bus 03-03] [ 0.415438] pci 0000:00:1c.1: bridge window [io 0xe000-0xefff] [ 0.415446] pci 0000:00:1c.1: bridge window [mem 0xd0600000-0xd06fffff] [ 0.415457] pci 0000:00:1c.2: PCI bridge to [bus 04-04] [ 0.415462] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff] [ 0.415476] pci 0000:00:1c.3: PCI bridge to [bus 05-05] [ 0.415481] pci 0000:00:1c.3: bridge window [io 0x3000-0x3fff] [ 0.415563] pci_bus 0000:00: resource 4 [io 0x0000-0x006f] [ 0.415569] pci_bus 0000:00: resource 5 [io 0x0078-0x0cf7] [ 0.415574] pci_bus 0000:00: resource 6 [io 0x0d00-0xffff] [ 0.415579] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff] [ 0.415584] pci_bus 0000:00: resource 8 [mem 0x000c0000-0x000dffff] [ 0.415588] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000fffff] [ 0.415594] pci_bus 0000:00: resource 10 [mem 0xc0000000-0xd0805ffe] [ 0.415599] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff] [ 0.415603] pci_bus 0000:01: resource 1 [mem 0xd0700000-0xd07fffff] [ 0.415609] pci_bus 0000:02: resource 1 [mem 0xd0700000-0xd07fffff] [ 0.415614] pci_bus 0000:03: resource 0 [io 0xe000-0xefff] [ 0.415618] pci_bus 0000:03: resource 1 [mem 0xd0600000-0xd06fffff] [ 0.415623] pci_bus 0000:04: resource 0 [io 0x2000-0x2fff] [ 0.415628] pci_bus 0000:05: resource 0 [io 0x3000-0x3fff] [ 0.415784] NET: Registered protocol family 2 [ 0.415894] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.416183] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.416803] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.417111] TCP: Hash tables configured (established 131072 bind 65536) [ 0.417116] TCP: reno registered [ 0.417121] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.417134] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.417300] NET: Registered protocol family 1 [ 0.417326] pci 0000:00:02.0: Boot video device [ 0.431718] PCI: CLS 64 bytes, default 64 [ 0.431806] Unpacking initramfs... [ 0.850619] Freeing initrd memory: 13700k freed [ 0.856116] audit: initializing netlink socket (disabled) [ 0.856144] type=2000 audit(1596502247.748:1): initialized [ 0.871850] highmem bounce pool size: 64 pages [ 0.871859] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.872231] VFS: Disk quotas dquot_6.5.2 [ 0.872277] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.872408] msgmni has been set to 1701 [ 0.872723] alg: No test for stdrng (krng) [ 0.872781] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.872787] io scheduler noop registered [ 0.872791] io scheduler deadline registered [ 0.872833] io scheduler cfq registered (default) [ 0.873142] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.873179] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.873183] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.874318] GHES: HEST is not enabled! [ 0.874340] isapnp: Scanning for PnP cards... [ 1.228531] isapnp: No Plug & Play device found [ 1.228619] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled [ 1.249152] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.269727] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 1.290707] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 1.311375] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 1.311864] Linux agpgart interface v0.103 [ 1.312160] i8042: PNP: No PS/2 controller found. Probing ports directly. [ 1.314751] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.314816] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.315021] mousedev: PS/2 mouse device common for all mice [ 1.315116] rtc_cmos 00:00: RTC can wake from S4 [ 1.315289] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0 [ 1.315322] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs [ 1.315543] TCP: cubic registered [ 1.315656] NET: Registered protocol family 10 [ 1.316018] Mobile IPv6 [ 1.316024] NET: