- Thank you received: 216
Did you pick two mesa cards?I have pushed the PnCconf changes. I probably missed something but it does at least seem to build configs.
Stepconf was "fixed" several days ago.
NOt sure if I did something unexpected but there are a number of errors loading hostmot2. I think pncconf is stuttering...Code:loadrt hm2_eth board_ip="10.10.10.10, 192.168.1.121" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx, num_encoders=3 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxx00xxxx"
