Setup a M545D driver with a stepper motor
5 years 5 months ago #210610 by Goulven
So I tried with another driver (DM556) and another motor (4 wires 23HS30-2804S) with the same result. The problem is elsewhere ...
This is how I connect the driver to the mesa 7i76 board:
Is this correct?
My ini and hal files as attachments
  • BeagleBrainz
  • New Member
  • New Member
5 years 5 months ago #210611 by BeagleBrainz
Replied by BeagleBrainz on topic Setup a M545D driver with a stepper motor
Is that diagram labelled correctly ?
Your diagram has the enable connections connected and the pulse connections disconnected. Usually its the other way around.
This thread maybe of help.
forum.linuxcnc.org/27-driver-boards/3191...-sheet?start=0#83565
5 years 5 months ago - 5 years 5 months ago #210615 by Goulven
Thanks BeagleBrainz. after reading this thread it's working with DM556:
forum.linuxcnc.org/27-driver-boards/4013...t-it-to-move-stepper
Here is how i wired the driver (Don't working with M545D):
Last edit: 5 years 5 months ago by Goulven. Reason: Wrong driver
5 years 5 months ago #210620 by Goulven
it's also working for M545D with Hobbycnc 8 Wires Motors (23-205-DS8) with the same conection...ThX Andypugh and BeagleBrainz
The following user(s) said Thank You: BeagleBrainz
Time to create page: 0.400 seconds