Registered protocol family 17 [ 1.316033] Registering the dns_resolver key type [ 1.316114] Using IPI No-Shortcut mode [ 1.316336] PM: Hibernation image not present or could not be loaded. [ 1.316357] registered taskstats version 1 [ 1.316970] rtc_cmos 00:00: setting system clock to 2020-08-04 00:50:48 UTC (1596502248) [ 1.317212] Freeing unused kernel memory: 416k freed [ 1.317464] Write protecting the kernel text: 3496k [ 1.317501] Write protecting the kernel read-only data: 984k [ 1.336810] udevd[57]: starting version 175 [ 1.363321] SCSI subsystem initialized [ 1.367491] libata version 3.00 loaded. [ 1.368030] ata_piix 0000:00:13.0: version 2.13 [ 1.368059] ata_piix 0000:00:13.0: MAP [ P0 -- P1 -- ] [ 1.376065] usbcore: registered new interface driver usbfs [ 1.376111] usbcore: registered new interface driver hub [ 1.376763] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 1.376825] r8169 0000:03:00.0: (unregistered net_device): unknown MAC, using family default [ 1.377162] r8169 0000:03:00.0: eth0: RTL8168b/8111b at 0xf8082000, d0:50:99:ac:ca:39, XID 0c000800 IRQ 17 [ 1.377171] r8169 0000:03:00.0: eth0: jumbo features [frames: 4080 bytes, tx checksumming: ko] [ 1.377706] usbcore: registered new device driver usb [ 1.378393] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.381904] ACPI: Fan [FAN0] (off) [ 1.397747] microcode: CPU0 sig=0x30673, pf=0x4, revision=0x321 [ 1.420611] microcode: CPU1 sig=0x30673, pf=0x4, revision=0x321 [ 1.424020] microcode: CPU2 sig=0x30673, pf=0x4, revision=0x321 [ 1.427500] microcode: CPU3 sig=0x30673, pf=0x4, revision=0x321 [ 1.431106] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba [ 1.521568] ata_piix 0000:00:13.0: setting latency timer to 64 [ 1.522054] scsi0 : ata_piix [ 1.522254] scsi1 : ata_piix [ 1.522349] ata1: SATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xf030 irq 14 [ 1.522356] ata2: SATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xf038 irq 15 [ 1.522490] ehci_hcd 0000:00:1d.0: setting latency timer to 64 [ 1.522501] ehci_hcd 0000:00:1d.0: EHCI Host Controller [ 1.522543] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 1 [ 1.522586] ehci_hcd 0000:00:1d.0: debug port 2 [ 1.526459] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported [ 1.526492] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xd0805000 [ 1.537515] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00 [ 1.537557] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.537563] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.537568] usb usb1: Product: EHCI Host Controller [ 1.537573] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd [ 1.537577] usb usb1: SerialNumber: 0000:00:1d.0 [ 1.537801] hub 1-0:1.0: USB hub found [ 1.537811] hub 1-0:1.0: 8 ports detected [ 1.852896] usb 1-1: new high-speed USB device number 2 using ehci_hcd [ 1.852911] Refined TSC clocksource calibration: 1999.999 MHz. [ 1.852927] Switching to clocksource tsc [ 1.985032] usb 1-1: New USB device found, idVendor=8087, idProduct=07e6 [ 1.985038] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 1.985338] hub 1-1:1.0: USB hub found [ 1.985403] hub 1-1:1.0: 4 ports detected [ 1.996647] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 320) [ 1.997078] ata1.00: ATA-9: KingSpec KDM-SA.71-008GMJ, 1.094.12, max UDMA/100 [ 1.997085] ata1.00: 15649200 sectors, multi 1: LBA48 NCQ (depth 0/32) [ 1.997626] ata1.00: configured for UDMA/100 [ 1.997826] scsi 0:0:0:0: Direct-Access ATA KingSpec KDM-SA. 1.09 PQ: 0 ANSI: 5 [ 2.256255] usb 1-1.2: new high-speed USB device number 3 using ehci_hcd [ 2.349318] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0608 [ 2.349324] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 2.349329] usb 1-1.2: Product: USB2.0 Hub [ 2.349750] hub 1-1.2:1.0: USB hub found [ 2.350064] hub 