PnCConf Wizard doesn't launch
5 years 2 months ago #216837 by bevins
What? Pncconf is broken? that blows.
Time to check JT's stuff out. I have another plasma machine next week to do.
Anything else broken we need to know about?
IS 2.8 QTplasmac updated to latest or we need master for that?
5 years 2 months ago #216853 by robertspark
could install from *.Deb files of previous buildbot installs too.... that is how I am upgrading to test and downgrade to run stuff.... not happy about changes but heyho such is a development release and the nature of old applications no longer being supported.....
5 years 2 months ago #216874 by CFE
Replied by CFE on topic PnCConf Wizard doesn't launch
Hi all,
Thank you for the responses. I have used our old computer which is currently driving the plasma cutter to make up configuration files using PnCConf. I will copy them to the new computer and manually edit the ini and hal files, that is for us the path of least trouble.
We are going from using a parallel port setup to the MESA ethernet setup, and I see in the hal files pin and signal names we are not familiar with. Is there a document somewhere which explains which pin/signal does what ? That will be a great help to understand the workings of the hal files for the MESA card.
Cheers, Peter
5 years 2 months ago #216895 by tommylight
There are sim configs included with LinuxCNC for Mesa boards, have a look at those as a starting point.
5 years 2 months ago #216903 by BigJohnT
All the sims for Mesa look like very old cards like 5i20 era. I don't see any for the newer cards.
JT
5 years 2 months ago #217274 by CFE
Hi all,
I have manually set up .ini and .hal files to create a basic machine, and I wanted to run PlasmaC/QtPlasmaC configurator. But if I read the QtPlasmaC user guide then QtPlasmaC is now setup with the PnCConf Wizard, which is the very thing that doesn't work. What am I supposed to do now ?
Cheers, Peter
Time to create page: 0.298 seconds
