Mesa 7i76E first try
6 years 2 months ago #177834 by Jocman
Replied by Jocman on topic Mesa 7i76E first try
Honestly,as nothing moved i quit pncconfig without going on with the other axis....
Well,tomorrow when i back from work (in a while i'll go to sleep) i'll try to complete the wizard procedure and see what happen....
6 years 2 months ago #177918 by Jocman
Ok I did the full pncconf procedure and started Linuxcnc. But I got an error message (see attacheg log.txt).
As I understand, I've an issue with Preempt-RT kernel (so as I found on other post in the forum).
If I'm right, I've installed Linuxcnc Debian Wheezy, so I tried to follow the steps found on Linuxcnc website to install Preempt-RT kernel.
But this time the system tells me there's nothing to update.
Well, don't know what to do now....
6 years 2 months ago #177919 by tommylight
Replied by tommylight on topic Mesa 7i76E first try
You need the Stretch version of LinuxCNC for Mesa ethernet boards.
Get it in the downloads section of the main Linuxcnc page.
linuxcnc.org/downloads/
6 years 2 months ago #177924 by dvn4life1972
Replied by dvn4life1972 on topic Mesa 7i76E first try
Jocman wrote: Unfortunately it wouldn't accept more than 5000 each fields,but even inserting 5000 in each field,then trying lowering the values,the motor still don't move....
Did you select "Custom" for the stepper? I'm pretty sure it won't allow value changes, or at least only a very limited range, unless custom is selected.
6 years 2 months ago - 6 years 2 months ago #177995 by Jocman
tommylight wrote: You need the Stretch version of LinuxCNC for Mesa ethernet boards.
Just started downloading the Stretch version.
Reading the specifics, it says:
"This is compatible with Mesa PCI and PCIe and Pico interface boards but is not compatible with Mesa Ethernet interface boards"
The 7i76E (my board) is an Ethernet device. Any chance it won't work (but I think it referres to debian7, while the stretch should be 9)? BTW, doing a try is not a problem. I'm waiting for a new SSD to install the strecth versione, then see what happens...
Yep, custom was selected. Nevertheless, the max value allowed is 5000 (even putting higher values, it automatically reduces to 5000....)
Last edit: 6 years 2 months ago by Jocman.
The following user(s) said Thank You: dvn4life1972
6 years 2 months ago #178035 by dvn4life1972
You could change that value in your INI file manually, right after running and completing the pncconf.
I'm running stretch (debian 9) with a Mesa ethernet board, you should be okay there.
Time to create page: 0.171 seconds