1-1.2:1.0: 3 ports detected [ 2.419936] usb 1-1.3: new low-speed USB device number 4 using ehci_hcd [ 2.518487] usb 1-1.3: New USB device found, idVendor=0d62, idProduct=910e [ 2.518493] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [ 2.518497] usb 1-1.3: Product: HP USB Business Slim Keyboard [ 2.547531] ata2: failed to resume link (SControl 20) [ 2.558423] ata2: SATA link down (SStatus 4 SControl 20) [ 2.565646] sd 0:0:0:0: [sda] 15649200 512-byte logical blocks: (8.01 GB/7.46 GiB) [ 2.565850] sd 0:0:0:0: [sda] Write Protect is off [ 2.565858] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 2.565919] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 2.566976] sda: sda1 sda2 < sda5 > [ 2.567726] sd 0:0:0:0: [sda] Attached SCSI disk [ 2.570988] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 2.572046] input: HP USB Business Slim Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3/1-1.3:1.0/input/input0 [ 2.572208] generic-usb 0003:0D62:910E.0001: input,hidraw0: USB HID v1.10 Keyboard [HP USB Business Slim Keyboard] on usb-0000:00:1d.0-1.3/input0 [ 2.578795] input: HP USB Business Slim Keyboard as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.3/1-1.3:1.1/input/input1 [ 2.579015] generic-usb 0003:0D62:910E.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [HP USB Business Slim Keyboard] on usb-0000:00:1d.0-1.3/input1 [ 2.579053] usbcore: registered new interface driver usbhid [ 2.579058] usbhid: USB HID core driver [ 2.587614] usb 1-1.4: new low-speed USB device number 5 using ehci_hcd [ 2.683543] usb 1-1.4: New USB device found, idVendor=04f2, idProduct=0939 [ 2.683551] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.683556] usb 1-1.4: Product: USB Optical Mouse [ 2.683560] usb 1-1.4: Manufacturer: PixArt [ 2.685862] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.4/1-1.4:1.0/input/input2 [ 2.686033] generic-usb 0003:04F2:0939.0003: input,hidraw2: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1d.0-1.4/input0 [ 2.759399] usb 1-1.2.1: new high-speed USB device number 6 using ehci_hcd [ 2.855084] usb 1-1.2.1: New USB device found, idVendor=0930, idProduct=6545 [ 2.855090] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 2.855095] usb 1-1.2.1: Product: DT 101 G2 [ 2.855099] usb 1-1.2.1: Manufacturer: Kingston [ 2.855103] usb 1-1.2.1: SerialNumber: 6C626DBED94EEC601000CEC8 [ 2.859196] Initializing USB Mass Storage driver... [ 2.859529] scsi2 : usb-storage 1-1.2.1:1.0 [ 2.859668] usbcore: registered new interface driver usb-storage [ 2.859673] USB Mass Storage support registered. [ 3.859031] scsi 2:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 0 CCS [ 3.860358] sd 2:0:0:0: Attached scsi generic sg1 type 0 [ 3.861011] sd 2:0:0:0: [sdb] 30481152 512-byte logical blocks: (15.6 GB/14.5 GiB) [ 3.861501] sd 2:0:0:0: [sdb] Write Protect is off [ 3.861507] sd 2:0:0:0: [sdb] Mode Sense: 23 00 00 00 [ 3.861998] sd 2:0:0:0: [sdb] No Caching mode page present [ 3.862060] sd 2:0:0:0: [sdb] Assuming drive cache: write through [ 3.865368] sd 2:0:0:0: [sdb] No Caching mode page present [ 3.865428] sd 2:0:0:0: [sdb] Assuming drive cache: write through [ 3.866627] sdb: sdb1 [ 3.868992] sd 2:0:0:0: [sdb] No Caching mode page present [ 3.869052] sd 2:0:0:0: [sdb] Assuming drive cache: write through [ 3.869119] sd 2:0:0:0: [sdb] Attached SCSI removable disk [ 7.647979] PM: Starting manual resume from disk [ 7.647986] PM: Hibernation image partition 8:5 present [ 7.647990] PM: Looking for hibernation image. [ 7.648351] PM: Image not found (code -22) [ 7.648355] PM: Hibernation image not present or could not be loaded. [ 7.659342] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 7.995284] udevd[380]: starting version 175 [ 8.094406] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3 [ 8.094419] ACPI: