Hi all,
I am setting up a computer to control our plasma cutter through a MESA 7i76E card. I got the ethernet connection established between the computer and the card, and I get info about the card when I go "mesaflash --device 7i76e --addr 10.10.10.10 --readhmid" in a terminal. So far, so good. But the PnCConf wizard doesn't launch from the applications menu, and if I try "pncconf" in a terminal then I get the following message :
/usr/bin/pncconf:43: PyGIWarning: Gtk was imported without specifying a version first. Use gi.require_version('Gtk', '3.0') before import to ensure that the right version gets loaded.
from gi.repository import Gtk as gtk
File "/usr/bin/pncconf", line 45, in <module>
import gtk.glade
ModuleNotFoundError: No module named 'gtk.glade'
We have a buildbot installation on buster, master-rtpreempt, 2.9, and I have installed glade with "sudo apt-get install glade" in a terminal. How do we get the PnCConf wizard to work ?
Cheers, Peter
