Mesa Card 6i25. Linux CNC Error during program operation
6 years 2 months ago #177724 by JZHA1985
I'm positing that merely loading up 100K lines of code and the limited amount of video memory available coupled with other variables could be the issue. I'll do a dry run with the video memory switched to either a high level or auto then see how it goes.
6 years 2 months ago #177725 by rodw
jm82792 wrote: I'm positing that merely loading up 100K lines of code and the limited amount of video memory available coupled with other variables could be the issue. I'll do a dry run with the video memory switched to either a high level or auto then see how it goes.
malloc() is a C function that allocates memory. Its possible for some reason that there was a memory overflow or insufficient memory remaining to allocate the amount of memory requested.
I don't think that would be due to the Pcode. People say they run far larger files than that. So as you say, it could be graphics related
The following user(s) said Thank You: JZHA1985
6 years 2 months ago #177726 by JZHA1985
Could it be a bad stick of ram or likely not?
Regardless I'll first change it to auto, second I'll swap the ram out, and thirdly I'll reevaluate.
Thank you for the info everyone--I'll give it all a shot and see how it goes.
6 years 2 months ago - 6 years 2 months ago #177772 by JZHA1985
I think we've found the problem and it took less than a few minutes of memory testing.
All it took was adding an additional stick of ram and not realizing that it could be causing an intermittent problem--which has wasted 10+ hours of time, and resulted in me collecting another G540 to my collection.
Attached are screenshots of both machines with Memtest86--test your memory is my only advice at the moment for others!
Last edit: 6 years 2 months ago by JZHA1985.
Time to create page: 0.208 seconds