Power Button [PWRB] [ 8.094521] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input4 [ 8.094531] ACPI: Sleep Button [SLPB] [ 8.094619] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input5 [ 8.094628] ACPI: Power Button [PWRF] [ 8.124306] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4 [ 8.128540] parport_pc 00:06: reported by Plug and Play ACPI [ 8.128634] parport0: PC-style at 0x378 (0x778), irq 5 [PCSPP,TRISTATE] [ 8.145810] udevd[450]: renamed network interface eth0 to eth1 [ 8.751217] Adding 370684k swap on /dev/sda5. Priority:-1 extents:1 across:370684k SS [ 8.773623] EXT4-fs (sda1): re-mounted. Opts: (null) [ 8.832267] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 8.866972] loop: module loaded [ 9.822356] RPC: Registered named UNIX socket transport module. [ 9.822365] RPC: Registered udp transport module. [ 9.822370] RPC: Registered tcp transport module. [ 9.822374] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 9.830097] FS-Cache: Loaded [ 9.840598] NFS: Registering the id_resolver key type [ 9.840633] FS-Cache: Netfs 'nfs' registered for caching [ 9.848165] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 10.749819] Bluetooth: Core ver 2.16 [ 10.749851] NET: Registered protocol family 31 [ 10.749856] Bluetooth: HCI device and connection manager initialized [ 10.749862] Bluetooth: HCI socket layer initialized [ 10.749867] Bluetooth: L2CAP socket layer initialized [ 10.749879] Bluetooth: SCO socket layer initialized [ 10.776256] Bluetooth: RFCOMM TTY layer initialized [ 10.776267] Bluetooth: RFCOMM socket layer initialized [ 10.776272] Bluetooth: RFCOMM ver 1.11 [ 10.778729] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 10.778736] Bluetooth: BNEP filters: protocol multicast [ 10.838909] lp0: using parport0 (interrupt-driven). [ 10.843589] ppdev: user-space parallel port driver [ 10.979685] r8169 0000:03:00.0: eth1: link down [ 10.979916] ADDRCONF(NETDEV_UP): eth1: link is not ready [ 11.422380] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6 [ 303.549817] I-pipe: head domain RTAI registered. [ 303.549827] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) . [ 303.549916] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 303.549923] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 2000082000, CPU_FREQ 2000082000 [ 303.549928] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312 [ 303.549934] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 2248500 [ 303.578542] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>. [ 303.578592] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes. [ 303.578601] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists. [ 303.578607] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2000082000 hz. [ 303.578611] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns. [ 303.592485] RTAI[math]: loaded. [ 303.709173] hm2: loading Mesa HostMot2 driver version 0.15 [ 303.714208] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7 [ 303.714315] hm2_pci: discovered 5i25 at 0000:02:00.0 [ 303.718958] hm2/hm2_5i25.0: 34 I/O Pins used: [ 303.718965] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort [ 303.718971] hm2/hm2_5i25.0: IO Pin 001 (P3-14): PWMGen #0, pin Out0 (PWM or Up) (Output) [ 303.718977] hm2/hm2_5i25.0: IO Pin 002 (P3-02): StepGen #0, pin Step (Output) [ 303.718981] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort [ 303.718986] hm2/hm2_5i25.0: IO Pin 004 (P3-03): StepGen #0, pin Direction (Output) [ 303.718992] hm2/hm2_5i25.0: IO Pin 005 (P3-16): StepGen #4, pin Step (Output) [ 303.718997] hm2/hm2_5i25.0: IO Pin 006 (P3-04): StepGen #1, pin Step (Output) [ 303.719002] hm2/hm2_5i25.0: IO Pin 007 (P3-17): IOPort [ 303.719007] hm2/hm2_5i25.0: IO Pin 008 (P3-05): StepGen #1, pin Direction (Output) [ 303.719012] hm2/hm2_5i25.0: IO Pin 009 (P3-06): StepGen #2, pin Step (Output) [ 303.719017] hm2/hm2_5i25.0: IO Pin 010 (P3-07): StepGen #2, pin Direction (Output) [ 303.719022] hm2/hm2_5i25.0: IO Pin 011 (P3-08): StepGen #3, pin Step (Output) [ 303.719027] hm2/hm2_5i25.0: IO Pin 012 (P3-09): StepGen #3, pin Direction (Output) [ 303.719033] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Encoder #0, pin A (Input) [ 303.719038] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Encoder #0, pin B (Input) [ 303.719043] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Encoder #0, pin Index (Input) [ 303.719048] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort [ 303.719052] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort [ 303.719057] hm2/hm2_5i25.0: IO Pin 018 (P2-14): PWMGen #1, pin Out0 (PWM or Up) (Output) [ 303.719062] hm2/hm2_5i25.0: IO Pin 019 (P2-02): StepGen #5, pin Step (Output) [ 303.719067] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort [ 303.719072] hm2/hm2_5i25.0: IO Pin 021 (P2-03): StepGen #5, pin Direction (Output) [ 303.719077] hm2/hm2_5i25.0: IO Pin 022 (P2-16): StepGen #9, pin Step (Output) [ 303.719083] hm2/hm2_5i25.0: IO Pin 023 (P2-04): StepGen #6, pin Step (Output) [ 303.719087] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort [ 303.719092] hm2/hm2_5i25.0: IO Pin 025 (P2-05): StepGen #6, pin Direction (Output) [ 303.719097] hm2/hm2_5i25.0: IO Pin 026 (P2-06): StepGen #7, pin Step (Output) [ 303.719103] hm2/hm2_5i25.0: IO Pin 027 (P2-07): StepGen #7, pin Direction (Output) [ 303.719108] hm2/hm2_5i25.0: IO Pin 028 (P2-08): StepGen #8, pin Step (Output) [ 303.719113] hm2/hm2_5i25.0: IO Pin 029 (P2-09): StepGen #8, pin Direction (Output) [ 303.719118] hm2/hm2_5i25.0: IO Pin 030 (P2-10): Encoder #1, pin A (Input) [ 303.719124] hm2/hm2_5i25.0: IO Pin 031 (P2-11): Encoder #1, pin B (Input) [ 303.719129] hm2/hm2_5i25.0: IO Pin 032 (P2-12): Encoder #1, pin Index (Input) [ 303.719133] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort [ 303.719316] hm2/hm2_5i25.0: registered [ 303.719320] hm2_5i25.0: initialized AnyIO board at 0000:02:00.0 [ 325.340921] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [ 603.396870] sdb: detected capacity change from 15606349824 to 0 [ 605.941129] usb 1-1.2.1: USB disconnect, device number 6 [ 605.943117] scsi 2:0:0:0: rejecting I/O to offline device [ 605.943127] scsi 2:0:0:0: killing request [13555.738814] usb 1-1.2.1: new high-speed USB device number 7 using ehci_hcd [13555.835241] usb 1-1.2.1: New USB device found, idVendor=0930, idProduct=6545 [13555.835248] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [13555.835253] usb 1-1.2.1: Product: DT 101 G2 [13555.835257] usb 1-1.2.1: Manufacturer: Kingston [13555.835261] usb 1-1.2.1: SerialNumber: 6C626DBED94EEC601000CEC8 [13555.835797] scsi3 : usb-storage 1-1.2.1:1.0 [13556.910059] scsi 3:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 0 CCS [13556.912291] sd 3:0:0:0: Attached scsi generic sg1 type 0 [13558.755055] sd 3:0:0:0: [sdb] 30481152 512-byte logical blocks: (15.6 GB/14.5 GiB) [13558.755540] sd 3:0:0:0: [sdb] Write Protect is off [13558.755547] sd 3:0:0:0: [sdb] Mode Sense: 23 00 00 00 [13558.756038] sd 3:0:0:0: [sdb] No Caching mode page present [13558.756045] sd 3:0:0:0: [sdb] Assuming drive cache: write through [13558.759288] sd 3:0:0:0: [sdb] No Caching mode page present [13558.759294] sd 3:0:0:0: [sdb] Assuming drive cache: write through [13558.779162] sdb: sdb1 [13558.781486] sd 3:0:0:0: [sdb] No Caching mode page present [13558.781493] sd 3:0:0:0: [sdb] Assuming drive cache: write through [13558.781500] sd 3:0:0:0: [sdb] Attached SCSI removable disk [13566.551717] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [13712.170675] usb 1-1.2.1: USB disconnect, device number 7 [13778.534812] usb 1-1.2.1: new high-speed USB device number 8 using ehci_hcd [13778.631242] usb 1-1.2.1: New USB device found, idVendor=0930, idProduct=6545 [13778.631248] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [13778.631255] usb 1-1.2.1: Product: DT 101 G2 [13778.631261] usb 1-1.2.1: Manufacturer: Kingston [13778.631266] usb 1-1.2.1: SerialNumber: 6C626DBED94EEC601000CEC8 [13778.631851] scsi4 : usb-storage 1-1.2.1:1.0 [13779.706067] scsi 4:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 0 CCS [13779.707308] sd 4:0:0:0: Attached scsi generic sg1 type 0 [13781.588357] sd 4:0:0:0: [sdb] 30481152 512-byte logical blocks: (15.6 GB/14.5 GiB) [13781.588844] sd 4:0:0:0: [sdb] Write Protect is off [13781.588851] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00 [13781.589342] sd 4:0:0:0: [sdb] No Caching mode page present [13781.589349] sd 4:0:0:0: [sdb] Assuming drive cache: write through [13781.592716] sd 4:0:0:0: [sdb] No Caching mode page present [13781.592724] sd 4:0:0:0: [sdb] Assuming drive cache: write through [13781.613471] sdb: sdb1 [13781.618163] sd 4:0:0:0: [sdb] No Caching mode page present [13781.618172] sd 4:0:0:0: [sdb] Assuming drive cache: write through [13781.618179] sd 4:0:0:0: [sdb] Attached SCSI removable disk [13788.775829] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! [14951.025238] hm2_5i25.0: dropping AnyIO board at 0000:02:00.0 [14951.025248] hm2/hm2_5i25.0: unregistered [14951.025327] hm2_pci: driver unloaded [14951.028159] hm2: unloading [14953.180018] RTAI[math]: unloaded. [14953.182992] SCHED releases registered named ALIEN PEDV$D [14953.190395] RTAI[malloc]: unloaded. [14953.286582] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0). [14953.289462] I-pipe: head domain RTAI unregistered. [14953.289561] RTAI[hal]: unmounted.
Last edit: 6 years 2 months ago by JZHA1985.
6 years 2 months ago #177703 by tommylight
step time = 500
step space = 5000
direction setup 20000
direction hold = 20000
servo period must be 1000000 or 1 million
And you have very bad latency issues, so try disabling everything related to power saving, speed step, hyperthreading, virtualisation, etc in the BIOS.
6 years 2 months ago #177715 by PCW
Is actually rather meaningless (and not an error)
What actual problem do you have and can you post your hal/ini files?
The following user(s) said Thank You: JZHA1985
6 years 2 months ago #177717 by rodw
I have found that a termination on startup is usually as a result of a mis-configuration error
as as PCW says, post your config files.
6 years 2 months ago - 6 years 2 months ago #177721 by JZHA1985
I had a program running and suddenly in the middle of it LinuxCNC said it needed to close along with telling me to share the aforementioned information.
I've got another machine that uses the same motherboard, also uses a G540, the same SATA DOM, very similar BIOS setup and same version of Linux CNC. Both were setup to do step gen with the parallel port initially till recently.
The "good" machine has ran perfectly for over 4 years with parallel port step gen with default settings and the "problem" machine was configured identically (BIOS is almost identical--I think one has 64 MB video memory and the other is auto) but was always used less than a dozen times per year as my backup setup...
When I started using it daily the problems became apparent (lost position, faulting on the G540, etc); therefore, I increased step timing which helped immensely but not fully, I tried the spare 6i25 card, and continue to have problems that make me think the motherboard is defective for my timing needs.
Attached are the INI and the HAL files.
6 years 2 months ago #177723 by PCW
Hmm the real error seems to be to be this:
Not sure what triggered this but it does not seem to be 6I25 related
Time to create page: 0.169 seconds
